731
OxygenOS 10.3.0 for the OnePlus 6 and 6T
  1. K1577634318742
    Cupcake Dec 31, 2019
  2. A1541373622202
    A1541373622202 , Dec 31, 2019 :
    My Bluetooth is all messed up since the update. not showing any previously connected devices. Help!!
  3. radu.dorin13
    Froyo Dec 31, 2019
    radu.dorin13 , via OnePlus 6T , Dec 31, 2019 :
    swapnil.s
    Sorry if this is a repost but is anyone having issues with screen stuttering on OnePlus 6?
    Whole UI stutters, no matter which app you use. It kind of goes away with a restart but fix is not permanent. I have also wiped my phone's cache from advanced boot up menu but no help.
    I first noticed this issue with 10.0.1 update and was hoping that it would get fixed 10.3.0​
    Hi there, I have it too. OP 6T, 6GB version if that matters. What system navigation are you using? (i.e.: new gestures, three buttons, op gestures).
    Divyanshu_Sankhwar likes this.
  4. Artemus.
    Nougat Dec 31, 2019
    Artemus. , Dec 31, 2019 :
    When is the last time you formatted the phone?
    Caomhin likes this.
  5. manasarora98
    Ice Cream Sandwich Dec 31, 2019
    manasarora98 , Dec 31, 2019 :
    The new Files app is the revamped Downloads
  6. Ok1337
    Ok1337 , Dec 31, 2019 :
    On 10 Android, the auto-brightness of the screen works differently. Either sharply decreases / increases the brightness or very smoothly. On 9 android it was more stable.
    L1569409198862 likes this.
  7. L1569409198862
    L1569409198862 , Dec 31, 2019 :
    i have updated my mobile to 10.3.0. It has issue in finger unlock and camera performance has also come down though the update log mentions that camera performance has improved
  8. NRSafi
    NRSafi , via OnePlus 6 , Dec 31, 2019 :
    help post. after the OS (10.3.0) update my screen remains off for few seconds after ending a call. is anyone facing the same problem? have to press the power button multiple times to turn on the screen.
  9. Dhawal vasudev
    Donut Dec 31, 2019
  10. R1543465200018
    Froyo Dec 31, 2019
    R1543465200018 , Dec 31, 2019 :
    i think in the settings you have change under the customisation clock style may be hidden. select any one clock style to work the Ambient display
  11. Ultra.Numan
    Gingerbread Dec 31, 2019
    Ultra.Numan , via OnePlus 6 , Dec 31, 2019 :
    When you say formatted you phone to you literally been wipe everything? I have battery drain too but for me it's manageable. If I formatted my phone it would take hours to put the 9000+ music tracks back on it!
  12. Artemus.
    Nougat Dec 31, 2019
    9000+ tracks?! How big of storage space do you have and why is it all on your phone?!
    Ultra.Numan, Caomhin and ironass like this.
  13. A1550387522048
    Honeycomb Dec 31, 2019
    A1550387522048 , via OnePlus 6 , Dec 31, 2019 :
    By along this 10.3.0 update on my OP6 I see three problems after more than a week past.
    1. to take a call automatically by riding up the device to the ear is more difficult. I t is not working well and you have to try more times by changing the velocity and directions...before it was working smooth and normal and always you could take the call automatically by riding up to the ear
    2.İ could not find the last apps cleaning level...normal or completely.it was in the system settings..
    3. Even today with Android 10 update the parallel space can not be discharge manually by user...still WhatsApp is existing on parallel space..
    The rest are perfect..camera, velocity,smoothness,speed everything. also I saw the settings has been clearly ordered and useful than 9.
  14. O1577772561019
    O1577772561019 , Dec 31, 2019 :
    I am facing a lot of problems after this update. The device is OnePlus 6. Here are these -
    1. When I lock the screen using side button, a light flashes on the upper side of the screen around the notch area.
    2. Some apps are not working properly.
  15. VivekRaju17
  16. Y1575092233928
    Donut Dec 31, 2019
  17. Digvijay404
    Donut Dec 31, 2019
    Digvijay404 , via OnePlus 6T , Dec 31, 2019 :
    wifi at 5ghz is dropping but it is mentioned in the change log that it is fixed but it is not after the android 10 update. this rom is full of bugs. we need an incremental update with bugs fixed.
  18. Y1575092233928
    Donut Dec 31, 2019
  19. C1577774683724
  20. thakurnitesh84
    thakurnitesh84 , Dec 31, 2019 :
    New OS is good but I cannot see the download folder it is removed in this new version.
    waiting for resolution of this issue.
