731
OxygenOS 10.3.0 for the OnePlus 6 and 6T
  1. Artemus.
    Nougat Jan 1, 2020
    Artemus. , Jan 1, 2020 :
    What're you casting and to what makes a huuuuuuge difference.
    Caomhin likes this.
  2. Antonio88GR
    Cupcake Jan 1, 2020
    Antonio88GR , via OnePlus 6 , Jan 1, 2020 :
    Καλημέρα χρόνια πολλά και καλη χρόνια. Μετά το update έχω κι εγώ το ίδιο πρόβλημα μόνο το κεφάλαιο S στα ελληνικά.
    Βρήκες κάποια λύση η ψάχνεσαι ακόμα.
  3. djtutis
    Cupcake Jan 1, 2020
    djtutis , via OnePlus 6 , Jan 1, 2020 :
    Βάλτε την κλασική γραμματοσειρά και όχι την καινούργια αφού έχετε ρυθμίσει την συσκευή στα αγγλικά πρώτα. μετά θα είναι κομπλέ.
  4. Chinmay_Agarwal
    Cupcake Jan 1, 2020
    Chinmay_Agarwal , Jan 1, 2020 :
    after recent oxygen os 10.3.0 update my oneplus 6 sometimes becomes slow and lag in animation. even some apps stop responding every once in a while. before this update i didn't used to restart the device frequently but post this update i have to restart my device atleast once a day. overall performance has come down since this update. phone no more feel that snappy and fluid.
    Naveen_006 likes this.
  5. Jamze
    Ice Cream Sandwich Jan 1, 2020
    Jamze , via OnePlus 6 , Jan 1, 2020 :
    Can't you create another account on the phone (not guest) and configure it the same way? Guest is really for when you hand someone your phone temporarily to use.
    Artemus. likes this.
  6. et121677
    Froyo Jan 1, 2020
    et121677 , via OnePlus 6 , Jan 1, 2020 :
    I came to this forms to get the reaction of others on the update and find out about any issues so I can make an informed decision as to update or not. one thing I noticed though is that there's a bunch of douches in here. I see that people will post about a problem they are having and some of the replies are unreal. I'm like man... if your not gonna help then keep your comments to yourself. the "can't you read" or "try using search" are unnecessary. some of you act like you wrote the code for the OS. Get out of your mom's basement and relax a little...
  7. E1551613683478
    Cupcake Jan 1, 2020
  8. SuvamBose
    Eclair Jan 1, 2020
    SuvamBose , via OnePlus 6T , Jan 1, 2020 :
    Is it possible to Install Android 10.0.1 in my OnePlus 6t if im running on 10.3.0 by manually downloading the package? will it wipe out my data or just simply downgrade to 10.0.1 like it usually happens..can anyone tell me?
  9. H1542987991964
    Cupcake Jan 1, 2020
    H1542987991964 , Jan 1, 2020 :
    Hi!
    Since I have received this update, I can't share pictures on my WhatsApp. The device hungs.
  10. H1560512378088
    Cupcake Jan 1, 2020
    H1560512378088 , via OnePlus 6T , Jan 1, 2020 :
    battery draining is still not fixed in this version, heavy battery draining after this update, team OP please fix this in upcoming version, wish you a very happy new year 2020 ahead ....
  11. X1559984215293
    Cupcake Jan 1, 2020
  12. X1559984215293
    Cupcake Jan 1, 2020
    X1559984215293 , via OnePlus 6T , Jan 1, 2020 :
    could you please provide link for local upgrade, i am facing issue which shows error that installtion failed
  13. K_deep
    Gingerbread Jan 1, 2020
  14. L1531904290108
    Cupcake Jan 1, 2020
    Kintha27 likes this.
  15. Abhaysoni
    Cupcake Jan 1, 2020
  16. tamaszoltan
    Cupcake Jan 1, 2020
  17. bighairydel
    Eclair Jan 1, 2020
    bighairydel , via OnePlus 6 , Jan 1, 2020 :
    thanks for your reply
    please direct me to technical details regarding this issue and where it states the reason for lifting keyboard up from bottom of screen.
    thank you in advance
  18. Andreas Rauchhaus , via OnePlus 6T , Jan 1, 2020 :
    I can now continue to tell you my experiences about battery lifetime with 10.3.0 for the last days.
    Since I updated on 27. December I had to recharge my phone as usual. Normally I can use my OP 6T for about 2.5 days before it needs to be recharged. The same after this update. Actually I get the same usage time with OxygenOS 10.3.0. And I guess that it is possible that I can extend it up to 3 days. Because as usual after an update I play much more around on my phone to checkout the new features and settings.
    So thanks to OP team for this update. No battery drain at all.
  19. O1532347657328
    Donut Jan 1, 2020
  20. iamgauravmehta
    Cupcake Jan 1, 2020
    iamgauravmehta , Jan 1, 2020 :
    Hi,
    I'm having problem after the updates, my wifi is 5ghz and it used to work flawlessly but after the update it disconnects in random intervals for 3-4 seconds and connects again. i don't seem to figure out what's at fault here. I've reset the network, wifi, Bluetooth settings but I'm still facing this issue.
