732
OxygenOS 10.3.0 for the OnePlus 6 and 6T
  1. supertintin24
    Cupcake Jan 12, 2020
  2. sms5214
    sms5214 , Jan 12, 2020 :
    post the event update I am facing battery drain problem.. why is this so.. can this be fixed asap
  3. sms5214
    i am also facing this issue
  4. Y1547582785232
    Eclair Jan 12, 2020
  5. H1557924869607
    H1557924869607 , Jan 12, 2020 :
    I am using OnePlus 6 with Android 9. As I am reading here there are lot of bugs in this new update , suggest me will i update my phone or not?
  6. v1n_y_
    v1n_y_ , Jan 12, 2020 :
    battery isn't lasting long as it used to right before the 10.3.0 update, the camera app is crashing a lot, please fix these issues.
  7. v1n_y_
    yup same here
    Zang_888 and Y1547582785232 like this.
  8. v1n_y_
    but the screen time is two and half hours, that's not good
  9. Jamze
    Ice Cream Sandwich Jan 12, 2020
    Jamze , via OnePlus 6 , Jan 12, 2020 :
    Use the phone more then!
    SOT is a bit of a weird metric, wouldn't get too hung up on it unless your phone is going dead on you.
    Caoimhín likes this.
  10. KoKo..!
    Gingerbread Jan 12, 2020
  11. v1n_y_
    I Remember getting around 5-6hrs of screen time on a regular day till the charge ran out, even with the same usage in a day I have to charge it again in the eve(considering last charge was in the morning) to get that screen time
  12. Caoimhín
    OnePlus 9 Series Expert Community Expert Jan 12, 2020
    Caoimhín , via OnePlus 6T , Jan 12, 2020 :
    No one from OnePlus monitors this forum, its user driven.
    However do a quick search online and you can get a trade in value from OnePlus.
    You will need to search for your country to get the correct locale.
    JAGADISH BHATTA, Auristic and ironass like this.
  13. Caoimhín
    Be Proactive. Just in case there is an App hogging resources, causing lag, or draining battery, clear your recent apps, also try setting 3rd party apps to Optimize in Settings Battery, only leave the ones you need run in the background or to notify you such as messages, email, Google Services, oneplus etc on Intelligent control.
    Also charge your phone to full and restart it after optimizing, and see if that helps.
    Check App battery stats at about 50% and see if there are particular apps using more battery than necessary.
    How to calibrate your Battery
    https://forums.oneplus.com/threads/...ting-tips-how-to-improve-battery-life.556988/
    drl431 and Auristic like this.
  14. Caoimhín
    It's entirely up to you. What's on here is only a fraction of the millions of users, you will only hear of the issues, the other 99% are happy with their phones. Here are some steps to help.
    If you are not on US TMobile variant.
    You can download and manually install 10.3.0 for the International version from the OnePlus support website below. Follow the instructions given on the OnePlus website. Make sure you have backed up your phone first.
    https://www.oneplus.com/ie/support/softwareupgrade
    Once upgrade is done, it's best to then Factory reset to place a fresh install of 10.3.0 on the device. This will ensure no compatibility issues carried over from 9 Pie.
    Do a full Erase/Delete Data button, factory reset. This will restore you to a fresh installation of 10.3.0. So you will need to backup your phone.
    Go to Settings, System, Reset Options, Erase All Data, click on the Delete All Data button.
  15. V1551638499904
    Zang_888, airiartev and nagarjuna003 like this.
  16. Caoimhín
    Please read literally 2 posts above yours. Honestly there are many suggestions you can try, when reading before posting.
    Auristic, ironass and V1551638499904 like this.
  17. MCunha
    MCunha , Jan 12, 2020 :
    The worst Wi-Fi roaming ever!
    It doesn't switch to a better signal, no matter if you turn on the "switch to a better wifi" in the options.
    If you are in a large build, with several access points, you will face several problems when walking.
    You can be at side of an access point with -40 signal, it will be connected to the same (and far) access point with - 90 of signal...
    Forget about internet calling in this situation! No Skype, no WhatsApp calls etc.
    Simple awful.
  18. muhammed13
    Froyo Jan 12, 2020
    Jamze, Caoimhín and Alex Sem like this.
  19. Jamze
    Jamze , Jan 12, 2020 :
    I'd work through the battery optimisation suggestions on here. What apps are top of the list in detailed usage? I'm now at the point that I get more SOT and battery life than I need for my usage. Battery lasts > 24 hours.
    Caoimhín and ironass like this.
  20. Auristic
    Lollipop Jan 12, 2020
    Auristic , via OnePlus 6T , Jan 12, 2020 :
    I'd say you'd better buy a brain since your smartphone seems smarter than yourself...
    drl431, ironass and Caoimhín like this.
