732
OxygenOS 10.3.0 for the OnePlus 6 and 6T
  1. H1567891960897
    Cupcake Dec 24, 2019
    H1567891960897 , Dec 24, 2019 :
    Finally got 10.3.0 update after VPNed to India. Otherwise wouldn't have received it until a later time. So far so good. like Android 10 ne1 gesture features.
  2. seahero
    Froyo Dec 24, 2019
  3. Sravan Muralidharan
  4. X1577115143196
    X1577115143196 , via OnePlus 6T , Dec 24, 2019 :
    This update is quite good as it had resolved the fingerprint issue in OP6t . Also the new layout is amazing with good features, However I am facing a critical problem of battery draining super fast after this update as after charging 100% the battery gets reduced to 20% just in few hours unlike previously when it used to last for almost one and a half day. It is to be noted that I have not installed any battery draining app after installing this update.
    Please One Plus Team resolve this issue ASAP as it is a critical issue and is creating lot of problems .
    B1575233054994 and Santoshtheone like this.
  5. D1577007991726
    Eclair Dec 24, 2019
    D1577007991726 , Dec 24, 2019 :
    Yes, go to page 324 for my opinion..
    Santoshtheone likes this.
  6. E1541267984702
    E1541267984702 , Dec 24, 2019 :
    thank you
  7. X1577115143196
  8. Z1577220706701
    mikekacz and martian-balu like this.
  9. Lu00765
    Froyo Dec 24, 2019
    Lu00765 , via OnePlus 6 , Dec 24, 2019 :
    OnePlus really ruined the selfie camera in every android 10 build (including this one) for the OnePlus 6. every photo taken with the front camera has weird blue coloring around the edges. it seems like software designed to brighten up the edges, but it fails miserably. I've tried every single problem fixing step you usually need to take, even going as far as factory resetting and the problem is still present. after downgrading the front camera is perfectly fine... and I'm not even the only one with this issue on a OnePlus 6. I really hope OnePlus fixes this in the next update because apps like Snapchat are a joke,quality-wise, with this update.
  10. X1540794839032
    Eclair Dec 24, 2019
    X1540794839032 , via OnePlus 6T , Dec 24, 2019 :
    use the roboto font. it's included in the image and shows the capital Σ as it should.
    ironass likes this.
  11. D1577007991726
    Eclair Dec 24, 2019
    For 5: no, it's impossible to avoid yellow tint with every setup...go page 324 for my opinion with this problem
  12. Actify
    Donut Dec 24, 2019
    Actify , via OnePlus 6T , Dec 24, 2019 :
    the phone will usually see a battery life drop the first few days after a big update but will usually return to normal within a week.
    Artemus. likes this.
  13. Shrinath Rathi
    Eclair Dec 24, 2019
    Shrinath Rathi , Dec 24, 2019 :
    there's an issue with the keyboard. it's a bit elevated from bottom chin and there's a gap in between those 2 which wasn't there earlier and is causing inconvenience
  14. Ghayas_Ali
    Shay+ likes this.
  15. G_Earcandy29_AlXF
    G_Earcandy29_AlXF , Dec 24, 2019 :
    There's this extra space below the keyboard after the update on my 6T. It does look really annoying and is kinda uncomfortable. Would be good if you guys could remove it in the next update🤷🏻‍♂️
  16. Raresch
    Ice Cream Sandwich Dec 24, 2019
    Raresch , via OnePlus 6 Midnight Black , Dec 24, 2019 :
    then submit a feedback to oneplus through the community app.
    I always used P3 colors. seemed the more natural for me. I did a photo with the camera and selected the most accurate representation of what I was seeing on the screen with what I was seeing in the real life.
    D1577007991726 and Artemus. like this.
  17. Artemus.
    Community Hero 2020 Dec 24, 2019
    Artemus. , Dec 24, 2019 :
    I suggest searching before bringing this up for the thousandth time. You'll get an answer a LOT faster.
    ade0410, phon3Xx, ironass and 3 others like this.
  18. Q1533492076261
    Donut Dec 24, 2019
    Q1533492076261 , Dec 24, 2019 :
    Did the screen calibration changed after the update, and got a bit yellowish, or am I the only one ?
  19. Mayank Poddar
    Donut Dec 24, 2019
    Mayank Poddar , via OnePlus 6 , Dec 24, 2019 :
    Ever since the 10.3.0 update the apps are likely to become unresponsive. Even my G-cam crashes everytime i opens it. The apps transition effects have also become quite a slow since the update.
    B1575233054994 and Boubaker01 like this.
  20. Jamze
    Jamze , Dec 24, 2019 :
    Search this thread and you'll find you are not.
    Mayank Poddar likes this.
