1372
OxygenOS 10.0 for the OnePlus 7 Pro and OnePlus 7
  1. UnicornZ
    Ice Cream Sandwich Sep 30, 2019
    UnicornZ , via OnePlus 7 Pro , Sep 30, 2019 :
    Open beta is a separate channel. As long as u r in open beta u will receive consecutive updates that is specific to open beta. U will not get official OTA when you are in open beta
    Gangester likes this.
  2. H1561960043803
    F_Mazin_M_Merza_EDiT likes this.
  3. David Turney
    Gingerbread Sep 30, 2019
  4. Deactivated User
    Sep 30, 2019
  5. Deactivated User
    Sep 30, 2019
  6. F_Mazin_M_Merza_EDiT
    Donut Sep 30, 2019
    F_Mazin_M_Merza_EDiT , Sep 30, 2019 :
    That is true.
    I just made the switch from IOS that's why this is a bit different for me.
  7. N1562307125192
    Cupcake Sep 30, 2019
    Rishisahu likes this.
  8. F_Mazin_M_Merza_EDiT
    Donut Sep 30, 2019
  9. dsmonteiro
    Community Consultant Staff Member Sep 30, 2019
    dsmonteiro , Sep 30, 2019 :
    As it's mentioned in every Beta thread,
    Moving back to the Official OTA path from the Beta path will require a full install and clean flash (full wipe of all data and cache).
    Getting back to Stable will always require data wipe, but you can use OnePlus Switch. Still, if your concern is only being up to date in terms of features, Open Beta is usually always ahead of stable updates.
  10. hituahuja
    hituahuja , Sep 30, 2019 :
    After upgrading, feeling good for icon packs, themes and etc... Found one Issue that navigation between recent apps become difficult at some extent which was extra smooth in previous version.
    Yet haven't focused much on the camera... Will check soon.
    Thanks in advance
  11. Gangester
    Eclair Sep 30, 2019
    Gangester , Sep 30, 2019 :
    thank you very much I decided that I'll stay in open beta channel :)
    dsmonteiro likes this.
  12. dsmonteiro
    As the original post states, This OTA will have a staged rollout. The OTA will be received by a limited number of users today and will have a broader rollout in a few days after making sure there are no critical bugs.
    This is a common practice for OTA software updates. Most Android manufacturers do this as well as Microsoft with Windows. There's probably other examples I'm not aware of.
    This is to avoid that any unforeseen issues that only affect small subsets of users get widespread. Some issues have such low ocurrence rates that cannot be detected through Beta testing.
  13. David Turney likes this.
  14. Deactivated User
    Sep 30, 2019
  15. dsmonteiro
    Just an additional thing. Sometime in the future, it may come a day where Open Beta program stops and you won't get any additional updates and you'll have to move back to stock software to keep getting updates. For past devices, this has happened when 2 new generations of devices are on the market (3 and 3T stopped getting beta updates when the 6 was released).
    When that day comes, you can easily copy everything with OnePlus Switch and then restore all data. ;)
    Georgeoneplus7pro and Gangester like this.
  16. rayprayas03
  17. Purushothdsp
    Donut Sep 30, 2019
  18. kishor_d91
    Eclair Sep 30, 2019
    kishor_d91 , Sep 30, 2019 :
    Hi,
    For some weird reason my clock in status bar stuck at "6:31" AM and didn't reflect with correct time eventhough in settings I could everything is set correctly.
    Is this a glitch? or do I have to reset my device to fix this? I'm currently running Android 10. Can someone help me with this please!
  19. Stako187
    Stako187 , Sep 30, 2019 :
    what is the difference@
  20. dsmonteiro
    Download size. Incremental is just the needed update over the previous one. Full is, well, the full update.
    Stako187 likes this.
