732
OxygenOS 10.3.0 for the OnePlus 6 and 6T
  1. deepeshbarjatya@
    Eclair Dec 24, 2019
    deepeshbarjatya@ , Dec 24, 2019 :
    Hidden Space is accessible for me every time i attempt it.
  2. ItsRavi25
    Ice Cream Sandwich Dec 24, 2019
    ItsRavi25 , via OnePlus 6T , Dec 24, 2019 :
    wipe cache..or hard reset your device it will solve your problem
  3. ItsRavi25
    update your launcher
  4. Sarath043
    Cupcake Dec 24, 2019
  5. T1577157596491
    O1574402461895 likes this.
  6. shabab_khan
    shabab_khan , Dec 24, 2019 :
    the slow motion speed is too slow . please update it to little bit faster like iphone.
  7. A1577178603406
    Donut Dec 24, 2019
    A1577178603406 , Dec 24, 2019 :
    i have done update to latest Oxygen and since none of the apps are working properly. gallery is not showing any pictures, watsapp is automatically getting hang and stop working. Google play automatically terminates. serious bug issues still present. i recommend do not upgrade
    Luisfertj1 likes this.
  8. LegolasX
    Jelly Bean Dec 24, 2019
    LegolasX , Dec 24, 2019 :
    i didn't know OnePlus 6 had optical fingerprint sensor..
    and how long have you been using your OnePlus and still unknown about OnePlus using blue led for dash/warp charging which cannot be changed.
  9. lucky18904
    Eclair Dec 24, 2019
  10. Antgl
    Honeycomb Dec 24, 2019
    Antgl , via OnePlus 6 , Dec 24, 2019 :
    When I turn off the notch, the notification bar comes down under the notch. Is it a bug that it doesn't stay next to the notch?
  11. shawanilkumar22
    sushantparajuli91 likes this.
  12. RuchirK
    RuchirK , Dec 24, 2019 :
    Please Bring Back The Dark Mode On Oxygen OS 9... If I Turn On The Dark Mode, It Forces All The Apps To Be On The Dark Mode...
  13. F_Andrea_Leo_dnlR likes this.
  14. SanJayDa
  15. C1572008285965
  16. Waseem_Chaudhary
    Waseem_Chaudhary , via OnePlus 6 , Dec 24, 2019 :
    After recent update 10.3.0 i cannot hear any voice while making any call. it happens only during outgoing while other audio settings are perfect.
    does anyone is facing this?
    how to reslove ??
  17. vaibhav2794
    vaibhav2794 , Dec 24, 2019 :
    Hey, excuse my analogy please.. but as far as I know if you have an option to change it.. why not mean it? or plain and simple remove it[e]1f481[/e]🏽‍♂️
    it's a no brainer!
  18. Neeraj_Agarwal_97
    Donut Dec 24, 2019
    Neeraj_Agarwal_97 , Dec 24, 2019 :
    Hi, I am facing a serious issue after updating to Android 10, I upgraded the phone by the OnePlus default update channel using the system update on 23Dec 2019.
    Device details-
    OnePlus 6t
    Current Os version-10.3.0
    Issues I am facing-
    1. No images in gallery
    2. Files missing in file manager(system files are there, documents 0, images 0,....)
    3. Apps crashing - Play store
    4. Opening Google app shows loading
    5. Other apps crashing randomly
    6. Google photos only shows backed up images.
    I myself checked about the data on my phone after facing the issue and files in internal storage have not been removed, as Settings>Storage>photos shows
    18 gb occupied.
    Also I visited file:///scard, earlier it showed all the system files, photos and other documents, but now the file:///scard is not loading on Chrome browser.
    My phone's apps are not accessing the storage files, I don't know what went wrong. The storage permissions to the apps mentioned is Enabled.
    I tried restarting the phone several times and also in safe mode no files appeared.
    [Also while writing this post I can't select any screenshot because this app is also not showing my storage files :( ]
  19. chetanraj46
    chetanraj46 , via OnePlus 6 , Dec 24, 2019 :
    A small bug in the new update... The keypad does not cover the bottom screen.... It leaves a small gap between the bottom screen.... Which was not there in the old version.... Kindly check if the same can be fixed
    Neeraj_Agarwal_97 likes this.
  20. LegolasX
    it works as specified when a non-dash/warp charger or cable is used. thus the option is provided. That's how OnePlus designed it. if you think otherwise feel free to leave feedback for them.
    vaibhav2794 likes this.
