1371
OxygenOS 10.0 for the OnePlus 7 Pro and OnePlus 7
  1. Tejas_Winnie
    Cupcake Sep 22, 2019
    Tejas_Winnie , Sep 22, 2019 :
    I'd suggest WiFi..
  2. saadh.samsudeen
    Froyo Sep 22, 2019
  3. Tedinetto
    Gingerbread Sep 22, 2019
  4. R1569155998665
  5. Swejuggalo
    OnePlus 9 Series Expert Community Expert Sep 22, 2019
    Swejuggalo , Sep 22, 2019 :
    Didn't realize it had buttons. I'm a Oneplus noob [e]1f609[/e]
  6. ddhbanger
    Honeycomb Sep 22, 2019
    L1569154888140 likes this.
  7. Hamzanehvi111
  8. Poetstylez
    Poetstylez , Sep 22, 2019 :
    it ends . zip.jar so, just remove the jar? I didn't have to do that when I downloaded the Beta... that's weird, it's that normal?
  9. Rajan06
    Rajan06 , Sep 22, 2019 :
    can we toogle the internet while updating the OS.
    I am using internet with 2 GB per day so I don't think that I am able to update all at once.
    what if I change the Carrier or to WiFi networks while updating the OS. can this have any affect or problem while downloading?
  10. Shebin98
    Donut Sep 22, 2019
    Shebin98 , Sep 22, 2019 :
    Okay so for me after updating I feel there are some bugs.
    1. The keyboard moved a bit up n the bottom part is.. Well unresponsive. Just a black area.(Below the blue line.)
    2. Whenever I do the back gesture(old swipe up from the right bottom thingy) I can see a blackish transparent dot on the screen that comes n goes right whenever I do that n disappears when the back operation is completed.
  11. awes0me1
    awes0me1 , Sep 22, 2019 :
    Force Dark still broken but all in all, very good, I would recommend a full wipe as it was a lttle buggy before I did a full wipe but no issues at all.
  12. Abhishek_goswami18
    Eclair Sep 22, 2019
    Abhishek_goswami18 , Sep 22, 2019 :
    why there is two option?
    files and file manager??
    and why have you given google pay option too..as dat isnt available in india then also??
    geeting lil confused by this new update
    Shebin98 likes this.
  13. RainGater
    RainGater , Sep 22, 2019 :
    Okay guys, I was on Beta 2 (OnePlus 7) and moved to 10 stable. Please NOTE that it will WIPE your phone. I wanted to start fresh, so no problem for me although I wasted close to 2 hours to configure everything. Worth it, IMHO!
    1. Download the file from https://piunikaweb.com/2019/09/21/oneplus-7-7-pro-oxygenos-10-0-android-10-stable-update/.
    2. Do a local upgrade (Settings - System - System Updates) and it will install and wipe the phone.
    I you are on Beta 2, there is NO need to rollback to PIE to go to 10 stable!
    Even though I can use OnePlus Switch to backup and restore, it ONLY restores the apps and NOT the data. If it restores data, then it's worth it but it doesn't! So, I started fresh and installed everything from Play Store.
    ABala likes this.
  14. Imbaliciouz
    Donut Sep 22, 2019
  15. Swejuggalo
    Verify the filenames if you like
    Links to stable update to 10 http://bit.ly/2Ns6Zmr
  16. guardianzpride
  17. Sidharth Singh Bhati
  18. alishan212
    alishan212 , Sep 22, 2019 :
    [e]1f602[/e][e]1f602[/e][e]1f602[/e][e]1f602[/e]
    on point.
    People, chill out. Wait patiently for the update. There's no rush. I'm sure we all have far more productive things to do in life than just bog down the community for update timelines.
    karthikkb likes this.
  19. Swejuggalo
    Rollback unless you can dirty flash in custom recovery
  20. jagdish servi
    jagdish servi , Sep 22, 2019 :
    after updating locally does anybody have Google pay and files app been installed by default or it is just me???
