732
OxygenOS 10.3.0 for the OnePlus 6 and 6T
  1. hitz123
    Cupcake Dec 24, 2019
  2. Rajatsoni99981
    Froyo Dec 24, 2019
    Rajatsoni99981 , Dec 24, 2019 :
    but there is a problem. We dont get the haptic feedback when opening an application form the app drower.
  3. Deactivated User
    Dec 24, 2019
  4. Satyam1093
    Satyam1093 , Dec 24, 2019 :
    after update my one Plus 6 not perform well
    in contact and Call log remove slide option now u tap on option below screen to contact , Call log and speed dial please update this bugs and fix it
  5. Rishi92
  6. Rishi92
    Rishi92 , via OnePlus 6 , Dec 24, 2019 :
    buddy camera also not started
  7. raheel23
  8. vaibhav2794
  9. Manas Prakshale
    Manas Prakshale , via OnePlus 6T , Dec 24, 2019 :
    I wrote what I experienced . These are not some made up rumours .
  10. Caomhin
    Community Hero 2020 Dec 24, 2019
    Caomhin , via OnePlus 6T Mirror Black , Dec 24, 2019 :
    Have heard a few who had as high in the storage folder, some fixed it with a factory reset, some had the same storage after a factory reset. It appears to be random. If you do decide on a factory reset, ensure you backup phone first as it will wipe your data.
  11. ajithrktr
    Eclair Dec 24, 2019
    ajithrktr , Dec 24, 2019 :
    this post is done after the factory reset...[e]1f622[/e]
    Caomhin likes this.
  12. mr.dauer
    mr.dauer , Dec 24, 2019 :
    hi, my settings for the dark theme is resetting to light every week. do you have the same issues?
  13. SumitPrajapati
    SumitPrajapati , Dec 24, 2019 :
    i tried it thousands time but it doesn't oppen.
  14. DKBaddage
    Donut Dec 24, 2019
    DKBaddage , Dec 24, 2019 :
    Only problem I'm having is that empty space under the keyboard. Other than that everything works fine.
    Before downloading the update, I did a full reset from recovery mode.
    Then install the update
    Then did an another full reset.
    I normally does this whenever I get a big update. I'm sure it will solve most of problems
  15. Manish_More
  16. Rajeshbs
    Luisfertj1 and O1574402461895 like this.
  17. J1543078014378
  18. Vineetm1
    Vineetm1 , Dec 24, 2019 :
    Is anyone facing these two issues after the update?
    1. Hidden Apps space isn't accessible, even after trying multiple times.
    2. Colors are more warm now, don't know but they look over, and lot different than normal.
  19. deepeshbarjatya@
    Eclair Dec 24, 2019
    deepeshbarjatya@ , Dec 24, 2019 :
    yesterday i got update in my oneplus 6 android 10.3.0,
    one thing i want to add here is that everything is working fine BUT i don't know why camera performance looks degraded to me, is this intentionally done by Oneplus or is the bug please fix this issue, yesterday the pics i click at my home is awesome as before but today when i click after updating my phone in the same environment i got the pics are blurry and not as before at all.
    @OnePlus please check this issue asap.
    Luisfertj1 likes this.
  20. Anrudh2520
    Anrudh2520 , Dec 24, 2019 :
    Facing problem after update with 10.3.0 after my screen goes for sleep mode it doest not unlock . I have to force fully re-start the phone every time and screen remain dark and nothing can be done.
    O1574402461895 likes this.
