732
OxygenOS 10.3.0 for the OnePlus 6 and 6T
  1. mohd_areeb
    Honeycomb Jan 9, 2020
    mohd_areeb , Jan 9, 2020 :
    it was due to dc dimming when i turned it off, the problem is gone.
    Caomhin likes this.
  2. mohd_areeb
    i already did a full reset after installing 10.3.0
    having issue with multi touch while playing games like pubg!
  3. mitulgada
    Cupcake Jan 9, 2020
    mitulgada , Jan 9, 2020 :
    There's a bug in wifi.... Its gets disconnected automatically.... And after the new os update... Whatsapp is lagging too much... Not able to load images from gallery
  4. mohd_areeb
    multi tapping doesn't work properly, as i had to again and again put my thumbs and fingers over the screen to use multiple fingers at a time!
    i reported in the bug section already, any suggestions for now?
  5. Caomhin
    OnePlus 9 Series Expert Community Expert Jan 9, 2020
    Caomhin , via OnePlus 6T , Jan 9, 2020 :
    Check here if to see if it can resolve the issue.
    https://forums.oneplus.com/threads/android-10-wifi-failed-to-connect-fix.1133014/
    You can also try resetting the WiFi,
    Settings, System, Reset Options, Reset WiFi
    Just in case there is an App hogging resources, causing lag, or freezing, clear your recent apps, also try setting 3rd party apps to Optimize in Settings Battery, only leave the ones you need run in the background or to notify you such as messages, email, Google Services, oneplus etc on Intelligent control.
    Also charge your phone to full and restart it after optimizing, and see if that helps.
    Check App battery stats at about 50% and see if there are particular apps using more battery than necessary.
    How to calibrate your Battery
    https://forums.oneplus.com/threads/...ting-tips-how-to-improve-battery-life.556988/
    mitulgada likes this.
  6. JosephElsave
    Gingerbread Jan 9, 2020
    JosephElsave , via OnePlus 6T , Jan 9, 2020 :
    ok you are not Gamer .consider when u are video calling your girlfriend wifi disconnected serveral time . then what happen ?
  7. Jamze
    Ice Cream Sandwich Jan 9, 2020
    Jamze , Jan 9, 2020 :
    OK, I definitely don't get the issue then. I'm making video calls and VoWiFi whilst walking around. Phone must be switching to my various mesh units. Never drops.
    Kuronosu and Caomhin like this.
  8. JosephElsave
    i am experiencing wifi drop even near to wifi [e]1f602[/e][e]1f602[/e][e]1f602[/e]
  9. upthera
    Eclair Jan 9, 2020
    upthera , Jan 9, 2020 :
    I, for one, am not going to the obvious puns........
    Jamze likes this.
  10. NJA264
    Cupcake Jan 9, 2020
    NJA264 , Jan 9, 2020 :
    Can the update posted on the OnePlus website (10.3.0) be used on the T-Mobile variant of the 6t?
  11. kjjm
    kjjm , Jan 9, 2020 :
    Only if you do the conversion first. Search the T-Mobile thread for instructions. But you will lose Play Store certification, so Google Pay won't work and neither will Netflix. If that's important to you then you should probably wait for T-mo's update in at least a month or two.
    Caomhin likes this.
  12. NJA264
    Cupcake Jan 9, 2020
  13. AbyssIsEternal
    AbyssIsEternal , Jan 9, 2020 :
    Hola amigos
    I was reading differents posts of this thread and I'm simply disullidionned by the fact that some of you haven't yet teceived ota Android 10 update... and by all the bugs that exist which exist for those who had it... What does OnePlus do???
  14. Actify
    Donut Jan 9, 2020
    Actify , via OnePlus 6T , Jan 9, 2020 :
    they are not worried about these old phones anymore tbh no more revenue to be had
  15. G_letterio_la_fauci_aOni , via OnePlus 6 , Jan 9, 2020 :
    After a few days I've to say that the issue of battery draining has disappeared. The phone goes to deep sleep when not used and the battery has the same performance then before the update to 10.3.0.
    No particular activity or tuning on my behalf.
    Caomhin likes this.
  16. arrago123
    Cupcake Jan 9, 2020
    arrago123 , via OnePlus 6 , Jan 9, 2020 :
    al tener 2 cuentas en mi teléfono, al recibir una llamada telefónica no me aparece la ventana para contestar, solo suena el timbre.
  17. ironass
    Lollipop Jan 9, 2020
    Artemus. likes this.
  18. Luigi28
    Donut Jan 10, 2020
    Luigi28 , via OnePlus 6T , Jan 10, 2020 :
    can you send pics or explain in detail how you got it done??
  19. L1570304917045
    Cupcake Jan 10, 2020
    L1570304917045 , via OnePlus 6 , Jan 10, 2020 :
    wifi continuously getting disconnected not only in games but also while watching movies while also in whatsapp or skype call, which is kind of very frustrating now, although you guys know about this stuff u are behaving like you don't know anything, I am jus so much frustrated now I don't know how to scold one plus for this gift , I don't have words with me, thank you one plus.
  20. L1570304917045
    see now while replying here as well look at my wifi both incoming and outgoing not der which is happening continuously all time and if u thinking my wifi has some issue let me give you the screenshot
