732
OxygenOS 10.3.0 for the OnePlus 6 and 6T
  1. Caomhin
    OnePlus 9 Series Expert Community Expert Jan 3, 2020
    Caomhin , via OnePlus 6T Mirror Black , Jan 3, 2020 :
    And literally hundreds of suggestions already posted in the few pages above yours.
    Try optimizing apps in Settings Battery, only leave the ones you need run in the background or to notify you such as messages, email, Google Services, oneplus etc on Intelligent control.
    Also charge your phone to full and restart it after optimizing, and see if that helps. You may need to do this for 2 to 3 charge cycles.
    Check App battery stats at about 50% and see if there are particular apps using more battery than necessary.
  2. E1577349390170
    Donut Jan 3, 2020
  3. Caomhin
    Literally the post above yours has suggestions to rectify the issue
    ironass likes this.
  4. Jamze
    Ice Cream Sandwich Jan 3, 2020
    Jamze , Jan 3, 2020 :
    I don't think anybody here can add any more on this issue that hasn't already been said.
    Caoimhín likes this.
  5. kumarskotadia
    Cupcake Jan 3, 2020
    kumarskotadia , Jan 3, 2020 :
    post 10.3.0 update in my 6T, under phone dialler option, favourites, call history and contacts have.moved from top to bottom. this is very close to the.home, back buttons. can this be moved up? if yes pls share steps to be followed
  6. C1569601707404
    Gingerbread Jan 3, 2020
    C1569601707404 , via OnePlus 6 , Jan 3, 2020 :
    right you bro but more bug this update 10.0.3 not good stable
  7. Boubaker01
    Boubaker01 , via OnePlus 6 , Jan 3, 2020 :
    Caomhin
    They are specific to a Beta testing version for OP7 Pro, completely different hardware. Cannot be compared.
    i didn't mean that they release the same open beta of op7/7pro for op6/6t.
    all i wanted to say is that they must do a great changelog for us,in the next update.
  8. Caomhin
    Mine is running very Stable. You can stabilise yours by trying the suggestions I gave, let me know how that goes in a couple of days. Can take a few charge cycles for stability
  9. Caomhin
    I am sure the Experience Improvement Program the majority have opted into is giving a lot of Auto feedback for the developers to work on, along with the user bug report forms and feedback forms.
    Boubaker01 likes this.
  10. Caoimhín likes this.
  11. Caoimhín likes this.
  12. f00tbaLL and Caoimhín like this.
  13. NIK3SH
    Froyo Jan 3, 2020
    NIK3SH , Jan 3, 2020 :
  14. Pa_Adh
    Cupcake Jan 3, 2020
    Pa_Adh , Jan 3, 2020 :
    My OnePlus 6 used to run so much better before this update. This update has several bugs. Is there any way to provide specific bugs report to OnePlus?
  15. Jamze
    Yes, use feedback (under support).
  16. Caomhin
  17. Jamze
    'I provided them oneplus kit logs since week and till now there is no any response...'
    That's a pretty unrealistic expectation. They have millions of users, it's the holidays and you complain you've had no response in a week to a submitted log?
  18. govilsam
    Cupcake Jan 3, 2020
    govilsam , via OnePlus 6T , Jan 3, 2020 :
    Hello!
    Thanks for the update.
    Just wanted to share one issue after the update that is my click widget is not updating time on regular basis while the time appears to be correct in lock screen and top screen clock but not updating in widget that i have put on my home screen. kindly guide me or fix this issue asap.
    Thanks
  19. Caomhin
    Is the widget a 3rd party app, if so check the settings and make sure it's set to get the time from the Network provider or some such.
