1323
OxygenOS 10.0 for the OnePlus 7 Pro and OnePlus 7
  1. MarkoBatrac
    Honeycomb Sep 22, 2019
    MarkoBatrac , Sep 22, 2019 :
    yes, you will have both ..stable and beta..what you want, depends on you
  2. KirkyWirky
    Cupcake Sep 22, 2019
    KirkyWirky , Sep 22, 2019 :
    I flashed the BA (EU) zip.. can I simply (and safely) flash the AA (Global) zip over it?
    is there any advantage flashing AA over BA anyway?
  3. faizarsyadw
    Gingerbread Sep 22, 2019
  4. F1569160577583
    F1569160577583 , Sep 22, 2019 :
    hello sir. I'm using oneplus 7pro. Just updated to latest software android 10. The only think i encounter when i launch any game my screen turn blank and need to force restart. Formatted my phone. Still encounter this problem. Any help or advice?
  5. BrokenMel
  6. acheney1990
    Eclair Sep 22, 2019
    acheney1990 , Sep 22, 2019 :
    Ok. Thanks. So OnePlus will still keep releasing beta updates? Are there any changes between current Beta 2 and Stable?
  7. MarkoBatrac
    check post #2397
  8. ahwan313
  9. Arnob1992
    Arnob1992 , Sep 22, 2019 :
    After updating to android 10 (One plus 7pro) my horizon light stopped working though my notification light ambient display smart display all are toggled in. When there is a new notification it just making sound or vibrate but no horizon light. Could anyone help me with this.
    sandeep9.narla likes this.
  10. sambashivareddy
    Eclair Sep 22, 2019
    sambashivareddy , Sep 22, 2019 :
    they will announce in the forum. stay tuned
  11. ahwan313
    ahwan313 , Sep 22, 2019 :
    yes...
  12. MarkoBatrac
    acheney1990 likes this.
  13. Eduardo77
    Eclair Sep 22, 2019
    Eduardo77 , Sep 22, 2019 :
    So I got a OP7 EU, no official update still..how long do you guys think it can take, worst case scenario? 1 week?
  14. faizarsyadw
    MarkoBatrac likes this.
  15. MarkoBatrac
    less than 1 week I think. but you can flash it now if you want, there are link with build
  16. acheney1990
    Eclair Sep 22, 2019
  17. Head_Hunter
    Froyo Sep 22, 2019
    Head_Hunter , Sep 22, 2019 :
    Its like I am still using a beta versions, full of bugs
  18. G_mohammad_sharafi_qMRT
    Froyo Sep 22, 2019
    G_mohammad_sharafi_qMRT , Sep 22, 2019 :
    hello everyone I'm AA build should i update through oxygen updater or wait for system update to pop on and lastly isbit good and stable update to update to!?
  19. unExplodeX
    Eclair Sep 22, 2019
    unExplodeX , Sep 22, 2019 :
    Quick question do i have to do factory reset before install of the Android 10? or is it ok to update from oxygen updater without factory reset?
  20. Swejuggalo
    KitKat Sep 22, 2019
    Swejuggalo , Sep 22, 2019 :
    Great. Should not be a an issue using full update on beta 2 then besides the wipe that is.
    docnok63 likes this.
