732
OxygenOS 10.3.0 for the OnePlus 6 and 6T
  1. Artemus.
    Community Hero 2020 Dec 26, 2019
    drl431 and Vivan009 like this.
  2. The1Lion
    Marshmallow Dec 26, 2019
    The1Lion , Dec 26, 2019 :
    You typically get a notification on the phone when connected via USB that allows you to set the connection type or if you have developer options you can use the menu options to set the transfer type.
    Artemus. likes this.
  3. skukku2
    Cupcake Dec 26, 2019
    skukku2 , Dec 26, 2019 :
    After updating to Android 10 not able to connect to the laptop through data cable..plz help..
  4. SHGOVI
  5. Benjamin Leo
    Froyo Dec 26, 2019
    Benjamin Leo , Dec 26, 2019 :
    if you're facing any minor bugs try wiping cache partition after every update, it will probably solve most of the problems you're facing.
  6. E1577367439433
    E1577367439433 , Dec 26, 2019 :
    Issues with this roll out:
    OnePlus 6 in Australia on Vodafone network, 4G continuously disconnecting and wifi strength and connection very volatile
  7. A1564749442755
  8. V1559402471921
    V1559402471921 , Dec 26, 2019 :
    Anyone with this?
  9. bhako111
    bhako111 , Dec 26, 2019 :
    Today I have received update on my oneplus 6T (OxygenOS 10.3.0). my office network is secure via binding MAC address. I can't connect to my office wi-fi after today’s update. I have found that my mobile device MAC address has changed. I can’t find device MAC address under SETTING> ABOUT PHONE > STATUS ….. I have seen that wi-fi MAC address “unavailable” in status page. I have found MAC address on Wi-Fi preference page….How it is possible?
  10. Z1577367807763
  11. Artemus.
    Artemus. , Dec 26, 2019 :
    The MAC address changed with the update, you're going to have to readd the address.
  12. V1549874485479
    V1549874485479 , via OnePlus 6 , Dec 26, 2019 :
    Smile capture feature while taking selfies is removed from the system after upgrading to OxygenOS. When can it be again loaded to the system. Ideally original features should not be removed while upgrading. Smile capture is the feature which makes the phone different from other brands. now it is not there in oneplus6 too. I am very disappointed with this update.
  13. JasmineLanei
    JasmineLanei , Dec 26, 2019 :
    So my OP6 updated today and in the alternate user, the button navigation bar is the default setting and i cannot replace it with gestures. Still using gestures in the admin account and it works fine. I would hate relearning these old navigation button stuffs. :(
  14. j.bahrudeen
    Gingerbread Dec 26, 2019
  15. G_Yashpal_Rana_VwKA
    D1570607660686 likes this.
  16. G_Simran_Panchal_8402
  17. MAHESHRM
  18. marcozwetsloot
    Eclair Dec 26, 2019
    Boubaker01 likes this.
  19. G_Manoko_Torqe_bZCm
  20. ParveshChauhan
