732
OxygenOS 10.3.0 for the OnePlus 6 and 6T
  1. rjpj
    Cupcake Jan 9, 2020
    rjpj , via OnePlus 6 , Jan 9, 2020 :
    I'm facing the same issue. very annoying.
  2. chat_n_ya , via OnePlus 6 Mirror Black , Jan 9, 2020 :
    Although I'm using a OnePlus 6, and yes even I'm facing battery issues. OnePlus should roll out an update to fix this, and I'm sure they will.
  3. DJTM
    Cupcake Jan 9, 2020
    DJTM , Jan 9, 2020 :
    My OP6T not charging with my VOOC powerbank (battery charge keep disconnecting) after upgrade to Android 10.3.0 😪
  4. V1542117523567
    Cupcake Jan 9, 2020
  5. Caomhin
    9 Series Expert, Participator of the Year Community Expert Jan 9, 2020
    Caomhin , via OnePlus 6T , Jan 9, 2020 :
    While OnePlus can't be expected to give support for VOOC,
    I would suggest cleaning the connection ports on the Charger, Phone, and both ends of the USB cable. A10 seems to be a bit more sensitive to connections
  6. Caomhin
    You could try some of the suggestions here for battery issues.
    Just in case there is an App hogging resources, clear your recent apps, also try setting 3rd party apps to Optimize in Settings Battery, only leave the ones you need run in the background or to notify you such as messages, email, Google Services, oneplus etc on Intelligent control.
    Also charge your phone to full and restart it after optimizing, and see if that helps.
    Check App battery stats at about 50% and see if there are particular apps using more battery than necessary.
    How to calibrate your Battery
    https://forums.oneplus.com/threads/...ting-tips-how-to-improve-battery-life.556988/
    chat_n_ya likes this.
  7. Caomhin
  8. DJTM
    Cupcake Jan 9, 2020
    DJTM , via OnePlus 6T , Jan 9, 2020 :
    very sure is SW.. even with my phone power off, it is not charging with my power bank.. disconnect every time it goes to rapid charge mode.. previously no issue at all on Android 9.. hope OnePlus team is looking into this!!
  9. Widdl
    Donut Jan 9, 2020
  10. Aswin chembath
    Eclair Jan 9, 2020
  11. avijaunty
    Donut Jan 9, 2020
  12. Gokul7373 , via OnePlus 6T Midnight Black , Jan 9, 2020 :
    I need one information from you. what is the sim card your are using?
  13. ironass
    Lollipop Jan 9, 2020
    ironass , Jan 9, 2020 :
    GOOGLE LENS
    Camera > Settings > Smart Content Detection (on)
    Long press on the camera viewfinder screen to activate Google Lens
  14. knowledgeseeker
    Cupcake Jan 9, 2020
    knowledgeseeker , via OnePlus 6T , Jan 9, 2020 :
    My OnePlus 6T is getting it's battery drained from 100% to zero(almost 23 hours) than before the Android 10 update. This is a big performance dip. Please let me know what can I do about this & also where else to post this? Thank you
    DiogoBelo likes this.
  15. DiogoBelo
    Eclair Jan 9, 2020
    DiogoBelo , via OnePlus 6 , Jan 9, 2020 :
    knowledgeseeker
    My OnePlus 6T is getting it's battery drained from 100% to zero(almost 23 hours) than before the Android 10 update. This is a big performance dip. Please let me know what can I do about this & also where else to post this? Thank you​
    I got 33hs wit 7h SoT, OP6 On Oos 10.3.0, location off, brightness in about 20-30%.
    knowledgeseeker likes this.
  16. Caomhin
    Nah, these are jokes, corny but funny.
    How is a telephone like a dirty bathtub?
    They both have rings!
    What do you get if you cross a telephone with an iron?
    A smooth operator!
    How can you tell if a bee is on the phone?
    You get a buzzy signal!
    What is the favorite TV show of a telephone number?
    Game of Phones!
    What did the therapist say to the angry client when their cell phone battery died?
    I suggest you find an outlet!
    Why does anyone still have a landline?
    To locate their cell phone when it goes missing!
    Why does the bird never make phone calls?
    Because it might wing the wrong number!
  17. JAGADISH BHATTA
    Jelly Bean Jan 9, 2020
    JAGADISH BHATTA , Jan 9, 2020 :
    Try turning on DC dimming
    drl431 and Caoimhín like this.
  18. Jamze
    Ice Cream Sandwich Jan 9, 2020
    Jamze , Jan 9, 2020 :
    It already has it, so ask your mobile network provider if they support it?
  19. JAGADISH BHATTA
    If your network provider supports VOWIFI then you will get setting to enable it
    Caoimhín likes this.
