732
OxygenOS 10.3.0 for the OnePlus 6 and 6T
  1. saber1203
    Gingerbread Dec 19, 2019
    saber1203 , Dec 19, 2019 :
    Yes, they're robbing you of your screen space if you don't like the notch, the old method of hiding the notch was better thought out, but it requires them to put effort
  2. Makaronui
    Eclair Dec 19, 2019
    bjorg18 likes this.
  3. NicestRudeGuy
    Froyo Dec 19, 2019
    NicestRudeGuy , via OnePlus 6 , Dec 19, 2019 :
    try any custom rom ,there it's like android 9's notch .not this shit.
    also the black bar below the keyboard when using the OnePlus gestures suck
  4. abhinav_kajla
    Cupcake Dec 19, 2019
  5. E1571023934349
    Donut Dec 19, 2019
  6. bogdan.soare9
    Froyo Dec 19, 2019
    bogdan.soare9 , Dec 19, 2019 :
    Actually, this also happened with the Pie update for the 5/5T last year. In the exact same way. The first good Pie update was 9.0.2 or 9.0.3 if I remember correctly. The other ones were filled with bugs and were stopped shortly after release. Let's do a test. Next year check out the update process for the 7/7T and compare it to this year's 6/6T. Moreover, I wouldn't expect android R for the 6/6T sooner than Q1-Q2/2021, just like this year with the android Q update for the 5/5T.
  7. sardaarbabu
    Eclair Dec 19, 2019
    sardaarbabu , Dec 19, 2019 :
    Thanks for the your updates ..
  8. G_Subbu_asodu_hebbar_mMu
    G_Subbu_asodu_hebbar_mMu , Dec 19, 2019 :
    still my 6t is run in oxygen 9. when do we receive the update. it's so creepy to go to setting check for update and realize it hasn't got any updates...😕
    Shay+ likes this.
  9. vasek2
    Eclair Dec 19, 2019
    vasek2 , Dec 19, 2019 :
    It looks much stable.
    Notch on/off works fine. Even I can send photo from galery (Native app) using whatsup without getting stock.
    Alex1681 likes this.
  10. Shay+ likes this.
  11. D1536903736214
    Donut Dec 19, 2019
  12. G_SayIDidIt™
    G_SayIDidIt™ , via OnePlus 6T , Dec 19, 2019 :
    When I saw that "Hide the Notch" was part of the update I got excited. But then I tried it, and it bumps the notification panel below the notch (like what Google did with the Pixel 3),i got upset.
    What happened OnePlus??? In Android 9 it worked so well! Why did you kill it in Android 10? And then to bring it back but worse? Come on.
    #disappointed
  13. Smxtren
    Smxtren , Dec 19, 2019 :
    waiting since november fro LierPlus update and still nor recieving it....
  14. parovi01
    parovi01 , via OnePlus 6 , Dec 19, 2019 :
    Hi all!..
    I have just upgrade my OnePlus 6 to the OOS 10.3.0.
    But I still have a problem with the WiFi hotspot using 5 GHz band.
    It is turn automatically off after a few seconds. This was the same behaviour than OOS 10.0.1 . I expected that this problem was solved on this new release. [e]1f62d[/e]
    Could someone who has the 10.3.0 installed test it just to know if more people is affected?
    thanks in advance!
    Pablo
  15. CHINTUREDDY
    CHINTUREDDY , Dec 19, 2019 :
    hello could you please tell me how can i upadate to 10 i didn't get updates in settings
  16. Bobs Smart
    Bobs Smart , via OnePlus 6 , Dec 19, 2019 :
    [e]1f44d[/e][e]1f44d[/e][e]1f44d[/e]
  17. Adi2002
  18. Shivarajbg
    Eclair Dec 19, 2019
