1371
OxygenOS 10.0 for the OnePlus 7 Pro and OnePlus 7
  1. vasugoyal3
    Eclair Sep 25, 2019
    Netsky60 and FRJerome like this.
  2. H1561960043803
    Ice Cream Sandwich Sep 25, 2019
  3. H1561960043803
    H1561960043803 , via OnePlus 7 Pro Nebula Blue , Sep 25, 2019 :
    And confirming that you are using the oxygen updater app from the playstore,?
  4. MBala
    Cupcake Sep 25, 2019
    MBala , Sep 25, 2019 :
    need notch hiding option.
    after update android Q
    i could not see notch hiding option
  5. kossgreim
    Donut Sep 25, 2019
    kossgreim , Sep 25, 2019 :
    I'm downloading the full update right now from the oxygen updater. I was able to retrieve it, thanks :)
    H1561960043803 likes this.
  6. H1561960043803
    No problem just install it through the local update like you did all. The others, and you should be good to go
  7. sateeshreddy
    Eclair Sep 25, 2019
    mateusz91 likes this.
  8. kossgreim
    Donut Sep 25, 2019
    will it delete all the data on the phone?
  9. H1561960043803
    kossgreim likes this.
  10. Daniel Marin
    Daniel Marin , Sep 25, 2019 :
    an error that I see usually happens with gestures when you are viewing an image and want to go back or at the beginning does not recognize the gesture and makes as if you were making an increase to the image
  11. V1569415900104
  12. Vivaan19
    Froyo Sep 25, 2019
    Vivaan19 , Sep 25, 2019 :
    any onplus 7 user are facing issue with alert slider after update 10
    i have issue with alert slider after shift to vibrate mode to ring mode it not come to ring mode
  13. V1565895526939
    V1565895526939 , Sep 25, 2019 :
    Android 10 ,it has some defects like we don't have a option to hide notch display,and some problems with the notification bar its blank while running some apps
    O1569076922961 likes this.
  14. sudhanshu665
    Donut Sep 25, 2019
  15. _shubham_SKULLER
  16. G_SRUJAN_DESHPANDE._ , via OnePlus 7 Mirror Red , Sep 25, 2019 :
    i think then it will be a hardware issue
  17. JmcRepair33
    JmcRepair33 , Sep 25, 2019 :
    Man i dont really see much difference at all in changes as far as bugs being killed, i really do suspect what they say that they updated the Beta 2 and chopped it on up with bugs that we didnt notice and released it as stable, although of course its stable no questions about it.
  18. JmcRepair33
    You might want to check if your slider is bad, could be defective, thats not a known issue i think you should call OnePlus on that 1 (858) 609-6590 ....Is the slider slide easily or can you feel lit click in pace when you move it to different profile switch?
  19. JmcRepair33
    You might want to check if your slider is bad, could be defective, thats not a known issue i think you should call OnePlus on that 1 (858) 609-6590 ....Is the slider slide easily or can you feel lit click in place when you move it to different profile switch?
    C1564584311009 likes this.
  20. Harishtamil
