1371
OxygenOS 10.0 for the OnePlus 7 Pro and OnePlus 7
  1. Georgeoneplus7pro
    Jelly Bean Sep 22, 2019
    Georgeoneplus7pro , Sep 22, 2019 :
    You are right! It is true that they know the problems very well and do not care.
    elanglois likes this.
  2. ESavage648
    Donut Sep 22, 2019
  3. Georgeoneplus7pro
    It also depends on the software of the machine, it is not compatible with all. And on my Volvo(2017) works well, android auto.
  4. elanglois
    Lollipop Sep 22, 2019
    elanglois , Sep 22, 2019 :
    I will NOT factory reset. If I go to that much trouble, I'll load a custom ROM while I'm at it. That will likely fix my keyboard issue as well.
    Georgeoneplus7pro likes this.
  5. TheMysticalShaman
    Honeycomb Sep 22, 2019
    TheMysticalShaman , Sep 22, 2019 :
    Nova Launcher gestures work better than Android 10 gestures. Android 10 gesture for recent apps are too difficult. Nova launcer, I assigned recent apps to swipe up. Working great
  6. H1561960043803
    Ice Cream Sandwich Sep 22, 2019
    J1567647284934 likes this.
  7. H1561960043803
    docnok63 likes this.
  8. Masthanvali77
    Cupcake Sep 22, 2019
    Masthanvali77 , Sep 22, 2019 :
    perfect bro
  9. elanglois
    Always works fine for me. You start the swipe from off the screen.
  10. Andronk
    Eclair Sep 22, 2019
  11. elanglois
    Stop pressing on the bottom of the screen. For gestures, slide up. Start at the home button for pill nav. Start off the screen edge for full gesture nav
  12. elanglois
    What notch?
  13. TheMysticalShaman
    Basically, I can't do recent apps gestures with an app on screen. I have to Clear the app, then swipe for recent apps. With fixed navigation. I can go to recent apps when an app is open on the screen without having to go to the home screen
  14. Sigmanp320x
    Gingerbread Sep 22, 2019
    Sigmanp320x , Sep 22, 2019 :
    I did help him by giving him the proper direction on where to post his question /concern !
    the problem is folks going flash crazy update happy but don't know anything about proper procedures and such (even though there in the OP every time )
    I was not criticism @ him rather his inability to direct his issue in the appropriate thread. most moderators would delete those post anyhow and should clutters the thread with useless info
    H1561960043803 likes this.
  15. Andronk
    Eclair Sep 22, 2019
    Andronk , Sep 22, 2019 :
    The OnePlus 7 has a notch. Previously there was an option to hide it, but it seems not to be there any more (unless I'm being stupid and can't find it.)
  16. elanglois
    Since Q, or did it work on Pie? Only certain apps or any app on screen? Still using Oneplus launcher?
    For me its 100%. Slide from where the case sits up to the center and stop. Don't overthink it
  17. TheMysticalShaman
    I am trying to swipe now to recent apps. I see the bar moving. No recent apps. So from within an app, only home swipe and back work with gestures
  18. TheMysticalShaman
    From the home screen, the swipe to recent apps works fine. Within an app. Impossible to swipe up to recent apps
  19. Braveheart008
    Froyo Sep 22, 2019
    Braveheart008 , Sep 22, 2019 :
    Great job team! Finally the wait is over! Looking forward to receive the update soon...
    ***Never Settle***
    [e]270c[/e]️[e]1f44c[/e][e]1f60a[/e]
  20. JavieRozen
    Donut Sep 22, 2019
