1343
OxygenOS 10.0 for the OnePlus 7 Pro and OnePlus 7
  1. z953rr
    Eclair Oct 10, 2019
  2. wospino
    Honeycomb Oct 10, 2019
    wospino , via OnePlus 7 Pro , Oct 10, 2019 :
    when it will be completed and done, release has been paused because a lot of bugs
  3. wospino
    you can do a downgrade to pie and update from pie... try to install the Android 10 package... both will wipe your data...
    take in mind that Android 10 stable isn't stable at all... You don't need to go to stable when stable and beta are the same
  4. sateeshreddy
    Eclair Oct 10, 2019
    z953rr likes this.
  5. RAHUL941
    Donut Oct 10, 2019
    RAHUL941 , Oct 10, 2019 :
    thank u soo much bro. I got it
    oneshotaz likes this.
  6. Prilla
    Eclair Oct 10, 2019
    Prilla , Oct 10, 2019 :
    Downgrading form Beta 2 to Pie does not wored! So where could I find the Link to Stabel Android 10 and then go back to pie?
  7. Sridharlovevirus
    Donut Oct 10, 2019
    Felipepipe likes this.
  8. iulisimo
    Gingerbread Oct 10, 2019
    iulisimo , via OnePlus 7 Pro , Oct 10, 2019 :
    docnok63
    Knowing the hotfix patch is coming in the next three weeks, I decided to jump back on A10 to test the new RiCE build and make sure my information about substratum lite was accurate I had a couple of unexpected things happen along the way...sorry in advance for the long post:
    First I disabled all Magisk modules in Pie and deleted substratum and RiCE 6.0 for Pie. I then loaded up A10 GM21AA via TWRP, reinstalled TWRP v70, and rooted with latest Canary (debug) version. I post this because a later screenshot will prove weird...
    View attachment 1149705 View attachment 1149706 View attachment 1149707
    Everything booted fine, but I noticed I forgot to uninstall FNG and it asked for root access. I uninstalled FNG and just enabled the regular Google left/right gesture in settings (screenshot later shows why this is mentioned.) I re-enabled all my Magisk modules and added RiCE 7.0 for 10 and the module for my 4K video recording on all lenses.
    I downloaded substratum lite and rebooted. Boot was fine again and I went into tweaking RiCE. Everything works as before with the exception of on the extended volume panel the phone volume no longer shows, but the important part is that the ring volume and notification volumes are separate in sound. All other RiCE tweaks work perfectly. This doesn't feel like an Alpha build...damn near release ready:
    On to substratum lite theming- NFL fingerprint wouldn't load, so I just reinstalled the apk and it was fine. The animation doesn't work on 10, but the icon is perfect. Pitch Black kept crashing so I disabled the compatibility mode that lite suggested I enable during setup. I then went to Swift Black and it loaded fine. I installed overlays A10 system and for all the apps that don't have a native dark mode. I only added Google Canary to the list because I don't like its native dark mode. There was an error for 3 system overlays that I never use, so I didn't care. Reboot and:
    View attachment 1149714 View attachment 1149715 View attachment 1149716 View attachment 1149719 View attachment 1149720 View attachment 1149721
    Did you notice some good things about those screenshots? Of course you did. In the first one you can see how pretty the lockscreen looks with the Dallas Cowboy FP logo and no notification from @Georgeoneplus7pro! Next, in the third screenshot you see that Gboard is all the way to the bottom edge!!! I think this is because I had FNG still installed/enabled from Pie when upgrading. I'm not sure and I'm certainly not gonna update it via the Play Store (turn off auto-updates for the app) or theme it with lite! If it ain't broke, don't fix it!!! Also, in the last screenshot, I love how Swift Black looks on Canary!!! I usually run a combo of Swift and Pitch Black but right now, Swift is all I need.
    As I said before, I added the 4K video recording Magisk module an XDA member made off of my work. What I had forgotten is that I installed OP cam v3.8.69 in Pie. The module still works with this version, but you lose 4K recording with the telephoto lens. Make sure you're on v3.8.59 before upgrading to 10 from Pie. I'm not bothered by it right now, but I might try reinstalling the camera later:
    View attachment 1149724 View attachment 1149725
    Things I lost from Pie: Kirisakura kernel isn't compatible with 10 yet (as far as I know)
    Things I gained from Pie: 4K wide angle video recording
    Things normally lost in 10 that I have: Gboard is flush with the bottom edge by accident.
    You see that RiCE reports that I have GM21BA installed, when I showed in first screenshot that I don't. Obviously gonna be cleared up with a later build.
    In summary, phones bought from OP are completely unlocked. Take advantage of this and unlock the bootloader and install Magisk at the least and TWRP for good measure. Android was made for to personalize and with Magisk modules and substratum lite, great things are possible.​
    so much work for nothing...have you no girlfriend?
    Ultraman215 likes this.
  9. iulisimo
  10. TusharDua51
    Froyo Oct 10, 2019
    Ramsvenkat likes this.
  11. Arun Sharma
    Arun Sharma , via OnePlus 7 , Oct 10, 2019 :
    it took you guys almost 24 day to realize this.
    iulisimo likes this.
  12. Georgeoneplus7pro
    Jelly Bean Oct 10, 2019
    Georgeoneplus7pro , Oct 10, 2019 :
    Do not ask anymore! Mr. Pi will penalize you and you will receive the update one month later. Each question, you receive a penalty month.
    B k, fidus62 and 7793044362 like this.
  13. Felipepipe , via OnePlus 7 Pro T-Mobile , Oct 10, 2019 :
    so... T-Mobile is selling the 7T on October 18 in the US. i would expect that by that time we get Android/Oxigen 10 on the 7 Pros , which they are no longer selling... if TMobile withdraws support for the 7 Pro, that would be EXTREMELY DISAPPOINTING, and a heads-up for any TMobile Oneplus buyer in the future... the other thing is... Im paying $14 a month for the jump program; what's going to happen if my 7 pro gets lost or damaged? since they wont have 7pros on-site... im sorry but i wont give up a 7 Pro for a 7T.
    Ultraman215 and A1560648267550 like this.
  14. Georgeoneplus7pro likes this.
  15. fidus62
    fidus62 , Oct 10, 2019 :
    Mr Pi is not allowed to write anymore. The Assistant Head moderator "Youbi" has written that Mr. Pi's messages are "offtopic" ... Look here:
    Your message in “OxygenOS 10.0 for the OnePlus 7 Pro and OnePlus 7” constitutes a violation of rule "1.3 Pointless & off-topic":You have been issued 1 warning point. This point will expire exactly two months from now. If at any point you accumulate 5 points, you will be subject to a 1-day temporary ban. Should you pass a higher specified point threshold during any two months period, the duration of your ban will be longer.
    For more information on our rules and warning points thresholds, see Terms and Rules.
    Please make sure to post threads with relevant content and with a basis for discussion and/or that your posts are relevant to the thread you are posting in.
  16. C1570712000695
    Cupcake Oct 10, 2019
    C1570712000695 , Oct 10, 2019 :
    Hi there! It has been almost a month since this post an we are keep waiting for the updates.. I'm a OP7 Pro user an still running android 9.. Can not wait for Android 10 with new Oxygen OS
  17. X1570712228543
    M1565805631266 likes this.
  18. Rahul_2911
    Rahul_2911 , via OnePlus 7 , Oct 10, 2019 :
    they don't give update to cheaper phones
    wait for one year haramkhor
  19. sam311
  20. tomtom1470
    Donut Oct 10, 2019
    tomtom1470 , via OnePlus 7 Pro , Oct 10, 2019 :
