732
OxygenOS 10.3.0 for the OnePlus 6 and 6T
  1. AmanChadha
    Donut Jan 12, 2020
    AmanChadha , Jan 12, 2020 :
    yes, never thought that way!
    thank you!
  2. Uresh_Rai
    Donut Jan 12, 2020
  3. Artur101
    Honeycomb Jan 12, 2020
    Artur101 , via OnePlus 6 , Jan 12, 2020 :
    The camera performance as just as good after the update as it was before. OnePlus 6/6T have more than a decent camera which performs very well in most situations. I can say I'm perfectly happy with 95% of the shots I take on my OnePlus 6 and that's a 2 years old phone! People today want to pay $300 for their phone and to have a $2,000 worth DSLR performing camera in it. You need to be reasonable. Nice photos, the ones you published, by the way [e]1f44d[/e][e]1f60a[/e]
  4. H1561148672456
    Cupcake Jan 12, 2020
  5. Jamze
    Ice Cream Sandwich Jan 12, 2020
    Jamze , Jan 12, 2020 :
    Go to Support/Software Upgrade on the OnePlus website. Pick your phone and 10.3.0 is posted there. Follow the instructions, make sure you backup your phone.
    Caomhin, ironass and Auristic like this.
  6. X1548468446231
    X1548468446231 , via OnePlus 6 , Jan 12, 2020 :
    make sure it is not in battery conserve mode my pie behaves like this when that is on. gps also turns off with screen in that mode
    ironass likes this.
  7. Dineshsharma0802
    Dineshsharma0802 , Jan 12, 2020 :
    Hi everyone. I have one plus 6 with latest version. now we are facing the problem in setup wifi hotspot. we are unable to ft out the Setup wifi hotspot. because of this I am unable to connect the Laptop. please advise. Thanks
  8. meakshaypatil
    meakshaypatil , Jan 12, 2020 :
    Not so well designed..
    1) keypad is same with unnecessary space below it.. occupying more area of screen and you get missed touched almost every time when you try to put a space.
    2) when you connect to Bluetooth headphones.. even mobile is put on silent..the time you get a call it rings for first 1-2 sec.
    3) And I dont see any difference in notch hiding option.
    4) major thing i have observed is it's kinda changed the screen saturation. Screen feels like somewhat yellowish...(dont know if its me or it really does )
    5) Another major thing is the problem with left quick access screen from where you can get your google feeds, recently used apps and other stuff..which gets freeze while scrolling..it even sometimes becomes irresponsive to the touches..and. other applications.
    6) the contacts and favorite contacts can not be accessed with swipe which is also quite annoying..
    So far I got only those problems..I request you to please have a look into it and provide a better version.
    thanks
    syjain likes this.
  9. syjain
    Donut Jan 12, 2020
    syjain , Jan 12, 2020 :
    lot of bugs ! pls remove them. message tone doesn't work.. phone has started slowing down. contacts not visible at times
  10. Jamze
    Best to provide feedback here.
    DrJMun, ironass and Caomhin like this.
  11. meakshaypatil
    Jamze likes this.
  12. Tusharagarwal100
    Zang_888 and airiartev like this.
  13. MachoRambo
    Caomhin and f00tbaLL like this.
  14. MachoRambo
    MachoRambo , via OnePlus 6T , Jan 12, 2020 :
    Try factory reset after backup. It will sort most of the issues.
    Caomhin and danycmoi like this.
  15. DrMohamed
    Donut Jan 12, 2020
    Amarjeet Sahoo likes this.
  16. O1563295757329
  17. Caomhin
    OnePlus 9 Series Expert Community Expert Jan 12, 2020
    Caomhin , via OnePlus 6T , Jan 12, 2020 :
    Just in case there is an App or Apps hogging resources, causing lag, or draining, clear your recent apps, also try setting 3rd party apps to Optimize in Settings Battery, only leave the ones you need run in the background or to notify you such as messages, email, Google Services, oneplus etc on Intelligent control.
    Also charge your phone to full and restart it after optimizing, and see if that helps.
    Check App battery stats at about 50% and see if there are particular apps using more battery than necessary.
    How to calibrate your Battery
    https://forums.oneplus.com/threads/...ting-tips-how-to-improve-battery-life.556988/
    Auristic likes this.
  18. Caomhin
    Go to Camera settings, enable Smart Content Detection, back to camera, long press camera screen to see Lens.
    drl431 likes this.
  19. L1531822142232
  20. Alex Sem
    Gingerbread Jan 12, 2020
    Alex Sem , Jan 12, 2020 :
    here is my battery. I used a smartphone, without denying anything to myself - constant surfing the Internet, watching videos online, WhatsApp almost all the time (correspondence, audio and video calls on time for more than one hour), listening to music online for hours on the road. but there were no games.
    Caomhin and Jamze like this.
