1334
OxygenOS 10.0 for the OnePlus 6 and 6T
  1. Krupesh3009
    Froyo Apr 3, 2020
    Krupesh3009 , Apr 3, 2020 :
    one more problem found and they says it's ur phone 🤣
    j.bahrudeen likes this.
  2. j.bahrudeen
    Gingerbread Apr 4, 2020
    j.bahrudeen , via OnePlus 7T Glacier Blue , Apr 4, 2020 :
    restart your mobile, use deep clear options,
  3. S117
    Donut Apr 4, 2020
    S117 , via OnePlus 6T , Apr 4, 2020 :
    Bonjour, j'utilise Android 10 sur mon OnePlus 6t. Vous pouvez le mettre à jour de 2 façons.1 mise à jour via la mise à jour logicielle via la mise à jour automatique du téléphone dans le paramètre. 2 Accédez au site Web OnePlus et téléchargez la dernière version de mise à jour logicielle.
    Désolé, j'utilise Google translate, alors pardonnez-moi si j'ai l'air bizarre.
  4. ravisoren007 , via OnePlus 6T Mirror Black , Apr 8, 2020 :
    Try to clean cache from boot loader then reset your battery 100% atleast 3 times, then you'll notice the difference.
    Too much on application on device can lead excessive battery consumption. So keep necessary application only which you need on daily basis.
    Stay Safe.
    V1539240502310 likes this.
  5. PRINCENIKKIb
    Donut Apr 9, 2020
    Hemangb2 and j.bahrudeen like this.
  6. Satyaranjan Das
    Eclair Apr 9, 2020
    Satyaranjan Das , Apr 9, 2020 :
    New update is really awesome...phone is working smoothly....
  7. PRINCENIKKIb
    Donut Apr 9, 2020
  8. Rohitashv
    Donut Apr 10, 2020
    Rohitashv , via OnePlus 6 , Apr 10, 2020 :
    where will i found boot loader
  9. Artemus.
    Community Hero 2020 Apr 10, 2020
    Artemus. , Apr 10, 2020 :
    If you have to ask, don't bother trying. There's no /cache partition anymore, this does absolutely nothing.
    Mike_Jiang, MCunha and drl431 like this.
  10. Kiran Pulicheri
    Eclair Apr 11, 2020
    Kiran Pulicheri , via OnePlus 6T , Apr 11, 2020 :
    Power off > hold volume down + power button even after the logo shows up until boot loader comes up.
    Enter phone password, select language > wow cache and reboot the device
  11. ronaksworld
    Jelly Bean Apr 12, 2020
    ronaksworld , Apr 12, 2020 :
    Power Off your device
    Then wait few seconds
    Then Press Power and Volume Down button
    Now your Phone is in recovery mode, select English language
    Then click Wipe data and cache, and in there simply click on wipe cache only.
  12. nagurukhader
    Cupcake Apr 14, 2020
    madhav888sheth@g likes this.
  13. j.bahrudeen
    Gingerbread Apr 14, 2020
    ParsleyUA likes this.
  14. nagurukhader
    nagurukhader , Apr 14, 2020 :
    I'm using dash charger and I tried that method still facing it, I'm facing this after the February updated it has to software problem
  15. rohit4577
    Gingerbread Apr 15, 2020
    rohit4577 , via OnePlus 6 , Apr 15, 2020 :
    u need to calibrate your battery ... use ur phone till battery died and charge again to 100% and repeat this 2-3 times , then it will re-calibrate. and do one more thing restart your phone and while booting keep pressing volume down key and then wipe cache , then reboot.
  16. Artemus.
    Community Hero 2020 Apr 15, 2020
    Artemus. , Apr 15, 2020 :
    What's the problem you're having? It dropping to 95% within a few minutes? That's completely normal.
  17. j.bahrudeen
    j.bahrudeen , via OnePlus 7T Glacier Blue , Apr 15, 2020 :
    don't update via oxygen update app, wait for official updates from OnePlus.
    yogesh5727 likes this.
  18. Artemus.
    Nothing wrong with Oxygen Updater, it's the exact same ROM. Plus, why are you bumping this thread?
    MCunha likes this.
  19. TMEL
    Cupcake Apr 16, 2020
    TMEL , via OnePlus 6T , Apr 16, 2020 :
    I don't know if this has something to do with it, but since I installed to Android 10 via oxygen updater I couldn't use the Google pay App and I still don't find a way to fix it. I have already installed to oxygenOS 10.3.2 from OnePlus, I haven't used oxygen updater since I installed it Android 10, but I still cannot use Google pay
