1365
OxygenOS 10.0 for the OnePlus 7 Pro and OnePlus 7
  1. stangweb
    Gingerbread May 11, 2020
    stangweb , via OnePlus 7 Pro 5G , May 11, 2020 :
    same here. I think it has something to do with the merging of the networks that is messing with the calls .
    Nitzz_Raju likes this.
  2. venki__8__8__PS
    Cupcake May 12, 2020
    gsranishsri likes this.
  3. Atmik123
    Eclair May 13, 2020
  4. ramlakhanmeena
    Cupcake May 14, 2020
  5. A1559657699604
    D1569993620569 likes this.
  6. sahilrana likes this.
  7. Chitwan220
    Donut May 20, 2020
  8. Vivaan19
    Froyo May 21, 2020
  9. Butch_Sales_ES , via OnePlus 7 Pro , May 21, 2020 :
    Much more stable than previous build beta, before I got some problem with accessing the app list, it become slow and sometimes the disappearance of the hidden app occured, as of now it's good and stable...Will keep you posted on or this thread if there's some bugs
  10. Vivaan19
    Froyo May 21, 2020
    Vivaan19 , May 21, 2020 :
    how about battery backup
  11. C1560446644239
    Cupcake May 28, 2020
  12. D1569993620569
    Cupcake Jun 11, 2020
    D1569993620569 , Jun 11, 2020 :
    Hello Team,
    I have issue, at times when I double tap my screen, the screan to get my finger print is not visible, the screen is simply off, I have checked the doubt tap option is enabled and but still I find this issue after this new update.
    kindly consider my feedback and help resolving the same.
    Regards,
    Ganesh Arumugam
  13. Artemus.
    Nougat Jun 11, 2020
    Artemus. , Jun 11, 2020 :
    Wroooooong thread...
  14. Massssss
    Eclair Jun 12, 2020
  15. Artemus.
    Nougat Jun 12, 2020
    Artemus. , Jun 12, 2020 :
    The one that corresponds with your update build?
    Vansh99 likes this.
  16. Massssss
    Eclair Jun 12, 2020
    Massssss , Jun 12, 2020 :
    can you please suggest exact thread for above mentioned problem
  17. Artemus.
    Nougat Jun 12, 2020
    Well, what version are you on right now?
  18. D1569993620569
    Cupcake Jun 12, 2020
    D1569993620569 , Jun 12, 2020 :
    Hello,
    Thank you for your response
    I believe you are aware of the option " Double tap to wake " option under " Butten & gesture -> quick gesture " I have enabled the same, now after this update when I double Tap the screen when it goes off, it is not waking up, so in that case I am using power button to open my screen,
    I hope you could understand my concern now, please help me on fixing this issue.
    Regards,
    Ganesh Arumugam.
