732
OxygenOS 10.3.0 for the OnePlus 6 and 6T
  1. PerfectStorm
    Donut Dec 24, 2019
    PerfectStorm , Dec 24, 2019 :
    guys..
    there is one additional problem that seems to be significant for me..the gcam stopped working..
    all other versions process the images awfully but this particular one was the best :( and now it crushes every time I try to launch it..
    the reinstallation didn't help
  2. matt_ccre
    Ice Cream Sandwich Dec 24, 2019
    matt_ccre , Dec 24, 2019 :
    Cool. Ultimately, if it works for your needs, that's all that really matters...
    Artemus. likes this.
  3. MasterRms
    Cupcake Dec 24, 2019
    MasterRms , Dec 24, 2019 :
    when I use the keyboard it is higher then on other versions and I have a black bar at the bottom of the screen and it's annoying.
    how can I disable the black bar?
  4. N1577215009520
  5. H1577170989311
    H1577170989311 , Dec 24, 2019 :
    thanks, however formatting is the last point of resort. problem here is the pictures you have taken after an upgrade are also not visible in gallery. this seems to be some sort of bug which developers would need to fix asap.
  6. Raresch
    Raresch , via OnePlus 6 Midnight Black , Dec 24, 2019 :
    that I can't do. try to to settings, apps, Google duo and press force stop. the go to storage and press clean cache and the turn off the phone and power back again.
  7. F1542624337174
    F1542624337174 , Dec 24, 2019 :
    Hello from Greece.
    Today I found a funny but annoying bug on 10.3.0 (6T). The capital letter "Σ" is shown as "C" after updating....
    I would like to keep that in mind for the next update
    Thanx!!
  8. T1557410190433
    T1557410190433 , Dec 24, 2019 :
    i have so many Problems ):
    1. the Display colour is pale and grayish (it ist not in nightmode or readingmode)
    2.under the Keyboard is a space.
    3. the Animations are Not Fluid
    4. Buttons are Missing.
  9. E1541267984702
  10. Boubaker01
    Gingerbread Dec 24, 2019
  11. Boubaker01
  12. ironass
    Lollipop Dec 24, 2019
    ironass , Dec 24, 2019 :
    Did you not update your GCam to the Android 10 version after you updated as the Android 9 version is not compatible. See...
    https://forums.oneplus.com/threads/...7-t-pro-6-t-5-t-and-3-t.911532/#post-19197460
    F_João_Martins_qwbE likes this.
  13. Biswajit Padhi
    Froyo Dec 24, 2019
    Abhilash.D likes this.
  14. ShaunTheBeast
  15. Gerrit Rijneker
    Eclair Dec 24, 2019
    Gerrit Rijneker , via OnePlus 6 , Dec 24, 2019 :
    i had the same problem.
    HAD
    because after switching off i could use Playstore normally.
    E1541267984702 likes this.
  16. M1577219700899
    M1577219700899 , Dec 24, 2019 :
    I have received the update, It work well and fast, but i don't like the new gap in the bottom of keyboard.
  17. Abhilash.D
    Eclair Dec 24, 2019
    Abhilash.D , via OnePlus 6 , Dec 24, 2019 :
    all the dark theme supported apps turning into dark mode :( i didnt find option for Insta but for other apps like gmail and play store etc ... open gmail and select settings there u can change normal mode
  18. N1577216484670
    N1577216484670 , Dec 24, 2019 :
    thanks)
  19. Jamze
    Jamze , Dec 24, 2019 :
    Post 5188? You only mention one thing. That it needs to be optimised?
    Several days in, still working perfectly for me.
    Trevor.Hawkes and Artemus. like this.
  20. V1534661223711
