1371
OxygenOS 10.0 for the OnePlus 7 Pro and OnePlus 7
  1. Chief Jems
    Gingerbread Sep 29, 2019
    Chief Jems , Sep 29, 2019 :
    then why i don't get yet latest official build Android 10?
  2. charmingash
    Honeycomb Sep 29, 2019
    charmingash , Sep 29, 2019 :
    i have given u link if u want fresh install check out.
    Chief Jems likes this.
  3. charmingash
    Chief Jems
    then why i don't get yet latest official build Android 10?​
    update was halted for now. Many ppl havent received yet .For ur info android 10 update was not stable tho maybe they are releasing new version after fixing bugs.
  4. Swejuggalo
    OnePlus 9 Series Expert Community Expert Sep 29, 2019
    Swejuggalo , Sep 29, 2019 :
    Rollout is limited the first 2 weeks. After that it rollouts globally unless there are too many bugs in the update. All you need to do is wait or manually update yourself. 7 AA is what you need.
    My forum post with download links to the 10 upgrade and 9 downgrades.
    https://forums.oneplus.com/threads/...-and-oneplus-7.1105492/page-118#post-20784258
    Short link if link above is broken: http://bit.ly/2NqjbUR
    Stylianos_Kalintzis likes this.
  5. Chief Jems
    thanks a lot.. for ur cordial support..
    Swejuggalo likes this.
  6. Dasguptashoubhik
    Donut Sep 29, 2019
  7. GothicDeath
    Donut Sep 29, 2019
  8. Sunil_Jinde
    Cupcake Sep 29, 2019
    sherwinkp likes this.
  9. miss4chewN8
    Froyo Sep 29, 2019
    miss4chewN8 , via OnePlus 7 , Sep 29, 2019 :
    If the update is stopped, then is it useless to update using Oxygen Updater?
    I'm using it for the first time, presumably the data will be safe right?
  10. Ultraman215
    Ultraman215 , Sep 29, 2019 :
    There's increased risk any time you use a third party source to update your OS...
  11. Swejuggalo
    If you are on stable you don't loose anything. If you are on beta it will wipe.
    Update does not wipe. Downgrade does.
  12. Swejuggalo
    If they stopped it you get the bugs that was the reason for they stopping it. So it's recommended to wait. If waiting is not your thing use any of the options available for manual update.
  13. Stylianos_Kalintzis
    Stylianos_Kalintzis , via OnePlus 7 Pro , Sep 29, 2019 :
    Swejuggalo
    I agree with you totally, but I think that OnePlus must clarify what will happened, because as their 1st Post:
    "This OTA will have a staged rollout. The OTA will be received by a limited number of users today and will have a broader rollout in a few days after making sure there are no critical bugs. ..."
    The "few days" already gone...
    Ultraman215 and HZ_ND like this.
  14. Swejuggalo
    They usually don't say anything before the actual replacement update is ready. It's still a big IF regarding if they stopped it or not.
    If the update rolls out globally I bet a new one comes faster than normal though.
  15. ironclaww
    Donut Sep 29, 2019
    ironclaww , Sep 29, 2019 :
    I am on stable 9.5.11 OP7Pro. So i just neet to download file from your link and do manual upgrade ? And it'll be fine perfectly?
  16. Likhith_007
    Donut Sep 29, 2019
  17. Swejuggalo
    Exactly. Just make sure to chose that one that is meant for your phone. The files are directly from Oneplus servers and all reliable sites posting and linking to stable releases should point to the exact same files. These are also the exact same files Oxygen Updater let's you download.
    Before you use the files you can verify the integrity of the file by checking the md5 with md5 checker. Always double check what files you use before flashing.
    https://play.google.com/store/apps/details?id=com.peppe130.md5checker
  18. ironclaww
    Donut Sep 29, 2019
    Well thank you soo much. I'm gonna wait for OTA! If my patience runs out, i'll use the link.
  19. Swejuggalo
    Just to be sure a backup can always be nice to have. Regardless of OTA to a major upgrade or manually doing it.
  20. Swejuggalo
    If it does rollout as normal it should be close. So you should not need to wait that long.
