1353
OxygenOS 10.0 for the OnePlus 7 Pro and OnePlus 7
  1. Diegoelunico
    Donut Oct 17, 2019
  2. Diegoelunico
    Donut Oct 17, 2019
    Diegoelunico , via OnePlus 7 Pro , Oct 17, 2019 :
    Just after I told you I was still waiting for the update, I received a notification and started downloading it [e]1f603[/e][e]1f603[/e][e]1f603[/e]
    Gabbyagedah likes this.
  3. Gabbyagedah
    Donut Oct 17, 2019
    Gabbyagedah , via OnePlus 7 Pro , Oct 17, 2019 :
    nice one
    Diegoelunico likes this.
  4. J1508070026278
    Gingerbread Oct 17, 2019
  5. DrewB83
    Cupcake Oct 17, 2019
  6. Paarthgandhi
    Eclair Oct 17, 2019
  7. O1571345469090
    O1571345469090 , Oct 17, 2019 :
    I have a problem with the software implementation. I'm currently using the Global Version of the One Plus 7 and when I use the gesture system without having a bar in the low part of the device I have some problems in some apps.
    For example, in Youtube I can't see the first two letters of "Página Principal" and in WhatsApp, when I want to send an audio (blocking it), it uses the same gesture as going back so it doesn't help the user experience. It can be a silly thing but it would be better to not have this visual problems.
    Thank you and sorry for my English.
  8. NoctisLucisCaelum
    Cupcake Oct 18, 2019
  9. K1559742975511
    Eclair Oct 18, 2019
    K1559742975511 , via OnePlus 7 , Oct 18, 2019 :
    yes bro I am using th current android 10.0.1 it's has no bugs
    T1571309289786 likes this.
  10. J1508070026278
    Gingerbread Oct 18, 2019
    J1508070026278 , via OnePlus 7 , Oct 18, 2019 :
    got the 10.0.1 update last night.
    haven't found any bugs yet but yeah battery life is significantly lower now as compared to 9.5.8
  11. TJ_1+7
  12. Z1559923202058
    Eclair Oct 18, 2019
  13. Z1559923202058
    Eclair Oct 18, 2019
  14. aristle.jm
    Eclair Oct 18, 2019
    aristle.jm , Oct 18, 2019 :
    Probably cause they left room for the three buttons...
    They might fix it in further updates
  15. A1571389683136
    A1571389683136 , Oct 18, 2019 :
    How to access my google contacts in contact menu. It's showing " you have disabled a required permissions." Please help me how to fix it. I am unable to call anyone from my contact list.
    Thank you
    Diwakar Chauhan
  16. Ayman Abu Kraiem
    Ayman Abu Kraiem , via OnePlus 7 Pro , Oct 18, 2019 :
    Got the update last night, noticed smoothly running os. no glitches so far, will report anything shows up.
    Camera improvement is yet to be tested.
    cpl of things I noticed, battery drains a bit faster than the previous 9.5! Also,new useless apps installed, why do you force a Google file manager when we already have a perfectly working one? Same goes for Google pay that I don't use or even think of using! seriously, anyone with brains won't give his financial data to anyone even if it's Google. now am stuck with these apps & I can't remove them.
    Overall,seems a working update without serious issues
  17. K1559742975511
    Eclair Oct 18, 2019
  18. Z1559923202058
    Eclair Oct 18, 2019
  19. K1559742975511
    Eclair Oct 18, 2019
  20. WFMLANDGRAF
    WFMLANDGRAF , Oct 18, 2019 :
    A bateria está drenando bastante, antes do Android 9 há cerca de 6 a 7 horas da tela, agora no novo Android 10, caiu para 4:40 a 5 horas de tela. Ao meu ver era para o sistema economizar mais bateria e não drenar como está acontecendo.
