1369
OxygenOS 10.0 for the OnePlus 7 Pro and OnePlus 7
  1. sarahmic
    Honeycomb Sep 22, 2019
    sarahmic , Sep 22, 2019 :
    I am on 9.5.11, so when i get Android 10 do i have to backup all my data before installing as it will be wiped out ?
  2. kanagaraj1010
    Ice Cream Sandwich Sep 22, 2019
    kanagaraj1010 , Sep 22, 2019 :
    performances are slow like hell even with 0.5 animation speed is feeling slow.
    more annoying is the idiot white bar underneath the keyboard! why????
    also the notification part in black mode is ugly as the top notification bar itself is not black!
    application launching is slow, with the last version it was the faster phone ever now I'm really disappointed
    Nemish gupta likes this.
  3. Wolexf
    Donut Sep 22, 2019
    Wolexf , Sep 22, 2019 :
    I have installed the update after downloading from the oxygen updater app. I didn't do factory reset. so far no complains everything is working fine.
    will post an update after 24 hours of use
    Debashish123 likes this.
  4. Debashish123
    Donut Sep 22, 2019
    Debashish123 , Sep 22, 2019 :
    So you mean India is getting 2 versions of Google pay with android 10 update??
  5. svntsvn
    Eclair Sep 22, 2019
    svntsvn , Sep 22, 2019 :
    thanks. currently on open beta 2, having issues with mobile data signal dropping, or when leaving wifi it's not picking up at all. (wipes, resets, remains an issue) definitely want to get the most specific region update I can.
    Hopefully it's fixed it's been an issue for past 2 OnePlus devices, 5t, 6t, until I got the 7 pro with latest pie.
  6. kanagaraj1010
  7. Debashish123
    Donut Sep 22, 2019
    No you won't have to... Your data will remain safe
  8. manojsurya99
    Jelly Bean Sep 22, 2019
    manojsurya99 , Sep 22, 2019 :
    Yes.
    And if you don't want to see two versions, you can disable the application.
    just long press the application in menu and click on App info. You'll get an option to disable the application.
  9. manojsurya99
    You can disable one application if you don't want. Tez is Indian version while GPay is NFC version of Google Pay.
  10. Debashish123
    Donut Sep 22, 2019
    Yes same for me... I guess it's the default feature of android 10... Google pay is inbuilt now.
  11. Swejuggalo
    Community Bug Hunter Sep 22, 2019
    Swejuggalo , Sep 22, 2019 :
    F2fs is still considered to be a pretty young and actively developed file system with some quirks and from what I understand issues with encryption (or atleast used to) ... Oneplus 3T did apperently use it but reverted to ext4 in 5.
    Maybe the filsystem improved over the years?
  12. CooperStation
    Donut Sep 22, 2019
    CooperStation , Sep 22, 2019 :
    What's the algorithm for the OTA rollout? Is it for some specific people/regions or is it just completely random?
  13. reach2ashish
    Eclair Sep 22, 2019
  14. P1563171176499
    Eclair Sep 22, 2019
    P1563171176499 , Sep 22, 2019 :
    why is the bottom bar covering the entire screen end to end and not just a floating bar?
    Also, the phone wide accent color doesn't apply to the camera app. Try changing the accent and then open the camera settings inside the app.
    tomjschwanke likes this.
  15. Sir_Pool_de_Float_MD
    Gingerbread Sep 22, 2019
    Sir_Pool_de_Float_MD , Sep 22, 2019 :
    My phone is still encrypted. Maybe there was an issue when OP was using it, but arter's kernel is solid for me.
    MDM formats and restores all partitions to stock. Stock recovery can only wipe the data partition, and although TWRP can format any partition, it is strongly discouraged with A/B devices as you can easily brick the phone.
  16. blomus
    Cupcake Sep 22, 2019
    blomus , Sep 22, 2019 :
    Will the open beta closed with this release or will the beta continue? I'm asking because I need to wipe the device to get off the beta train. If there will be more betas, I will not update my phone.
  17. manojsurya99
    Beta will continue.
    blomus likes this.
  18. Swejuggalo
    Stable version upgrades to newer stable versions without wipes. But if you get issues keep in mind that a factory reset can help sometimes.
  19. blomus
    Thanks! Then I will continue on this path.
  20. skyeking69
    Froyo Sep 22, 2019
    skyeking69 , Sep 22, 2019 :
    Backup question.... Will the data erase of the new stable version also wipe my OnePlus Switch backup of my beta 2 data??
