1372
OxygenOS 10.0 for the OnePlus 7 Pro and OnePlus 7
  1. nunobjmj
    Eclair Sep 24, 2019
    Spettinero likes this.
  2. Gauravk93
    Gingerbread Sep 24, 2019
    Gauravk93 , Sep 24, 2019 :
    even i am facing such lagginess while scrolling
  3. kartishrakhunde
    Cupcake Sep 24, 2019
  4. G1546972425195
    G1546972425195 , Sep 24, 2019 :
    guys who got OTA to Android 10, please write it from which country are you? in Norway still nothing
  5. Yash Narain
    Yash Narain , Sep 24, 2019 :
    Going by the reviews on Android 10 , I think there are several bugs which need to be fixed...I personally think it's better to stay on Pie until there is another Hotfix update or something.
    mjdb71, Spettinero and rockinsnake like this.
  6. Abhay Gaikwad
    Froyo Sep 24, 2019
    Shalin235 and G1546972425195 like this.
  7. Gersh
    Eclair Sep 24, 2019
    Gersh , Sep 24, 2019 :
    Working good so far. Only about 5 hours in so far though.
    Downloaded through Oxygen Updater, backed up, used the local upgrade option. I did clear the cache after letting it sit for 10 min, and again, let it sit for a bit after the last reboot. Did not loose any data coming from OxygenOS 9.5.13.
    First impressions. Seems that the finger print sensor opens faster, and more consistently. Use to always take a few attempts, but now it just opens the first attempt. Also, haven’t had any failed attempts in my pocket since the update, so they must have added a pocket mode. Huge improvement there. Along with that, single tap to wake seems more consistent as well.
    Someone said they had choppy audio through Bluetooth, and I have had zero hiccups, using headphones for an hour straight. No connectivity issues with my Wear OS watch either.
    Had an issue with my Launcher for a bit but solved it. I’m Using the latest version of Lawnchair pixel launcher, but I had to turn off optimization and select it as the Home app through its app setting, even though I already selected always, otherwise it would default to the stock one any time I clear all recent apps.
    The one thing that seems different, the screen seems overall dimmer. I have it maxed out, and it just does not seem to get as bright? Tried both with auto brightness on and off.
    Over all, it seems snappy and have not seen any lag. It will take a few days to see how battery life holds up, and test all aspects of it, but so far I am pretty happy with it.
  8. Deactivated User
    Sep 24, 2019
  9. J1567268971677
    G1546972425195 likes this.
  10. Sirichix
    Francisco_Jiménez and Kainey like this.
  11. Suresh2452
    Froyo Sep 24, 2019
  12. bebop_cola
    Froyo Sep 24, 2019
    bebop_cola , Sep 24, 2019 :
    man, this forum is like 95% people asking when theyre getting the update, and pointing out the bar below the keyboard.
    Davor Sudar, TVTV, ShermCraig and 2 others like this.
  13. I1564856499918
  14. milan786
    milan786 , Sep 24, 2019 :
    lol
    still not received
  15. Kevinck
    Donut Sep 24, 2019
    Kevinck , Sep 24, 2019 :
    Hello,
    This specially for the people who plays pubg regularly.
    After the 10 upgrade m facing bit of graphic issue while playing game especially Pubg, i usually play on smooth extreme, but some time it changes graphic like m playing Pubg lite.. and again after 1 min graphic changes..
    And for me finger print scanner is bit laggy n it recognises sometimes n sometimes not..
    And yes their is also a issue with WiFi it shows connected but sometime while YouTube or gaming it shows offline or reconnecting..
    Regards
  16. BlazinDroid
  17. Spettinero
    Spettinero , Sep 24, 2019 :
    I have installed the Android 10 Beta (V2) on my OnePlus 7 Pro. I have to go back to Pie to be able to install Android 10 stable?
    Joey Pardella likes this.
  18. Sanchitmeena
    Froyo Sep 24, 2019
    Sanchitmeena , Sep 24, 2019 :
    did you receive rigjt now ? at around 1 am
  19. Abhay Gaikwad
    Froyo Sep 24, 2019
    Abhay Gaikwad , Sep 24, 2019 :
    yes installed it and i can notice finger print unlock has slower animation. feelsbadman
  20. Sanchitmeena
    Froyo Sep 24, 2019
