1367
OxygenOS 10.0 for the OnePlus 7 Pro and OnePlus 7
  1. JmcRepair33
    Ice Cream Sandwich Sep 21, 2019
    JmcRepair33 , Sep 21, 2019 :
    Someone Please update it to Drive and share the link if you have got the update so we can download and install it thanks
    N1558173122614 likes this.
  2. anubis72
    Froyo Sep 21, 2019
  3. Z1559923202058
    Froyo Sep 21, 2019
  4. Abbas agaria
    Eclair Sep 21, 2019
  5. charmingash
    Honeycomb Sep 21, 2019
    charmingash , Sep 21, 2019 :
    Nitin Siddhanthy
    BLACK SCREEN BUG in New Oxygen Update.
    l Installed new update.
    Added features were good but
    1)My mobile is getting heated
    2)There is some kind of bug where SCREEN TURNS BLACK and doesn't respond(when I opened PUBG).
    I contacted the customer care he insisted me to hold all the three buttons (lock.... volume up and down) at the same time for some duration, and the device restarted.
    I was tensed like hell for the situation I was put into by the update.
    PLEASE FIX IT.
    you dont need to restart use full screen gestures and go back to home and go through recent apps if u use oneplus gesture go back to home or if u use stock gestures use back gesture.i recommend using oneplus full screen gestures its smooth.when u got black screen just use home gesture.
  6. sechinov
  7. Fuschy
    Gingerbread Sep 21, 2019
  8. JmcRepair33
    Wow Maybe they are giving up and making the beta version with some kinks fixed and pushing it out as Stable. I agree with you. Really OnePlus.?
    G_ayush_madan_YhBr likes this.
  9. bandit1976
    bandit1976 , Sep 21, 2019 :
    No, you wont
  10. TheMysticalShaman
    TheMysticalShaman , Sep 21, 2019 :
  11. JmcRepair33
    Yes it says its being rolled out randomly via OTA update. so yes eventually if everything goes well which i imagine it will since what i hear its the same as the beta 2 then yes you should receive official from experience by end of day or tomorrow hopefully
  12. Z1559923202058
    Froyo Sep 21, 2019
  13. JmcRepair33
    I beleive you have to be on oxygen pie to get it as a official update if not we will have to just flash it, its going to be a regular normal update like every other OEM update via OTA if you are in Stable Pie to upgrade to Q
  14. TheMysticalShaman
    Everything mentioned about the update. I have with the Beta 2
    there is no differences between this update and beta 2
    plus the black screen bug is still there
  15. JmcRepair33
  16. Nitin Siddhanthy
    Donut Sep 21, 2019
    Nitin Siddhanthy , Sep 21, 2019 :
    screen isn't responding
  17. MehmetKARAKAS
    Cupcake Sep 21, 2019
  18. ssrana3890
    ssrana3890 , Sep 21, 2019 :
    Hi I have downloaded the OTA file but it's showing factory reset .
    please i have to create backup or not ???
  19. JmcRepair33
    Obviously we aren't getting more features lol. No one mentioned we are getting more features. So they will be the same. But all updates have bug fixes at least. And things that are fixed that people reported, but not everyone is going to notice a difference because not everyone had problems. but the problems that were reported that people had more then likely have been cleaned out in a stable version. but NO YOU ARE NOT GOING TO USUALLY NOTICE ANYTHING SINCE WE ARE ALREADY in beta 2. Just bug fixes. Any new features and apps we have had since beta 1 or before, the updates have literally just fixed bugs and mosquitoes and what not.
    anubis72 likes this.
  20. SwethishS
    Donut Sep 21, 2019
    SwethishS , Sep 21, 2019 :
    Great work Oneplus But I was really expecting an update in the camera section too.
