1352
OxygenOS 10.0 for the OnePlus 7 Pro and OnePlus 7
  1. mrahul13
    Cupcake Oct 24, 2019
    mrahul13 , Oct 24, 2019 :
    Hey ,
    Raise to answer call doesn't work after upgrading to Android 10. During video recording when we click photo, the photo is scaled wrongly. I am unable to see the subject as it is cropped inappropriately when i look at it in gallery. And security patch update is still September 5 though it's almost nearing November. Kindly address this query please
  2. munawarul
  3. chitralapavan2000
    chitralapavan2000 , via OnePlus 7 , Oct 24, 2019 :
    Hi,
    After updating my Oneplus7 to OxygenOs 10.0 I am facing below issue.
    I am unable to download the apps from playstore when my device is connected to WiFi even though internet is fine I mean I was able to browse through the browser. If I use mobile data I am able to download the apps and update the apps.
    please help me on this issue.
    Thanks in advance
    one plus 7 user
    O1570553217388 likes this.
  4. anvithks
    Eclair Oct 25, 2019
    anvithks , Oct 25, 2019 :
    I too am facing issues with the thumbnail orientation in the gallery app. Although photos are portrait the thumbnail orientation is landscape.
    I have also noticed some issues with the gyroscope. Photos shot in landscape mode are rotated or inverted.
    I am also facing issue with sending photos with WhatsApp. The app just hangs and even force quitting and trying again doesn't work. I have to restart the phone to upload any pics if it hangs once.
    When this happens I also notice that scrolling in the OnePlus Gallery app gets stuck. I have to wait about 2 seconds after every scroll.
    The access to gallery from camera app is buggy as usual. Does not open the correct image and does not let you scroll sideways to check previous images.
    Switching between portrait mode and normal photo mode takes at least 3-4 seconds and cannot be done in a hurry. When I am taking pics of groups or some candid moments this just does not help.
    Camera crashes if I try to take photos quickly.
  5. O1570553217388
    Cupcake Oct 25, 2019
    O1570553217388 , Oct 25, 2019 :
    update is not stable fingerprint scanner doesn't work many times & take more time than before update. also switching the app doesn't work many times just go to back option automatically.
    please fix this fingerprint scanner issues cause it's the most needed feature & most important feature . every single person use it the most ..
    just because of this bug or instability I'm not updated my phone cause it irritated me too much ...
  6. vinothevilflame
    Eclair Oct 25, 2019
    vinothevilflame , Oct 25, 2019 :
    yeah tats the good idea...which iam implementing ryt now..iam in version 9.5.6only...
  7. brennanfurca
    Eclair Oct 26, 2019
  8. C1570707004537
    Cupcake Oct 26, 2019
    C1570707004537 , Oct 26, 2019 :
    How did you reverted back? Can you please share the guide?
  9. brennanfurca
    Eclair Oct 26, 2019
    brennanfurca , via OnePlus 7 Pro , Oct 26, 2019 :
    just Google it. there's a firmware one plus released to roll back. you just download it and go to the upgrade screen but select the file manually
  10. enya26
    enya26 , Oct 26, 2019 :
    I have the One Plus 7 and am having massive lagging while regular usage, opening apps, toggling between apps and whole browsing as well. the phone is also hanging very often for upto 5-8 seconds every time.
  11. DelBoyJamie
    Froyo Oct 27, 2019
    DelBoyJamie , via OnePlus 7 Pro , Oct 27, 2019 :
    Funny how wrong you where. I hope you will learn to chill with people. The keyboard issue IS a fault of OxygenOs and thankfully some kind person worked out how to fix oneplus mess.
    A simple line of code in adb
    adb shell wm overscan 0,0,0,-100
    Will fix the keyboard issue. Since again as I said it's not individual keyboard apps it's oxygen os issue.
    https://forums.oneplus.com/threads/...-and-oneplus-7.1117547/page-380#post-20938196
    Credit to XDA guys https://forum.xda-developers.com/oneplus-7-pro/themes/fix-adb-disable-black-bar-10-0-1-t3987731
  12. elanglois
    Lollipop Oct 27, 2019
    elanglois , via OnePlus 7 Pro , Oct 27, 2019 :
    Did you see the picture I posted? I was responding to the claim that it does it on all keyboard apps, and it does NOT.
  13. elanglois
    And thats a workaround, not a fix. Overscan should be 0, not a negative value.
  14. DelBoyJamie
    Froyo Oct 27, 2019
    Lol OK. Looking at the messages I said it was fault of oneplus you said it's the apps like swift key and Gboard who implemented it. I said it's a issue with oneplus OxygenOs anyway no worries thankfully people can fix it now.
  15. DelBoyJamie
    Froyo Oct 27, 2019
    Yes obviously it's a work around. That's because OxygenOs messed it up. At the end of day it's not the apps. I've tried 9 diffenent keyboard apps and they all do it and many other apps have issue with it. Again my point was. OxygenOs need to fix this.
  16. aashutosh_tomar
    Cupcake Oct 28, 2019
    aashutosh_tomar , Oct 28, 2019 :
    How can i bring back my gaming mode tile in notification panel. It has been removed from notification panel in Android 10. It was a great help and i used to need it very frequently.
  17. Sunny Birat
    Sunny Birat , Oct 28, 2019 :
    After update my 7 Pro to Android 10 i am facing many issue like it goes while you make and disconnect the call.
    Finger print area not show in apps which are secured with figure print.
  18. V1568917783282
  19. J1572317359586
    Cupcake Oct 29, 2019
  20. Sudhindra_Hulekal
    Sudhindra_Hulekal , Oct 29, 2019 :
    Hi 1 Plus team Post Oxygen update 10.0.01 inm unable to connect Bluetooth to my car music system I checked other devices it working fine this issue I am facing post software update until it was working fine
