1333
OxygenOS 10.0 for the OnePlus 6 and 6T
  1. klosz007
    Donut Dec 27, 2019
    klosz007 , Dec 27, 2019 :
    I got the upgrade to 10.3 yesterday. After upgrade, I can no longer connect to any WiFi network !!!
    They are all visible (signal strength etc.) but when I try to connect to any of them, nothing happens. If I delete the previously saved network and try to connect to it, then I'm asked for password (correct) and again nothing happens. Password isn't saved because if I try to connect to the same network again, I'm asked for the password again.
    Oooh, I know what had happened. WiFi MAC address in Phone information has changed to something else (I have MAC-address base security configured on my APs). Previously it was similar to BT's MAC address, now completely different.
    Moreover the MAC address that phone actually uses when connecting to AP is different than this one displayed in Phone Information and is different for 2,4 and 5GHz radios !
  2. K1544404401535
    Cupcake Dec 27, 2019
  3. olbatar
    Gingerbread Dec 27, 2019
    olbatar , Dec 27, 2019 :
    I still get bugs with print sensor on the last update 10.3 any fix planned for resolve it???
  4. klosz007
    Donut Dec 27, 2019
    Resolved ! This is new 'security feature' in Android 10.
  5. subhadeep chakraborty12
    Cupcake Dec 28, 2019
  6. W1572851326558
  7. rajkamalhm
    Cupcake Dec 30, 2019
    rajkamalhm , Dec 30, 2019 :
    Lens is still available in the camera. Long tap/press the screen in camera app to trigger google lens.
    Artemus. likes this.
  8. p51d007 and Artemus. like this.
  9. p51d007 and Artemus. like this.
  10. ironass
    Lollipop Dec 31, 2019
    ironass , Dec 31, 2019 :
    DOWNGRADE FROM ANDROID 10 TO ANDROID 9
    You will need to use the roll-back firmware which will wipe your phone and downgrade you to Android 9.
    See downloads and instructions for both OnePlus 6 & 6T, rollback firmwares...
    [GUIDE] Rollback/downgrade from OOS Android 10/Q to stable 9/Pie
    You can then download the the latest Android 9 stock Oxygen OS from here to upgrade to the most recent Android 9 release for the 6 & 6T by using Local Upgrade on the phone.
    (The above links DO work. If you cannot open them using the OnePlus Community app, switch to your Google Chrome browser)
    Artemus. and drl431 like this.
  11. ironass
    Download and install the official OnePlus OxygenOS firmware for your model of phone by using the instructions in this link... https://www.oneplus.com/uk/support/softwareupgrade
    Does not wipe your phone if you are upgrading from Android 9 to 10.
    (The above link DOES work. If you cannot open it using the OnePlus Community app, switch to your Google Chrome browser)
  12. M1577834288012
    Cupcake Jan 1, 2020
    M1577834288012 , Jan 1, 2020 :
    I have a problem with emojis. After updating my phone, all of emojis have disappeared. What should I do???When it will be the next update or the solution of this issue???I hope this will be resolved very soon.
  13. M1577834288012
    Cupcake Jan 1, 2020
  14. M1577834288012
    Cupcake Jan 1, 2020
  15. M1577834288012
    Cupcake Jan 1, 2020
  16. PatrickNL
    Gingerbread Jan 1, 2020
    PatrickNL , via OnePlus 6 , Jan 1, 2020 :
    sorry but I can't help you with you're problem. you could try to clear the cache.
  17. W1572851326558
    Cupcake Jan 2, 2020
  18. Ritesh sardar
    Cupcake Jan 4, 2020
    yogesh5727 likes this.
  19. Artemus.
    Nougat Jan 4, 2020
    Artemus. , Jan 4, 2020 :
    Old news.
