1348
OxygenOS 10.0 for the OnePlus 7 Pro and OnePlus 7
  1. akks
    Jelly Bean Sep 22, 2019
    akks , Sep 22, 2019 :
    No issues here. OnePlus 7 pro India
  2. G_hao_jiandong_NYTR
    Cupcake Sep 22, 2019
  3. bhavinder001
    Gingerbread Sep 22, 2019
  4. gizmo91_
    Eclair Sep 22, 2019
  5. Pierre02
  6. docbabloo
    docbabloo , Sep 22, 2019 :
    I used the Oxygen updater and downloaded the update that was available. Everything is working A OK ;)
  7. Swejuggalo
    KitKat Sep 22, 2019
    Swejuggalo , Sep 22, 2019 :
    Have not tested that. However you could download elsewhere and store on a USB drive to copy the file to root directory and do a local update.
    Links to stable update to 10 http://bit.ly/2Ns6Zmr
    Rajan06 likes this.
  8. Rajan06
    Froyo Sep 22, 2019
    Rajan06 , Sep 22, 2019 :
    I would like to go with local update
  9. Izem
    Donut Sep 22, 2019
    Izem , Sep 22, 2019 :
    it's not that you don't have it, for you it's just that the bar is black
    also in dark mode not everything is dark
    check my screenshot
    Shebin98 likes this.
  10. Rajan06
    Froyo Sep 22, 2019
    hmm we are also waiting for that
  11. VaibhavBhargava
    Lollipop Sep 22, 2019
    VaibhavBhargava , Sep 22, 2019 :
    So apart from what Funk Wizard said, there is also a possibility that the build is a bad release, i.e. it requires a hot fix release.
    This has happened with OnePlus in the past. When OnePlus released the stable (without fixing) Oreo (from Nougat) for OP3/3T devices even though issues existed in the open beta.
  12. F_Chis_Vasile_Toader_eGB
    Eclair Sep 22, 2019
  13. VaibhavBhargava
    No issues should be there.
    Rajan06 likes this.
  14. Karl_Columna
    Froyo Sep 22, 2019
    Karl_Columna , Sep 22, 2019 :
    horizon light not working. this is like renaming beta to stable just to release and be known to be the first to release after pixel. hopefully a new update is coming soon. i miss the horizon light already.
    acheney1990 likes this.
  15. Swejuggalo
    KitKat Sep 22, 2019
    Oneplus and normal android 10 file manager. I assume them might disable one of them later on... Or you can disable or hide the one you don't want.
    The Indian firmware shares firmware with basically every country other than EU countries. So instead of doing more special localized firmwares this is a side effect
  16. Imbaliciouz
    Donut Sep 22, 2019
    Imbaliciouz , Sep 22, 2019 :
    thanks!
  17. Pavithran987
  18. tipu006
    Eclair Sep 22, 2019
  19. sukamaldas
    Froyo Sep 22, 2019
    sukamaldas , Sep 22, 2019 :
    it is forum.. if have to see your message i can give my opinion.. and will again repeat understand what does open, community and stable builds means..
  20. Prithiviraj9696
    Prithiviraj9696 , Sep 22, 2019 :
    Thanks for the update... features are awesome.A great improvement in camera department.
    congratulations for one plus 7T launch
