732
OxygenOS 10.3.0 for the OnePlus 6 and 6T
  1. Ajay Chigurupati
    Cupcake Dec 26, 2019
    Ajay Chigurupati , via OnePlus 6T , Dec 26, 2019 :
    Notch implementation is better on Android 9 version, current implementation
    stands out and shows an empty space.
    Why the slide gesture is removed from Phone app? I should click on recent tab instead of swiping left.
    Linxx and Rahulyadav12345 like this.
  2. M1551141243456
    M1551141243456 , via OnePlus 6T , Dec 26, 2019 :
    Hi all
    Is anyone having problems with the finger print my OnePlus 6t is not reading my finger print. I thought it was because of my job getting dirt and damaged skin. I had my wife try and add her finger print but it won't work at all.
  3. F1547965384613
    F1547965384613 , Dec 26, 2019 :
    The update shows that connecting over 5GHz WiFi network has been solved how ever I am still unable to find my wifi which is 5GHz.
    please fix this issue ...
    one plus 6t , McLaren's edition.
  4. amitsahoo106
    Donut Dec 26, 2019
  5. Z1533406860757
    Z1533406860757 , Dec 26, 2019 :
    Hi I just updated to 10.3.0 and I noticed that there is no way to change the ambient display clock. I had it on analog before the update and now it's that only. Is that part of the update or is there a way to change it?
  6. J1534102027900
    J1534102027900 , Dec 26, 2019 :
    there is serious font issues and one plus 6 can't read Hindi messages and also ,things like widget, weather,sound recorder and notes are missing in the update.
  7. Y1528135568342
  8. Viralmohite
    Viralmohite , Dec 26, 2019 :
    in my camera it is not available.
  9. King2468
    Gingerbread Dec 26, 2019
    King2468 , Dec 26, 2019 :
    impossible
    have you installed the usb drivers?
  10. JAGADISH BHATTA
    Jelly Bean Dec 26, 2019
  11. L1577342346697
    L1577342346697 , Dec 26, 2019 :
    I'm very disappointed about the latest release.
    I cannot use Wi-Fi hotspot at all. There is no connection to internet. Sometime it works but then the internet connection on my mobile phone (Oneplus 6T) is lost (My work depends on this feature).
    Camera is freezing while using.
    "AP band" displays nothing as options. It is supposed to be 2.4 GHz Band or 5.0 Gbz Band.
    V1561179258865 likes this.
  12. F1544361667585
    Eclair Dec 26, 2019
    F1544361667585 , Dec 26, 2019 :
    I updated to A10 on Christmas, and it literally crippled my OP6.
    There are so many problems and I have probably not discovered all of them.
    1) I cannot download and update ANYTHING from play store, it crashes in a minutes after being opened.
    2) Cannot take screenshots, it just stucks and gets failed.
    3) Gallery doesn't show a single image.
    4) File Manager doesn't show anything. Other 3rd party file managers works but crashes in few minutes.
    5) Chrome crashes after being opened for a minute.
    6) When connected to pc for backup, I am not able to see my device but only empty CD drive for that, all the drivers are installed in control manager, and I am using file transfer mode. So, can't even take the backup from USB. Also, now my developer options is invisible!
    7) Battery drain is horrible.
    I tried clearing cache from recovery mode, but nothing got solved. I restarted phone probably thousands of times now, but no issue is resolved. **** this update.
    EsthayJ43 likes this.
  13. LegolasX
    Aashisheyeish likes this.
  14. F1544361667585
    Eclair Dec 26, 2019
  15. G1577343522217
  16. JAGADISH BHATTA
    JAGADISH BHATTA , Dec 26, 2019 :
    Report your issue here https://forums.oneplus.com/feedback/
  17. JAGADISH BHATTA
    Camera version?
  18. JAGADISH BHATTA
