732
OxygenOS 10.3.0 for the OnePlus 6 and 6T
  1. Boubaker01
    Gingerbread Dec 25, 2019
  2. G1571122249284
    Cupcake Dec 25, 2019
    G1571122249284 , Dec 25, 2019 :
    Per prima cosa buon natale a tutti, sotto la tastiera dopo l'aggiornamento, mi resta lo spazio he prima non c'era, in più nella lockscreen il display ambient non mi mostra più l'orologio ma solo il finger print. Problemi di aggiornamento o di impostazioni?
  3. Mojobalkan
    Froyo Dec 25, 2019
    Mojobalkan , via OnePlus 6T , Dec 25, 2019 :
    Strange,it should open up Google assistent.
    Try swiping up in the left or right corner.
    when i swipe in those corners it brings up my Google assistent as it should.
  4. X1577276266372
    X1577276266372 , Dec 25, 2019 :
    screen flickers when opening the lock screen. also when alarm starts ringing, screen wont open and only sound can be heard. after that you cant open your screen because its frozen and you have to press some buttons to restart the phone. also those button actions will come delayed so it takes time even to your phone to be on again. how am i supposed to use the alarm when this happens?????
  5. B1532833445885
    B1532833445885 , Dec 25, 2019 :
    Using this update since last 2 days and its totally unacceptable. Everything changed in a bad way, way too many bugs. Looks like One Plus rolled it out in a hurry without in-depth testing. Here are some of the bugs I found and hope One Plus do it right immediately:
    1. Most important is change in privacy, the apps which are under app locker, their contents should be hidden until the app is open with security passcode. After update, the contents are visible for the apps which are under app locker.
    2. Settings of Wallpaper resolution changed and there is no way to fix it.
    3. Under Phone app (for calling), the three tabs i.e. speed dial, call history and contacts are not switching on sliding and we have to click on the particular tab to reach. Very irritating when you have some habit and suddenly it is changed and that too not for good.
    4. Navigation gestures are lagging and not good after update.
    5. The OS seems now heavy as battery is consuming really fast.
    6. Further, charging time has been increased. It usually took 1.5 hours from 0-100 but now it takes more than 2 hours from 13-100.
    There are many other bugs which I will share later.
    One Plus team, please resolve these issues as these are very important.
  6. F1544361667585
    Eclair Dec 25, 2019
    F1544361667585 , Dec 25, 2019 :
    This update is garbage, brain drains like no tomorrow. Can't see any photo in gallery even after clearing cache and restarting the phone. Can't update and install any app in play store, chrome gets closed after 1 minute, MX player gets stuck on front screen, WTF One Plus? (using OP6)
    SirWesley and dineshinehkn like this.
  7. F1544361667585
    Eclair Dec 25, 2019
  8. vsuresh351
    vsuresh351 , via OnePlus 6 , Dec 25, 2019 :
    after updating to 10.3 my one plus 6 is not able to detect earphones properly. i need to plugin 3-4 times for it to play through earphones even when the headphones sign appear on quick settings bar.
  9. supyaesone
    supyaesone , Dec 25, 2019 :
    Can someone pls tell me how to go into split screen mode in the left right navigation gesture?
    Used to be able to easily do so with the swipe up navigation feature with the two button navigation bar but it was removed :(
  10. E1552151603210
    E1552151603210 , Dec 25, 2019 :
    This new update has drastically harmed my 6T (went from Android 9 directly to OxygenOS 10.3.0). I'm unable to take screenshots now. All screenshots I take sit on "Screenshot is being saved" and don't stop no matter how long it sits there. I've literally lost the ability to screenshot anything.
    The touch screen is acting weird now. Frequently it outright doesn't register my touches.
    The update mysteriously shoved my keyboard up ever so slightly. It's been shoved up by a few millimeters, which doesn't sound like a lot but it's drastically noticeable when typing. How do you even do that?
    My phone is now overheating despite the fact I don't have any apps open, so that's another win for this new update. My phone has never heated up in my hands before, no matter what I was doing, and now it's overheating for no reason with nothing open.
    Can you please fix this? It's seriously acting up and I've lost a lot of functionality.
  11. preetraghav
    preetraghav , Dec 25, 2019 :
    After android 10 update mobile network is not working in most of my apps in my Oneplus6 like playstore, Pubg, Clash Royale. Please help!!
  12. mohiter4
    mohiter4 , via OnePlus 6 , Dec 25, 2019 :
    Hiding notch option is a joke with 10.3.0 update.
    Unlike android 9, option hides the notch complely and do not use it even for showing the date an other status bar icons.
    It just blacks it out, disable that space making it useless.
    @petelau and Oneplus, we are degrading the software here !
    E1552151603210 likes this.
  13. Martzie_T8
  14. I1577292681692
    I1577292681692 , Dec 25, 2019 :
    Before the update I had only one Gpay app and now I have two. It says the new one is default now. Where can I raise this issue?
  15. F1577203603335
  16. Ananthcnair
  17. Auristic
    Lollipop Dec 25, 2019
    ironass likes this.
  18. Y1574959810489
    Y1574959810489 , Dec 25, 2019 :
    Have trouble with the new update. I use a 6T McLaren phone.
    1. The colors are too deep & hurt the eyes. I prefer the muted colors of the previous version.
    2. The home time shows to be an hour from now. This happened twice today. I have a widget on my home screen.
    Look forward to getting the above fixed.
  19. Ananthcnair
  20. G_Tanu_P_jKEB
