1353
OxygenOS 10.0 for the OnePlus 7 Pro and OnePlus 7
  1. fahirrulez
    Cupcake Sep 22, 2019
    fahirrulez , Sep 22, 2019 :
    Am using Tmobile OnePlus 7pro converted to International version and using it in India. Got update in OTA system update just now. Downloading now to enjoy the new flavour of Oxygen OS. Thanks OnePlus team.
    N1567409977459 likes this.
  2. zafs28
    zafs28 , Sep 22, 2019 :
    in Android 10 did OnePlus update the World Clock timing of Saudi Arabia in OnePlus 7
  3. U1551111791215
    V3X11 likes this.
  4. S Asheerwad
  5. F1536011049830
    Eclair Sep 22, 2019
    F1536011049830 , Sep 22, 2019 :
    seems that you got the AA international version instead of BA which is the EU version.
  6. zafs28
  7. Moeen2692
    Gingerbread Sep 22, 2019
    Moeen2692 , Sep 22, 2019 :
    Yep that is right. Need to get back to the eu version now
  8. B1558325828008
  9. Swejuggalo
    KitKat Sep 22, 2019
    Swejuggalo , Sep 22, 2019 :
    I'm gm1913. If I wanted stable I would have downloaded the EU version with Oxygen Updater.
    I also collected the files in a post.
    Links to stable update to 10 http://bit.ly/2Ns6Zmr
  10. F_Chis_Vasile_Toader_eGB
    Eclair Sep 22, 2019
    F_Chis_Vasile_Toader_eGB , Sep 22, 2019 :
    Very buggy apdate
    1.Gesture
    2.Screen not full screen in some apps
    3.When i write the keyboard is not full screen ,from the ege of the screen down, i have 1-1.5 cm up from scren
    4.Opera browsoer did't work very good
    5. Wifi problem
    Bad apdate until now , i most stay with this apdate for the apps, hurry up to rezolve all bugs.Thanks
    V1rTu likes this.
  11. poplectic
    Eclair Sep 22, 2019
    poplectic , Sep 22, 2019 :
    I'm finding battery much better on OP 7 Pro than on OB2 so I'm not sure The Stable is just OB2 renamed as some are claiming
  12. Swejuggalo
    KitKat Sep 22, 2019
    Download the EU 10 version and flash over rolled back version.
  13. H1560273497846
  14. ARJUN MOHAN
    Froyo Sep 22, 2019
  15. sushanth_goud
    Froyo Sep 22, 2019
    sushanth_goud , Sep 22, 2019 :
    there won't be any major problem but suggest you to wait until u get the update on your device
  16. Melkuse Daniel
  17. sushanth_goud
    Froyo Sep 22, 2019
    No major differences but sometimes some minor differences will be there for updates from another region
  18. Pa1KumarM
    Froyo Sep 22, 2019
    Pa1KumarM , Sep 22, 2019 :
    If you ever feel useless think about Digital Wellbeing in Android 10...[e]1f440[/e]
  19. Linkin1994
    Donut Sep 22, 2019
    Linkin1994 , Sep 22, 2019 :
    You know When new android arrive you can try Wipe cache or FR If you have a bugs
  20. Moeen2692
    Thank you. Will get this flashed. Shouldn't wipe again right?
