728
OxygenOS 10.3.0 for the OnePlus 6 and 6T
  1. habeebsahili
    Froyo Jan 4, 2020
    habeebsahili , via OnePlus 6T , Jan 4, 2020 :
    yes on fb and Instagram i have to Force stop the apps in order to work again for some reasons Instagram stories dont load even if im connected to my wifi and sometimes my phone doesn't find the 5ghz wifi i have in my house for some reason
  2. Kytharsis
    Nougat Jan 4, 2020
    Kytharsis , Jan 4, 2020 :
    You know the reason? Facebook sucks at optimizing on Android.
    ironass and drl431 like this.
  3. habeebsahili
    Froyo Jan 4, 2020
    and what about the lags that happen out of no where when im scrolling though some photos in gallery or when my battery becomes 15 percent it gets laggy af :D i hope it gets fixed
  4. ironass
    Lollipop Jan 4, 2020
    ironass , Jan 4, 2020 :
    So, once the Bonbon Sim is inserted, it is bye-bye editing facility for the APN.
    The only other time I have come across this is on the T-Mobile (USA) carrier locked minority variant. See...
    https://forums.oneplus.com/threads/unlocked-version-one-6t-apn-settings-grayed-out.943719/
    There is a suggestion in that thread that prior to placing the SIM in, you set up an identical APN setting with all the Bonbon details. The only drawback to that idea is that there do not seem to be any published Bonbon Apn settings for Croatia...
    http://www.apn-settings.net/sim-bonbon-96#android
    I am sorry R1552494263973 but I am all out of ideas apart from, as you say, installing a custom ROM.
    Kytharsis and drl431 like this.
  5. muhammed13
    Eclair Jan 4, 2020
  6. bramgoodwin
    Froyo Jan 4, 2020
    bramgoodwin , via OnePlus 6 , Jan 4, 2020 :
    Even though Nova Launcher warns, after updating to 10.3 that Google Gestures don't work, the Gestures do work, while using Nova. 10.3 came with Google Security Patch for November. Maybe it got enabled.
  7. H1542996669630
    Cupcake Jan 4, 2020
    H1542996669630 , Jan 4, 2020 :
    Connect with 2.4Ghz WiFi
  8. O1532638253981
    Eclair Jan 4, 2020
    O1532638253981 , via OnePlus 6T , Jan 4, 2020 :
    I'm having some major screen freeze problems since the new update. Also have this annoying little white bar at the bottom of the screen on any app. didn't have this problem with the old OS
  9. Kytharsis
    Nougat Jan 4, 2020
    The bottom white lines can be removed by turning off assistant in default app settings. As for the freezing, it's recommended you format the phone.
  10. O1532638253981
    Eclair Jan 4, 2020
    Thanks for advice I'll try removing the bar. But I already reformatted my phone the day after I got the update. There was an issue with the colors in the screen that I couldn't figure out. I mean I've had the 6t for a year and the 6 before that and never had any problems.
  11. O1532638253981
    Eclair Jan 4, 2020
    Hm don't know what to do here.
  12. Kytharsis
    Nougat Jan 4, 2020
  13. O1532638253981
    Eclair Jan 4, 2020
  14. ShankySurya
    Cupcake Jan 4, 2020
    ShankySurya , Jan 4, 2020 :
    after resetting, my phone will be downgrade ? or what different would it make ?
    V1561179258865 likes this.
  15. Ajayjoelabraham
    Eclair Jan 4, 2020
  16. NIK3SH
    Froyo Jan 4, 2020
    NIK3SH , Jan 4, 2020 :
    Give a try with this,
    1. Install,
    https://play.google.com/store/apps/details?id=com.wilysis.cellinfolite
    2. In app select "System Network Settings" by selecting 3 dots menu from upper right corner.
    3. Now this is core network settings of your device so chose wisely.
    4. For your affected carrier slot, select relevant band. Like for 4G, Select LTE only.
    5. Switch Roaming tab to On or Off. This will apply change immediately.
    6. Once your network gets refreshed in notification bar, proceed for APN configuration at bottom and create new one.
    7. If & Once that done, again switch roaming tab to get this applied immediately.
    If aforementioned steps failed too,
    You can give a try with Resurrection Remix ROM once.
    https://forum.xda-developers.com/on...m-unofficial-ressurection-remix-t3892779/amp/
    Just for your reference, I am also suffering from same network related issue with my 6T,
    https://forums.oneplus.com/threads/bsnl-network-reception-issue-with-oneplus-6t.1164544/
    Only and major difference is, I am not at all able to use network (i.e. Call + SMS + Internet).
  17. ganakala.krishna
    Donut Jan 4, 2020
    ganakala.krishna , via OnePlus 6 , Jan 4, 2020 :
    Another issue, music app Saavn is playing even after pause and even playing without activating...
    weird... and embarassing in office environment...
    OnePlus team are u listening...
  18. ChampaneriB
    Cupcake Jan 4, 2020
  19. Kytharsis
    Nougat Jan 4, 2020
    IMEI number doesn't change, MAC address does. Why it changes? Privacy.
