1326
OxygenOS 10.0 for the OnePlus 6 and 6T
  1. Vivek Unni
    Froyo Dec 4, 2019
    Vivek Unni , via OnePlus 6T , Dec 4, 2019 :
    thanks everyone who waited for the latest update with patience instead of people who were just cringy to know where is the update. [e]1f60a[/e]
    PapaMag, _BlackPanther_ and Kytharsis like this.
  2. kmaier
    Honeycomb Dec 4, 2019
    kmaier , via OnePlus 6 , Dec 4, 2019 :
    will try to save everything. WhatsApp chats etc. factory reset isn't soooo painful. not sure why you need to do it, but that said, I recently did it. you could also wait. but if you are on Beta then you will one day have to change to stable. because if you are on Beta, you won't receive the full stable update. my advice it that if you aren't comfortable messing around with this, stick on the stable software. Pie, the previous software, is perfectly fine.
    Caomhin likes this.
  3. hugocorreia78
    Gingerbread Dec 4, 2019
  4. Kedarnath65
    Froyo Dec 4, 2019
  5. ironass
    Lollipop Dec 4, 2019
    ironass , Dec 4, 2019 :
    BUMMER! :eek:
    Bad news for those on Open Beta 2
    The new official OxygenOS update, 10.0.1, has a build date of... 191114
    This is an earlier build date than Open Beta 2... 191120
    I have a feeling that this could cause issues for anyone wishing to switch from Open Beta 2 to OxygenOS 10.0.1
    Looks like it could be a full wipe job with either roll-back firmware or the MSMDownloadTool for the...
    OnePlus 6T MSMDownloadTool
    OnePlus 6 MSMDownloadTool
    Luckily, all our Open Beta testers are competent and experienced users. :rolleyes:
  6. B_Wrath
    Marshmallow Dec 4, 2019
    B_Wrath , Dec 4, 2019 :
    This below post is the reason. The beta will mostly be a newer build than the stable. Hence, going back to stable from beta will require you to use the rollback package, which in itself constitutes a data wipe.
  7. kmaier
    words of wisdom
  8. Tinu Joseph
    Eclair Dec 4, 2019
  9. Kedarnath65
    Froyo Dec 4, 2019
    Kedarnath65 , via OnePlus 6T , Dec 4, 2019 :
    yaa one is from OnePlus and one is of google,u see downloads app in Android 9, that's the new files app in Android 10,and file manager is from OnePlus.
  10. Tinu Joseph
    Eclair Dec 4, 2019
    Tinu Joseph , via OnePlus 6T , Dec 4, 2019 :
    Kedarnath65
    yaa one is from OnePlus and one is of google,u see downloads app in Android 9, that's the new files app in Android 10,and file manager is from OnePlus.​
    Thanks mate
    there is another small bug,
    if any fix let me know.
    No vibration when unlocking the screen with fingerprint.
    let me know any fix
    Kedarnath65 and Kazliux like this.
  11. _BlackPanther_
    _BlackPanther_ , Dec 4, 2019 :
    someone said to use Germany, or you could use oxygen updater.
    saikat.panja18 likes this.
  12. E1528389282093
    Froyo Dec 4, 2019
  13. shijopj2014
  14. B_Wrath
    It is released! People are using it.
    Caomhin, _BlackPanther_ and Kytharsis like this.
  15. ironass
    This build has only been out for 6 hours and you are asking about battery life!!! :rolleyes:
    Come back in 3 or 4 days and ask.
  16. F_張東尼_DtSX
    shijopj2014 likes this.
  17. shijopj2014
  18. shijopj2014
  19. Asfiul
    Donut Dec 4, 2019
    Asfiul , via OnePlus 6T , Dec 4, 2019 :
    how i can know my mobile is a T-mobile version?
