728
OxygenOS 10.3.0 for the OnePlus 6 and 6T
  1. E1538762150024
    Cupcake Dec 29, 2019
    E1538762150024 , Dec 29, 2019 :
    Hi
    I have Android 10 and Oxygen 10.3.0
    Now my OnePlus 6 crashes a lot and apps have started to stop working and crash.
    Can you help me
    martystagram likes this.
  2. Prince Ogaga
    Froyo Dec 29, 2019
  3. Prince Ogaga
    Froyo Dec 29, 2019
    Prince Ogaga , Dec 29, 2019 :
    Damn, these guys are good.. Oneplus should hire these guys to help them, ain't no shame if they help them get better. I will stick to my Pie OS till they sort out these bugs. I miss the days when OP releases an update and everyone gives absolutely positive comments and I will be so eager to update my phone.. These days I am so afraid after solving my massive battery drain issues with the help of some great guys here.. Its the last Sunday of the decade guys, let's rejoice and be happy.
  4. SruthiVyamasani
    SruthiVyamasani , Dec 29, 2019 :
    Their is no option called smart content detection, could you please help me with the following steps
  5. martystagram
    martystagram , via OnePlus 6T , Dec 29, 2019 :
    Thank you for the updates, bit please be aware there are lots of bugs at present with the 6T + Android 10 + other apps. E.g. Instagram won't access photos very well. The OnePlus camera stops working quickly too.
  6. Artur101
    Honeycomb Dec 29, 2019
    Artur101 , via OnePlus 6 , Dec 29, 2019 :
    The update on my device went very smoothly too.
    Apart from what you mentioned in your comment, I'd just add a couple of more things that need some additional adjustment after the update:
    - if you notice that the screen is too dim to your liking you may need to adjust it manually for a few times in different lighting conditions so that the sensor and the software "learns" your preferences. The auto-brighness should work fine then
    - you may also notice the colours on your screen got somewhat oversaturated after the update. That is something I personally have a bit of an issue with as I'm not big fan of very saturated and flashy colours. You may need to go back to the colour profiles in the settings and choose a different profile that'll suite you better
    Other than that I didn't have any major issues or problems with the update. Well, maybe except for new notch hiding implementation. I hope they change it in the next update.
    Oh, and people, please stop whining about the gap below the keyboard, it's really not a big deal! LOL
    Well done, OnePlus Team!
    Andreas Rauchhaus and Caomhin like this.
  7. SruthiVyamasani
  8. Navneet Bhargava
    Navneet Bhargava , via OnePlus 6 , Dec 29, 2019 :
    in previous OS if we enable notch functionality then we are allow to choose which app use full screen or which not but after update in this names of application is not present like YouTube, wps, games etc is this is bug or something else
    ps i have done hard reset, clear catch and also reinstall apps, reboot several times, and i have update software way back 1 week ago
  9. King2468
    Gingerbread Dec 29, 2019
    King2468 , Dec 29, 2019 :
    hold yr finger when tapping the object
  10. King2468
    raised keyboard is general bugs in a10, not only op occur
  11. Artur101
    You're wrong, it's not a bug, it's how it's supposed to be. Why don't you read other comments on this forum or investigate elsewhere to find out? I'm getting tired of explaining this over and over.
  12. SruthiVyamasani
    Caomhin likes this.
  13. M1577604591944
    M1577604591944 , via OnePlus 6T , Dec 29, 2019 :
    Sir .....the wifi network which I was very smoothly using before this update .....I m not able to connect to that wifi again.... Although my all other friends are using that wifi network without any issues. Please help me solve this issue
  14. DevilRoks
  15. tarinimishra
    Froyo Dec 29, 2019
  16. R1550506797264
    R1550506797264 , via OnePlus 6 , Dec 29, 2019 :
    you have to select use device mac address rather than use randmise mac address...may be this will solve your problem
    Caomhin likes this.
  17. CoachN1
    CoachN1 , Dec 29, 2019 :
    Have you MAC filtering on your wifi? If yes, in new rom was randomly switched MAC address of your phone, set new MAC on router and it should works
    Caomhin likes this.
