732
OxygenOS 10.3.0 for the OnePlus 6 and 6T
  1. Tee_Eee_Bee
    Ice Cream Sandwich Jan 12, 2020
    Tee_Eee_Bee , via OnePlus 6T , Jan 12, 2020 :
    Check Advanced Reboot in developer options in settings
    Caoimhín and ironass like this.
  2. ironass
    Lollipop Jan 12, 2020
    ironass , Jan 12, 2020 :
    Only those that enabled it in...
    Settings > System > Developer options > Advanced reboot
    Caoimhín likes this.
  3. freeshared
    Froyo Jan 12, 2020
    freeshared , Jan 12, 2020 :
    Some one here are suggesting factory reset to fix battery draining,but it won't work.factory reset will make your phone fast and smooth (especially if you haven't reset anytime it after updating from pie to android 10). battery draining issue is a bug probably in kernel which keeps cpu cores always at 2.8ghz when you are using phone(even for media or internet consumption),so more heat and more battery drain.
  4. Jamze
    Jamze , Jan 12, 2020 :
    Tweaks people have made to their phones, config, and apps they have installed?
  5. Jamze
    freeshared
    Some one here are suggesting factory reset to fix battery draining,but it won't work.factory reset will make your phone fast and smooth (especially if you haven't reset anytime it after updating from pie to android 10). battery draining issue is a bug probably in kernel which keeps cpu cores always at 2.8ghz when you are using phone(even for media or internet consumption),so more heat and more battery drain.​
    There can't be a generic kernel issue like you describe, otherwise we'd all have the battery issue? There's some great advice on this thread on battery optimisation which is not a factory reset. I followed that and am easily getting > 24 hours battery life out of a 3,300mAh 6.
    drl431, Caoimhín and Trevor.Hawkes like this.
  6. Palchen
    Cupcake Jan 12, 2020
    Palchen , Jan 12, 2020 :
    just downgraded to Android pie again cos android 10 has been so laggy since the update.
    the battery doesn't even last half day even with moderate usage.
  7. Faruxaan
  8. V1548859956673
    V1548859956673 , Jan 12, 2020 :
    How do I update my OnePlus 6t .can anyone tell me ?
  9. ManishSoni07
    Gingerbread Jan 12, 2020
    thirudev770 likes this.
  10. Jamze
    Mine did too for a while after I upgraded. Have you optimised your 3rd-party apps (settings/battery/battery optimisation?) It takes a while, but set all those apps to 'Optimise' unless you need them to be active in the backround. Very happy with battery life after I did this.
  11. Jamze
    If you have a global phone (not the T-Mobile version), OnePlus have now posted 10.3.0 in the Software Upgrade section of their site. Pick your phone and follow the instructions there. Make sure you backup.
    https://www.oneplus.com/support/softwareupgrade
  12. rubbamade
    Froyo Jan 12, 2020
    rubbamade , Jan 12, 2020 :
    thought I'd post this. on 10.3.0
  13. AmanChadha
    Donut Jan 12, 2020
    AmanChadha , Jan 12, 2020 :
    not sure what to feel
    i tried almost everything, restoring, clean flashing but none of that helped so far, can't get more than 3 hours of SOT
  14. Jamze
    Have you optimised your 3rd-party apps? That screenshot shows an estimated 24 hours battery life?
  15. AmanChadha
    Donut Jan 12, 2020
    Jamze
    Have you optimised your 3rd-party apps?​
    yes
    Jamze
    Have you optimised your 3rd-party apps?[/yes only two apps are not optimised "true caller and Inshort news app" rest every app is optimised​
  16. Jamze
    OK. Bit confused what the issue is with SOT. You've had 15 hours battery life so far, 9 hrs left. What's the issue?
    DrJMun and Caoimhín like this.
  17. AmanChadha
    Donut Jan 12, 2020
    yes but look at the speed my battery got drained from 100% to 37% in just 2.5 hours with the same usage my battery will come to 0% in another half n hour
    thats my main concern my battery dont last more than 3 hours
  18. Jamze
    I don't think this is what those screenshots are saying. Your battery was at 100% 15 hours ago. You have 9 hours of charge left if you continue to use the phone in a similar way. During that time you had the screen on for 2 hours 32 minutes. That's not bad.
    Unless I've completely misunderstood how these screens work.
  19. shgng
    shgng , via OnePlus 6 , Jan 12, 2020 :
    not only battery drain issue, but I received phone unlocking issue as well after the OS update. It's disappointing OnePlus could come up with such update which feeds issue to the phone.
  20. ironass
    Learn to read your own screenshot correctly!
    Your battery drained from 100% down to 37% in 15 hours.
    2 hours 32 minutes is the time your screen was on during that time.
    At your present rate of usage, you have another 9 hours of battery life left.
    Therefore, according to your own screenshot, your phone will, on a single charge, last approximately 24 hours with roughly 4.5 - 5 hours screen on time.
