1372
OxygenOS 10.0 for the OnePlus 7 Pro and OnePlus 7
  1. Pa One
    Donut Sep 22, 2019
    Pa One , Sep 22, 2019 :
    This is insane, Can anyone tell me why most of the OnePlus 7 device didn't get OxygenOS 10.0 update yet?
    Common you guys i can't do anything except checking for updates frequently from the time I saw this post.(op7 user)
  2. C1562653676935
    Cupcake Sep 22, 2019
  3. Swejuggalo
    OnePlus 9 Series Expert Community Expert Sep 22, 2019
    Swejuggalo , Sep 22, 2019 :
    AA is the correct one for Indian device. However 10 AA for 7 Pro does not seem to be out yet.
    siddartha. ps likes this.
  4. T1560354475008
    T1560354475008 , Sep 22, 2019 :
    My camera only record 1080p video at wide angle. Can somebody help me to record higher settings such as 1080p 60fps or even 4k. Im using oneplus 7 pro. Thanks
  5. Obstinate
    Froyo Sep 22, 2019
    Obstinate , Sep 22, 2019 :
    I got the notification directly, have not done any kind of vpn or anything
  6. aknashwin
    aknashwin , Sep 22, 2019 :
    The OOS 10.0 update is a "staged" update. Which means, it rolls out in stages. Some users get it first, and then the next lot and so on. I think it's safe to say all OP7Pro and OP7 users will get it within this month.
    Pa One likes this.
  7. siddartha.ps
    Froyo Sep 22, 2019
    siddartha.ps , Sep 22, 2019 :
    Hope so and that needs to be corrected if it's a listing issue.
    abhilash_saikia likes this.
  8. AJMERAKARTHIKEY
    Froyo Sep 22, 2019
  9. aknashwin
    It's better not to use any third party applications for the update. If you choose to do so, do it carefully!
  10. shoaibkhan996
    Gingerbread Sep 22, 2019
  11. AJMERAKARTHIKEY
    Froyo Sep 22, 2019
  12. aknashwin
    The update has started rolling out to some devices. I think it's safe to say you'll get the update within the end of this month
  13. SmilliePhotography
    Eclair Sep 22, 2019
    G_ayush_madan_YhBr likes this.
  14. AJMERAKARTHIKEY
    Froyo Sep 22, 2019
  15. com5585
    com5585 , Sep 22, 2019 :
    What is this nonsense? Why can not you do everything in one color scheme ???? Awful ....
  16. P1569140787404
    P1569140787404 , Sep 22, 2019 :
    same issue with my oneplus 7pro. plz solve this asap.
    thanks.
  17. shoaibkhan996
  18. Pa One
    Donut Sep 22, 2019
    P1569140787404
    thanks.​
    I had the same issue, but it is solved once I moved to beta 2
  19. Staf Heymans
  20. Swejuggalo
    It's by choice by Oneplus. Some say it had 60fps in OB1 but I'm not sure. Only 30fps in OB2 and apperently in stable too.
    Don't think other lenses than main lens support 4k.
