730
OxygenOS 10.3.0 for the OnePlus 6 and 6T
  1. C1547637192235
    Cupcake Dec 24, 2019
  2. bbzamangupta
    Eclair Dec 24, 2019
    bbzamangupta , via OnePlus 6 , Dec 24, 2019 :
    for battery i am already changed it to intelligent optimization.
    for the phone reset i dont have 4-5 hr spare to re apply my settings and apps again and manage it.
    Aman05 likes this.
  3. Aman05
    Gingerbread Dec 24, 2019
    Aman05 , Dec 24, 2019 :
    it's working fine bro, you might want to clear the cache or formats the device onc assuming you haven't format it.
  4. Aman05
    change it to optimised, from intelligent optimised.
  5. Clausimi
    Clausimi , via OnePlus 6T , Dec 24, 2019 :
    Liehjan
    App specific issue, check with the app developer​
    I did not have the issue before the update, why is it that right after the upgrade the game started freezing? I ve had the same issue with F.B. Messenger and after an android update it stopped freezing.
  6. K1575370310712
    K1575370310712 , Dec 24, 2019 :
    Experiencing a wierd bug which is not allowing to change the ringtone and set to default as oneplus tune after upgrading to Oxygen OS 10.3.0
    Aman05 likes this.
  7. Aman05
    bbzamangupta likes this.
  8. GauravKrNayyar
    E1577117229358 likes this.
  9. C1547637192235
    C1547637192235 , Dec 24, 2019 :
    yes i am facing the same problem .
  10. E1577117229358
    E1577117229358 , Dec 24, 2019 :
    can't open the hidden space , the keyboard of the previous version was way better , although working at a good speed but some function which are mostly used are not working ...
    please repair the hidden space window option because just by dragging the window to the right i cannot open it up
    and many of my major apps are in there..
  11. Y1549124396797
    Y1549124396797 , Dec 24, 2019 :
    Blue screen is flickering on unlock screen everytime after updating software 10.3.0
    Device : one plus 6
    H1572669940024 likes this.
  12. bbzamangupta
    Eclair Dec 24, 2019
    Aman05 likes this.
  13. E1577117229358
    Aman05 likes this.
  14. Aman05
    Bro you know I guess that after every major update like upgrading the OS you might want to format the once after the upgrade. Assuming you haven't done it try and check one. mine is working fine
  15. munish0407
    munish0407 , Dec 24, 2019 :
    Google Photos not working. it seems issue is with accessing the storage of phone via gallery and Google Photos app.
  16. nileyadav
    Eclair Dec 24, 2019
    nileyadav , via OnePlus 6T , Dec 24, 2019 :
    go home settings and select hidden space
  17. ZuhairKaify
    Eclair Dec 24, 2019
    Aman05 likes this.
  18. GauravKrNayyar
  19. Aman05
    change it in all app, since in the previous A9 version it was selected in optimised. Battery usage will be also more if you select in Intelligent optimised.
  20. E1577117229358
    Aman05 likes this.
