1372
OxygenOS 10.0 for the OnePlus 7 Pro and OnePlus 7
  1. Deactivated User
    Sep 22, 2019
  2. DreamsVish
    Donut Sep 22, 2019
    mbcool likes this.
  3. UnicornZ
    Ice Cream Sandwich Sep 22, 2019
    UnicornZ , Sep 22, 2019 :
    If any using RSA token and depends on that app for work related, kindly don't update to android 10. There is an issue with RSA app and its not allowing to open the app with android 10
  4. pratzzz
    Froyo Sep 22, 2019
    pratzzz , Sep 22, 2019 :
    You probably won't get update as you are on beta os not stable one.Please roll back to pie and be on the stable build you will surely get it. As long as you are on beta,you will only get beta OTA
  5. ranaharishdev
    Eclair Sep 22, 2019
  6. ranaharishdev
    Eclair Sep 22, 2019
  7. Swejuggalo
    OnePlus 9 Series Expert Community Expert Sep 22, 2019
    Swejuggalo , Sep 22, 2019 :
    It's a rollout in stages as normal. It's possible to update manually in several ways. Manually download it by these links is one way.
    Links to stable update to 10 http://bit.ly/2Ns6Zmr
  8. senthilaca
    Cupcake Sep 22, 2019
    senthilaca , Sep 22, 2019 :
    Thanks for the reply.. any link to downgrade from beta 2? Does it require full wipe including internal storage?
  9. senthilaca
    fullwipe including internal storage? will lose data in gallery?
  10. parv1795
    Eclair Sep 22, 2019
    mbcool likes this.
  11. Swejuggalo
    Wipe. Rollback and full updates here
  12. Oneplus suman
    Gingerbread Sep 22, 2019
    Fmps1987 and I1562646540694 like this.
  13. pratzzz
    Froyo Sep 22, 2019
  14. MaxPdK
    MaxPdK , Sep 22, 2019 :
    Can I update from Open Beta 2 ? when I with the OP Updater App it says that the upgrade will restore Factory m settings. Does It mean losing all data also ?
    thanks !
  15. mjai.mk
    Froyo Sep 22, 2019
    mjai.mk , Sep 22, 2019 :
    Got the update on GM1911. Ringtones has a bug, it's playing a dull beeping sound no matter which inbuilt ringtone you choose. hope this gets addressed
  16. O1561658854381
  17. I1565805057690
    I1565805057690 , Sep 22, 2019 :
    i don't want download any file or something I wanted to download directly in my mobile how can I do it
  18. elanglois
    Lollipop Sep 22, 2019
    elanglois , Sep 22, 2019 :
    Well, the Atmos controls finally work in Q. Google Assistant still doesn't listen like it should, but swiping up from a corner (the old "Back") works fine.
    Rooted users beware that full-screen gestures with 3rd party launchers (Quickstep w/ Lawnchair or Nova, etc) is broken. Swift Installer doesn't support Android 10 on OOS *yet*
    Other than losing some customization, it seems ok
  19. pratzzz
    Froyo Sep 22, 2019
    senthilaca
    Thanks for the reply.. any link to downgrade from beta 2? Does it require full wipe including internal storage?​
    Here you go http://bit.ly/2Ns6Zm
    Just check the last two download files and as per respective device you have to just download and place in the internal storage and flash it but before doing anything just take a BACKUP as it will completely erase everything on the device.
  20. DreamsVish
    Donut Sep 22, 2019
    DreamsVish , Sep 22, 2019 :
    Just tired PUBG ... working perfectly.
