732
OxygenOS 10.3.0 for the OnePlus 6 and 6T
  1. Artemus
    Junior Moderator, Community Hero 2020 Junior Moderator Dec 25, 2019
  2. dkburma
    Cupcake Dec 25, 2019
    dkburma , Dec 25, 2019 :
    Post updating the software I am unable to use data services on slot 1.
    I can use data services on sim slot 2 using Jio.
    please help!!
  3. Esteveira
  4. F_Rohan_Satam_ReNp
  5. AdemJ
    Eclair Dec 25, 2019
    AdemJ , via OnePlus 6T , Dec 25, 2019 :
    Unfortunately I didn't find it!! Could you send me a screenshot from your phone?!
  6. Artemus
    Artemus , Dec 25, 2019 :
    Caoimhín, drl431 and Adem.J like this.
  7. Sanjay Khade
  8. Amitanchal
    Donut Dec 25, 2019
    Amitanchal , Dec 25, 2019 :
    I am not able to set ringtone for Whatsapp Incoming call after upgrading to Android 10 in my One Plus Six Phone.
  9. Arshadh_
    Donut Dec 25, 2019
    Arshadh_ , Dec 25, 2019 :
    I got the update just now, but im not sure if i should download it cuz many of yall are having trouble after updating. Should i do it or not ? :/
    santosh45 likes this.
  10. AdemJ
    Eclair Dec 25, 2019
    Artemus likes this.
  11. D1574947523155
    D1574947523155 , Dec 25, 2019 :
    Too many features are missing on this new update, I & most of the other user need double tap wake-up & sleep screen with vibration effect.
    It was available in previous version, any luck with this new update?
  12. D1574947523155
    you are correct, will recommend you to wait for some time. there are too many unwelcomed changes.
  13. robin143
    Honeycomb Dec 25, 2019
    robin143 , Dec 25, 2019 :
    Atleast Pls tell me how to disable that sound durring call when notification arrives. Without silent mode or DnD mode
  14. G_Mike_Royal_BPFm
  15. Artemus
    Best bet: turn on silent mode while in a call. Seems to only happen in Ring mode.
    Caoimhín likes this.
  16. ironass
    Lollipop Dec 25, 2019
    ironass , Dec 25, 2019 :
    A little knowledge is a dangerous thing.
    I am guessing that you used the Oxygen Updater because you have now switched from the official, stock, OnePlus OxygenOS, 10.0.1, to the Open Beta 32 testing firmware. You will no longer receive the official, stock, OxygenOS updates OTA until you switch back by installing 10.3.0.
    Caoimhín and drl431 like this.
  17. robin143
    Thats difficult all the time...
  18. santosh45
    Froyo Dec 25, 2019
    santosh45 , via OnePlus 6T , Dec 25, 2019 :
    Totally agree with you on keyboard space issue and slow animations. The hidden space drawer isn't so smooth now too. I'm also facing issues working simultaneously with both sim at same time. I hope this gets fixed soon in future updates.
  19. Shyamgoud19
    Shyamgoud19 , Dec 25, 2019 :
    No it's not a fix of wifi connection it's crashed the wifi connections
    After update wifi is not connecting and and if it connected then disconnecting immediately! Not satisfied with update @OnePlus
  20. Arshadh_
    Donut Dec 25, 2019
    But will i receive future updates if i dont update to 10.3?
