731
OxygenOS 10.3.0 for the OnePlus 6 and 6T
  1. EsthayJ43
    Donut Dec 26, 2019
    EsthayJ43 , via OnePlus 6T , Dec 26, 2019 :
    At the moment I can't figure out any way to transfer files to PC via USB or otherwise. I did manage to get it backing up to Google Drive though after some initial problems so that's probably the best I'm gonna get.
  2. C1534597742546
    Cupcake Dec 26, 2019
    C1534597742546 , Dec 26, 2019 :
    I am using OnePlus 6
    After the upgrade my ringtone has been changed by itself.
    And all the ringtones provided are changed to a single one.
    So, how can i fix this issue.
    daanand likes this.
  3. prathap38509
    Donut Dec 26, 2019
    prathap38509 , via OnePlus 6T , Dec 26, 2019 :
    There's no point of living with the changes which are less productive and creates lag in the user experience. In the previous basic versions of Android we have used the menu options at the bottom but in recent updates swiping from the bottom for menu creates extra space and looks simple and sophisticated.
    and finally I agree with your point of learn to live with the changes and that changes must be creative and productive and leads to advanced versions not to the basic old versions.
    G_Harsh_Jain_OpRX likes this.
  4. Z1533406860757
    Z1533406860757 , Dec 26, 2019 :
    hahaha thank you. I can't believe I missed that.
    Terrathaw likes this.
  5. rajesh9010 , via OnePlus 6T Mirror Black , Dec 26, 2019 :
    after the update do any one feel battery drains fast and if u open an app with fingerprint scanner security
    just go back, fingerprint scanner will be displaying 1sec in hime screen
    this 2 prlms I'm facing since the update
  6. King2468
    Gingerbread Dec 26, 2019
    King2468 , Dec 26, 2019 :
    I try to use usb to transfer files to pc. I never try it in a10
  7. keshav2640
    keshav2640 , Dec 26, 2019 :
    Dear recipient,
    Im facing ultra lagging animations and frame rate drops on my OnePlus 6 after software update....plz help me fix it... I've cleared the cache and also tried restarting the device but it does not help.
  8. E1535482230150
    Donut Dec 26, 2019
  9. Terrathaw
    Eclair Dec 26, 2019
    Terrathaw , Dec 26, 2019 :
    It's okay. A lot of people are confused by this apparently. And rightly so. Because, logically, one would expect the customisation of the ambient display to be in the settings option called "Ambient Display". I have no idea why they didn't make it possible to change it in both places.
    Z1533406860757 likes this.
  10. Aashisheyeish , via OnePlus 6T Midnight Black , Dec 26, 2019 :
    How fast is it draining ? Can u show me the screenshot ? And i haven't downloaded Android do you suggest to download or not ?
  11. ManuBK
    ManuBK , Dec 26, 2019 :
    are you advising to use this slider for brightness adjustment?
  12. rajesh9010 , via OnePlus 6T Mirror Black , Dec 26, 2019 :
    it's just showing 5 hours left for 25% charge
    Aashisheyeish likes this.
  13. Q1577345648956
    Q1577345648956 , Dec 26, 2019 :
    after updating to android 10
    Time on screen not getting updated automatically but on top left time showing correctly. on screen showing 11:33 and top left 1:05.
  14. Aashisheyeish likes this.
  15. EsthayJ43
    Donut Dec 26, 2019
    Well it doesn't work via USB at all in Android 10 if that's what you're referring to. The phone will only show up as a CD drive in Windows explorer and device manager and it won't allow you to manually install the drivers as anything else either.
  16. peddivg
    SMSHAHRUKH likes this.
  17. imkathi07
  18. thrubovc
  19. HermanHu
    Froyo Dec 26, 2019
    HermanHu , Dec 26, 2019 :
    my op6 already get 10.3.0 update.. almost as smooth as 9.0.9 but battery life a bit less then 9.0.9
