732
OxygenOS 10.3.0 for the OnePlus 6 and 6T
  1. Balaji6t
    Gingerbread Dec 22, 2019
    Balaji6t , via OnePlus 6T , Dec 22, 2019 :
    thankyou very much [e]1f44c[/e][e]1f44c[/e][e]1f44c[/e][e]1f44c[/e][e]1f44d[/e][e]1f44d[/e][e]1f44d[/e][e]1f44d[/e][e]2764[/e]️[e]2764[/e]️[e]2764[/e]️
  2. KRITZSUTHAR
    Eclair Dec 22, 2019
  3. Sirohi777
    Cupcake Dec 22, 2019
    Sirohi777 , Dec 22, 2019 :
    Need help Can someone please help me
    I have update my oneplus 6 via local update and now i want to things to back normal please tell me how i fix this for normal ota updates
    And is updating via local file is safe? And how to go back to normal
  4. Virendra dhaka
    Froyo Dec 22, 2019
  5. adi1001
    Honeycomb Dec 22, 2019
  6. N1539961316860
    Froyo Dec 22, 2019
    N1539961316860 , Dec 22, 2019 :
    After updating new two android 10 version the only issue I faced that camera app went worse. Lot of noise in picture after opening camera app both normal and portrait mode. Team One plus has to work on this part as well.
    Deep clear option is not available in new update.
  7. J1576855115319
  8. F1544361667585
    Eclair Dec 22, 2019
    F1544361667585 , Dec 22, 2019 :
    I still have August security patch on my OP6 and Android pie, is it just problem with my device that I am not getting any update?
  9. desmondloh1997
    desmondloh1997 , Dec 22, 2019 :
    For those of you wanting to get the update without waiting for OTA, just go to Play Store and install the Oxygen Updater app. It is safe and easy to use to upgrade your OS faster before OTA reach your phone. It works for all OnePlus devices.
  10. Pdthepunisher
    Eclair Dec 22, 2019
  11. shantha1450
  12. ItsRavi25
    Jelly Bean Dec 22, 2019
    ItsRavi25 , via OnePlus 6T , Dec 22, 2019 :
    Great oneplus.....still not received 10.0.1.....and now 10.3.0 released....plz provide updates first to the devices who didn't receive the updates ..[e]1f622[/e][e]1f622[/e][e]1f622[/e]
  13. siddharth740
  14. mik29194
    Froyo Dec 22, 2019
    mik29194 , Dec 22, 2019 :
    Android 10 (10.3.0) Review for the 1+6t.
    Hey Guys, so I have been using this update on my 1+6t for almost two days now and here are my thoughts....
    I was very skeptical jumping from my Android 9 (9.0.17) to this build of Android after reading all the comments from the post of 10.0.1 update for the 6t which still had many bugs. but when I did it was quite different..
    The first thing that you'll notice after the after is entirely revamped settings menu and dark mode extending to a broader spectrum of the apps and system. so might see some minor random glitches here and there while scrolling but eventually it goes away.
    For those complaining about the battery drain, yes it is there but only after the first reboot after the update.so once you reboot go to the settings menu>security and lock screen and tap the Google play system update. It will promt that the "the phone needs to restart to apply the update" and click on restart tab on that page. After he phone restarts plug your phone to the dash charger and allow the battery to be charged way up to 100% with all things switched off as in mobile data,wifi, location, Bluetooth,nfc. I know it's hard but please be patient. once that is done you can go back to using the device normally and you can see that the battery drain has returned to it's normal state since it calibrates the battery. This worked for me and should work for you too.
    Also please note that the gap between the keyboard and bottom of the screen isn't a big and it's a feature of Android 10 to make the typing easier on a one handed usage.
    One plus has quietly added and removed some features.The addition includes Wifi calling feature inside the Sim setting(might be region specific) and the video enhancer option inside the display setting menu. The exclusions are the removal of ram boost option inside the one plus lab setting and moving it inside the systems tab and I'll keep updating the post if I find any.
    some other things worth noting are small tweaks in the sms and call app. while the sms app gets sms segregation based on type of sms and advanced spam detection,the call app gets called identification (might be region specific).one thing to be noted is that you can no longer switch between call history and speed dial tab just by swiping as earlier in the call app which was a good thing. I hope one plus brings it back.also you cannot access hidden space from the app drawer as it was earlier present in Android 9
    other features include logging into the one plus account direct from the settings menu,digital well being , one plus cloud service, new customization tab in settings menu to change system visuals,new guestures for navigation, game space, redesigned files app, redesigned system update apps and some minor tweaks here and there which I'm still exploring.
    People (Indian) complaining that there are seeing two Google pay apps don't be worried it's just one is an Indian version and another is an international version which allows you to store your cards in them and pay via NFC. it was present in the previous Android version but was disabled for some reason.
    some third party apps might now work due to it's compatibility issues with Android 10. For me it was the Gcam app which preferred over the stock camera app. if it work for you well and good.
    so I can say that this build of Android 10 is totally usable without any worries.
    This sums up my review for this release build.
    let me know your thoughts if I missed somethings to add by quoting this comment and I'll be making a separate thread as well for everyone to discuss.
    Till then ☮️
  15. sidhu22
  16. chinmayprabhu
    Eclair Dec 22, 2019
    LeonMx likes this.
  17. Aman05
    Aman05 , Dec 22, 2019 :
    the updates is stable till now, I haven't found any bugs.
    HOWEVER, you dev team shouldn't have remove the "Notch Hiding" option instead they should have added it the "Remove Notch" option.
    Now it feels like the screen is small.
  18. KANO98
    Donut Dec 22, 2019
    Pnjkay and LeonMx like this.
  19. vishnu3360
    Eclair Dec 22, 2019
