732
OxygenOS 10.3.0 for the OnePlus 6 and 6T
  1. bunthoen
    Donut Dec 25, 2019
  2. URM72
    Cupcake Dec 25, 2019
    URM72 , Dec 25, 2019 :
    after the update all my bank application I have to register again
  3. Geomlord
    Gingerbread Dec 25, 2019
    Sid_Sindhia likes this.
  4. T1528289336798
    bjorg18 and Sid_Sindhia like this.
  5. thakkar.darpan
  6. dm00389731
    Honeycomb Dec 25, 2019
    dm00389731 , via OnePlus 6T , Dec 25, 2019 :
    in india i think not supported ,i am using jio and idea both sims but this option is not showing
  7. sai@2212
    sai@2212 , Dec 25, 2019 :
    before Android 10 update I was able to view video icon and make video calls but after Android 10 update I am unable to view video icon
  8. sai@2212
  9. soopertrouper
    soopertrouper , via OnePlus 6T , Dec 25, 2019 :
    hi, I seem to have received the update and Installed it but I'm unable to link IMEI to activate my redcable club account. The community app keeps notifying me to update to latest version and the. tells me that I'm updated but still refuses to link.
  10. aaronvarghese
  11. Sid_Sindhia
    Donut Dec 25, 2019
    Sid_Sindhia , via OnePlus 6 , Dec 25, 2019 :
    I didbt like new navigation bar.
    I was using the menu and back button style which you have removed. new one is glitchy to use . if there is someway i can get the navigation bar style which you gave previously
    akhil221 likes this.
  12. Sid_Sindhia
    Donut Dec 25, 2019
  13. abtExp_
  14. Sid_Sindhia
    Donut Dec 25, 2019
    yes i am facing the same problem. also with navigation bar which i used before was more simpler
  15. Sid_Sindhia
    Donut Dec 25, 2019
    looks like you updated new problems instead OS . I lost my navigation bar style which i was previously using which was very suitable for me . hidden space is become very hard to open .... I wasn't able to open it for 30 min after update
  16. Raghu2706
    sai@2212, leoflorov and Caoimhín like this.
  17. H1529767936257
    H1529767936257 , Dec 25, 2019 :
    facing ringtone issue after the update. there is a default bell ring. even if I have changed my tone several times. anyone facing the same issue on OP6 ?
  18. Diwak91
    Diwak91 , Dec 25, 2019 :
    ring vibrate silent button on the right side above power button ...as it does not shows silent mode when i put this mode... instead it shows vibrate symbol only after Android 10 update for 1plus 6t..can any one help how to sought it out!
  19. creed90
    Donut Dec 25, 2019
    creed90 , via OnePlus 6T , Dec 25, 2019 :
    Just updated to this from beta. Dose any one here uses Mi4a giga version global router cause I can't seem to find my 5ghz wifi. Had this problem with the beta one also so decided to move to this and still the problem is there. Also one of my oppo A5s is able to see and connect with 5ghz wifi.
  20. Tomas891221 likes this.
