1372
OxygenOS 10.0 for the OnePlus 7 Pro and OnePlus 7
  1. Aftabkhan123
    Cupcake Sep 29, 2019
  2. _abdul2311
    Froyo Sep 29, 2019
    _abdul2311 , Sep 29, 2019 :
    Guys the update was released but it had major bugs...
    1. HIDING NOTCH OPTION WAS NOT AVAILABLE
    2. BATTERY DRAINING FASTER
    3. ISSUES WITH CERTAIN PARALLEL APPS
    4. AUTOMATIC CALL RECORDING FEATURE
    Roll out has been halted for time being so this issues can be fixed...
    So have patience, if you're happy to android buggy update, you can download it from Oxygen Updater...
    #PATIENCE
    jasprjay and jaypatelani like this.
  3. R1566507609532
  4. jaypatelani
    Eclair Sep 29, 2019
  5. Azhar041
    Froyo Sep 29, 2019
  6. satkv
    Donut Sep 29, 2019
    satkv , via OnePlus 7 , Sep 29, 2019 :
    Do a factory reset. It solved most of my problems after all the apps were reinstalled I. the new environment. Battery stability is also better and so is the life.
  7. Sufyan302
  8. Kislay55_2
    Gingerbread Sep 29, 2019
    Kislay55_2 , Sep 29, 2019 :
    I am facing the same 2 issues on me Oneplus 6T since a few weeks. Plz help.
  9. Saifmsk
    Eclair Sep 29, 2019
    Saifmsk , Sep 29, 2019 :
    using Android auto since the Android 10 updates heats the phone up quite a bit. never happened before on Android 9
  10. Rupesh_anu
    ankitstark786 likes this.
  11. J1569729344442
    J1569729344442 , Sep 29, 2019 :
    Hello. I am a Oneplus 7Pro user. I have been using the stable oxygen os. I am having some issues with my device.
    If somebody calls me, my phone starts ringing but the display does not show me the caller page. Like the phone is ringing and there is no mention of the call on the UI. After few cycles of locking and unlocking the screen, i get the caller where i can pick the call. Also, when i cut the call, it does not get cut, it takes a few seconds to cut the call. It stays in my notification bar for a while and then gets away.
    alexferdean likes this.
  12. brijpalsingh29
  13. J1569729344442
    when we will get Android 10 update on oneplus 7pro... I am having many issues with present is.. pls give me update as early as possible... thanking you
  14. ExS
    ExS , Sep 29, 2019 :
    My OP 7 pro model are GM1913 but my software received from OTA was gm21aa instead of gm21ba is that normal ? Planning to self upgrade Android 10 but not sure whether should use aa or ba, any advice?
    jasprjay likes this.
  15. Soumitra_Katti
    Soumitra_Katti , Sep 29, 2019 :
    nope no camera improvements
  16. Y1567862888361
  17. C1565421168459
    Donut Sep 29, 2019
    C1565421168459 , Sep 29, 2019 :
    Is it joke?
    May be you're conveyor of Oxygen updater.
    Use properly. Lots of bugs are there in the update. Fake App Oxygen updater.
  18. E1562857001168
    Donut Sep 29, 2019
    E1562857001168 , Sep 29, 2019 :
    still I didn't get Android 10 in my OnePlus 7..can anyone please help me out..am I going to be left out
  19. vsskrishnamraju
    J1560080028751 likes this.
  20. alexferdean
    Ice Cream Sandwich Sep 29, 2019
    alexferdean , Sep 29, 2019 :
    It also happen for me twice. After a restart everything was back to normal.
