731
OxygenOS 10.3.0 for the OnePlus 6 and 6T
  1. ironass
    Lollipop Dec 30, 2019
    ironass , Dec 30, 2019 :
    Since downgrading from Android 10 to Android 9 will wipe your phone, why not do a Factory Reset on 10.3.0 to see if that solves your issues first. Failing that...
    DOWNGRADE FROM ANDROID 10 TO ANDROID 9
    You will need to use the roll-back firmware which will wipe your phone and downgrade you to Android 9.
    See downloads and instructions for both OnePlus 6 & 6T, rollback firmwares...
    [GUIDE] Rollback/downgrade from OOS Android 10/Q to stable 9/Pie
    You can then download the the latest Android 9 stock Oxygen OS from here to upgrade to the most recent Android 9 release for the 6 & 6T by using Local Upgrade on the phone.
    (The above links DO work. If you cannot open them using the OnePlus Community app, switch to your Google Chrome browser)
    drl431, Artemus. and Caomhin like this.
  2. D1562524685932
    Cupcake Dec 30, 2019
  3. kvladan
    Froyo Dec 30, 2019
  4. Artur101
    Honeycomb Dec 30, 2019
    Artur101 , via OnePlus 6 , Dec 30, 2019 :
    Very good and honest overview of the update [e]1f44d[/e]
    Caomhin and mik29194 like this.
  5. R1559202045688
    R1559202045688 , Dec 30, 2019 :
    Any chance of getting 2 button navigation back from previous oxygenOS?
    3 button navigation is really bulcky and ugly, plus it takes a lot of screen space.
    Gesture navigation is really wierd. Tried to use it for a week - ultra uncomfortable, cant get used to it, always accidently pressing some wrong buttons.
    The "new" one button/semi gesture navigation is total nonsense.
    Please, just bring back 2 button navigation as an option!
  6. jushtrek
    jushtrek , Dec 30, 2019 :
    there's a huge glitch after this update. I'm facing glitches while playing games as standard as 8ball pool and normal less resolution games. please look into this and fix the bugs. I was happy with my older version.
  7. Artemus.
    Nougat Dec 30, 2019
    Artemus. , Dec 30, 2019 :
    You always have the option of downgrading.
    Caomhin and ironass like this.
  8. W1565553594891
    W1565553594891 , Dec 30, 2019 :
    after update 10.3.0 camera application is hanging..when trying to take selfie switch to front camera it's stuck so have to close application totally and have to relaunch again..
    I don't know this is a bug or application fault but i am getting this issue again and again.
  9. Trevor.Hawkes
    Ice Cream Sandwich Dec 30, 2019
    Trevor.Hawkes , Dec 30, 2019 :
    I'm sure that with such an in depth bug report the OnePlus development engineers will be onto it already.
    Nothing you've said in your post suggests for one moment that Oxygen is causing your problems.
    RogerOriginals and Caomhin like this.
  10. Hakkeeb
  11. G_Karothikeyan
    G_Karothikeyan , via OnePlus 6 , Dec 30, 2019 :
    Mine works very well...
    ensoniqeps likes this.
  12. P8505893412
    Eclair Dec 30, 2019
    P8505893412 , via OnePlus 6 , Dec 30, 2019 :
    by when will get the update..previously it's not happened .after announcement, update usually comes within a week but this time it's been more than 10 days and still waiting ..please confirm, one plus team...
  13. C1541509160316
  14. M1544478630722
    M1544478630722 , Dec 30, 2019 :
    major bugs after i updated. Oneplus PLEEEEASE HELP!!!!.
    - Chrome crashes every 30 seconds or so, and
    - i cant updated any apps in Play Store, it crashes everytime i try to update.
    - Running extremely hot even when not doing anything
    thanks
  15. doug77
    doug77 , Dec 30, 2019 :
    O espaço em branco a baixo do teclado ainda não foi corrigido, ele é estranho e incomoda muito, além de açúcar um espaço da tela q poderia ser usado para visualização de conteúdo. Muito chateado com isso
  16. radu.dorin13
    Froyo Dec 30, 2019
    radu.dorin13 , via OnePlus 6T , Dec 30, 2019 :
    I've had the same experience and I also have not encountered issues posted here on the forum. Hence, random system. lagging is still present from time to time which is annoying. this wasn't happening before on A9.
  17. Caomhin
    Marshmallow Dec 30, 2019
    Caomhin , via OnePlus 6T Mirror Black , Dec 30, 2019 :
    Sorry I may have hit the wrong reply button. I really must keep my glasses on. [e]1f631[/e]🤪[e]1f44d[/e]
  18. RogerOriginals
    RogerOriginals , via OnePlus 6T Mirror Black , Dec 30, 2019 :
    Try this, it works. I tried it on mine.
    https://www.androidpolice.com/2019/...plus-7-and-7-pro-running-android-10-beta/?amp
  19. U1577735704941
    U1577735704941 , Dec 30, 2019 :
    After installing oxygen 3, my OnePlus 6t McLaren became extremely slow...it is very strange, before it was my fastest phone ever...? Battery drainage became very fast, if I am typing I have to wait 2-3 seconds after each letter appear..after rebooting , in 5 min phone again starts to be very slow..I have already found a lot of similar claims of oxygen 3, people are looking how to get back to Android 9 version..
  20. Anupam2511
    Anupam2511 , Dec 30, 2019 :
    I'm using gesture navigation since 6T launch. I'm very well used to it. But with the new update, if I'm watching a movie or playing game in full screen mode or even playing YouTube video in full screen, the moment I swipe for 'back' option, it lands me to home screen everytime. But when I watch the same video on YouTube in normal mode (when you can scroll suggested videos), and then I swipe up for 'back', it works properly.
