1348
OxygenOS 10.0 for the OnePlus 7 Pro and OnePlus 7
  1. poplectic
    Eclair Sep 22, 2019
    poplectic , Sep 22, 2019 :
    People need to stop whining about inconsistencies in the UI and in apps that have arisen because they enabled force dark in developer options. Those kind of people should stay out of developer options. And stop describing those inconsistencies as bugs!
    Pawcio62432 likes this.
  2. R1569158095882
    Cupcake Sep 22, 2019
    R1569158095882 , Sep 22, 2019 :
    did you feel any trouble after the update
  3. aswinbarathb
    aswinbarathb , Sep 22, 2019 :
    same problem. didn't know it was a problem until I saw this comment. so please do give us a fix for this!
  4. Kironraj
    Donut Sep 22, 2019
    Kironraj , Sep 22, 2019 :
    Issue After Update.
    Cant select notification sounds for ringtone as well as msgs. anyone facing this issue. !?
  5. MelvinAbes
    Gingerbread Sep 22, 2019
    MelvinAbes , Sep 22, 2019 :
    Just got the update on my OnePlus 7 pro, Indian Retail unit.
    This android 10 update from OnePlus seems half baked and totally uninspired from OnePlus's side.
    Before I explain here are some info:
    Device : OnePlus 7 Pro
    Country : India
    Update method : Official OTA
    Issues I've found till now:
    1) Black bar under whatsapp and YouTube, This bar seems permanent and changing the phone to a light theme doesn't help either (I've attached a screenshot of what I mean)
    2) When the notification shade is pulled down, The rest of the display contents fade, Looks very Xiaomi MIUI. And does not look stock. (Screenshot provided)
    3) The raging dark mode inconsistencies, The notification shade is Grey while the notifications themselves are pitch black. Feels very inconsistent. Stock android 10 provides pitch black throughout the notification system, Why does OnePlus have to fiddle with that awesome implementation by Google?
    This update seems rushed in some way. Usually OnePlus has multiple open betas before releasing a stable update. But this time they only pushed out 2 open betas and the problems noticed by other open beta users were not even fixed in the stable build. I feel this rushed update of oneplus has something to do with their launch of the 7T series.
    PS : I was only able to pick up the visual changes as of now since I just installed the update. Will update this thread if any other bugs are found.
    Arun Rathnakumar likes this.
  6. Thatsmeetshah
    Eclair Sep 22, 2019
    Thatsmeetshah , Sep 22, 2019 :
    Why would you not provide Super Steady mode in Video to OnePlus7, the regular one!? Both have same cameras.
  7. Its.Leandroo
    The Lab - OnePlus 6 Reviewer Sep 22, 2019
    Its.Leandroo , Sep 22, 2019 :
    It is safe.
  8. Nitya_Shah
  9. akks
    Jelly Bean Sep 22, 2019
    akks , Sep 22, 2019 :
    Yes
    Rocking Android 10..
    Super awesome till now. Like the new gesture and dark mode everywhere.
    Didn't experience any of the bugs mentioned here till now.
    Shalin235 likes this.
  10. Izem
    Donut Sep 22, 2019
    Izem , Sep 22, 2019 :
    it can be designed by apple > I don't care
    I want to have an option which allows me to deactivate it if I don't like it
  11. Izem
    Donut Sep 22, 2019
    akks
    Yes
    Didn't experience any of the bugs mentioned here till now.​
    dark mode everywhere?
    do you have a real black notification panel?
    mine is dark grey
    H1560273497846 likes this.
  12. Yifeeikeh
  13. sukamaldas
    Froyo Sep 22, 2019
    sukamaldas , Sep 22, 2019 :
    hardly been an hour but i can see some glitches or bugs..
    1. Inconsistent dark theme. Some places you will find grey instead of black or some places worse white.
    2. Two google pays (Probably specific to India)
    3. Two file manager apps.
    4 applications using fingerprint authentication. many times even after logging in to the app finger print light stayed on. ( happened to me while using ActionDash).
    Rest everything has been pretty good so far.
  14. Swejuggalo
    KitKat Sep 22, 2019
    Swejuggalo , Sep 22, 2019 :
    Yes exactly. They have a staged rollout for good reasons. I would have delayed the stable version to at a later point myself.... But then again. Links is equally bad as Oxygen Updater. Using normal OTA and something gets messed up and it's a Oneplus issue. Downloading files yourself and you get issues... Then the blame can be on yourself.
    Oneplus can of obvious reasons not recommend tools like Oxygen Updater. But they should not promote direct download links either if you are picky.. Mistakes can happen and suddenly you got BA and a AA device and so on...
    No matter what methods you use to update. It does not hurt to think twice [e]263a[/e]️
  15. ktramit
    ktramit , Sep 22, 2019 :
    no i am not getting any issues ..i am just curious about what is BA and AA?
  16. Prabal_titanium27
    Froyo Sep 22, 2019
    Prabal_titanium27 , Sep 22, 2019 :
    Horizon Lights working fine? And what about black screen issue with games?
  17. R1569158095882
    ok bro then am going to update my phone thanks for your support
  18. Rameshanan
    Rameshanan , Sep 22, 2019 :
    Hello, I Upgraded to android 10 just today and i am finding a very troublesome issue which i am facing.
    The Issue:
    If i try to run PUBG Mobile on my phone the screen turns off automatically, but the background runs perfectly fine like, taking screenshot and charging, screen lock sounds but its just the display which is not working. I need to hard reset my phone all the time when this happens. I think this issue is related with the Fnatic Mode. I hope this issue get resolved quickly..
    Thank you
  19. Sheeng12
    Donut Sep 22, 2019
    Sheeng12 , Sep 22, 2019 :
    Did You use a VPN?
    Are in what region your in???
  20. Swejuggalo
    KitKat Sep 22, 2019
    Thatsmeetshah
    Why would you not provide Super Steady mode in Video to OnePlus7, the regular one!? Both have same cameras.​
    It uses the wide angle lens
    acheney1990 likes this.
