1356
OxygenOS 10.0 for the OnePlus 7 Pro and OnePlus 7
  1. Korok Hidup
    Gingerbread Sep 23, 2019
    Korok Hidup , Sep 23, 2019 :
    Its there by design, so get used to it.
  2. Korok Hidup
    ikr
  3. G_sandip_kandu_tlYZ
    Eclair Sep 23, 2019
  4. DarioDM7
    Cupcake Sep 23, 2019
  5. Melkuse Daniel
    Honeycomb Sep 23, 2019
    Melkuse Daniel , Sep 23, 2019 :
    Bro if you keep the file in jar format it won't show in local upgrade, so rename it as .zip in the place of .jar, then it will show the file in local upgrade.
    make sure that you have backed up all of your data before you rollback.
  6. Tanayr15
    Froyo Sep 23, 2019
    Tanayr15 , Sep 23, 2019 :
    Battery is draining faster than android pie. Anyone else noticed this on Android 10 stable update?
    Rest everything seems to be working fine. But the battery is terrible
  7. Zavow
    Eclair Sep 23, 2019
    Zavow , Sep 23, 2019 :
    I don't understand why T mobile hasn't sent out any updates since July 1st. Does anyone else know or is on T mobile that has any idea why that is?
  8. Iamrohit.07
  9. elanglois
    Lollipop Sep 23, 2019
    elanglois , Sep 23, 2019 :
    Glacial Indifference from the paid version of Typeface. You will need a rooted device
  10. Iamrohit.07
    Iamrohit.07 , Sep 23, 2019 :
    thanks!!
  11. S1565429066144
    S1565429066144 , Sep 23, 2019 :
    hello I am using OnePlus 7 and I am observing that whenever I take a slow motion video in the artificial lighting condition the light in the video starts flickering,this is very annoying .is there any solution for this?
    please reply..
  12. amitav007
    Sanchitmeena and jasprjay like this.
  13. Antaroop
    Antaroop , Sep 23, 2019 :
    yes it worked thanks bro !!
  14. Y1560506970315
  15. venki__8__8__PS
  16. G_kushal_patil_TBoY
  17. Melkuse Daniel
  18. Pratheekh Chandra
  19. Tanayr15
    Froyo Sep 23, 2019
    I totally agree. Its weird. Unusual drain. I hope it gets fixed with further stable updates
  20. Zavow
    Eclair Sep 23, 2019
    elanglois
    Didn't I tell you not to argue? Did you understand ANYTHING I just said? Charging your phone to 100% does NOT hurt it. And when left plugged in and hibernating your phone will optimize your apps and garbage collect (fstrim) your filesystem. Google has DESIGNED the OS to optimize while plugged in. This only happens if your phone is fully charged, on AC power, and asleep.
    As I said, after an update, your phone is running in JIT mode which is slow and needs more CPU power. Until it optimizes you will not get the SOT times you are used to.
    So stop arguing and do as you are told, or at least STFU about battery life EVERY damn update. I'm tired of people bitching about the same thing every time. I tell you how to fix it, and you argue! You try to outthink the engineers that designed this stuff rather than just using it as intended. Then you complain when you get poor results!
    As for battery, I still have my original Oneplus One, and it gets great battery life.​
    Dude, why are you so angry? I thought the OnePlus community was here to help each other. Stop being so toxic and just be helpful. Using foul language doesn't get your point across any better either.
