730
OxygenOS 10.3.0 for the OnePlus 6 and 6T
  1. Xbionicle
    Cupcake Jan 13, 2020
    Xbionicle , Jan 13, 2020 :
    is there anyone else noticed that your OnePlus 6/6T isn't receiving any charge from the old OnePlus car charger after the latest update?
    DiogoBelo likes this.
  2. Alex Sem
    Gingerbread Jan 13, 2020
    Alex Sem , Jan 13, 2020 :
    [QUOTE = "Jamze, post: 21253450, member: 552573"] Может быть, вы видите скриншоты приложения сообщества, а не браузера?
    https://play.google.com/store/apps/details?id=net.oneplus.forums&hl=en_GB
    Вы можете сделать это в Chrome, хотя. Параметр в настоящее время включен во флаги. Называется «Темные сайты». Перейдите в chrome: // flags и найдите «dark». Установите флажок «Затемнить сайты ...», и тогда вы найдете новую опцию в настройках / темах.
    [​IMG] [​IMG][/ QUOTE]
    Thanks, it helped. Now I can further increase the autonomy of my smartphone)
    about the community - I know about it, the default community icon is on the desktop. but I don’t use it somehow. It’s more convenient for me to reset between browser tabs than between applications. or do you still recommend the community?
    I apologize for English, I write through a translator)
  3. DiogoBelo
    Eclair Jan 13, 2020
    DiogoBelo , via OnePlus 6 , Jan 13, 2020 :
    yeah, after downgrade to 9.0.2, and setup my phone, update to 9.0.9.
    Thanks for the tip
    Caomhin likes this.
  4. Jamze
    Ice Cream Sandwich Jan 13, 2020
    Jamze , Jan 13, 2020 :
    Your choice. It's the first thing OnePlus (or any Android phone manufacturer) will ask you to do if they investigate your issues. IME it's the only way to be sure you have a good install of the OS. Not only Android. iOS, macOS, Windows...
    I don't really understand why you 1. Wouldn't want a tested backup 2. Wouldn't want to know for sure if the issues are the OS or your config/apps.
    DiogoBelo and Caomhin like this.
  5. Jamze
    I'd stick with the browser. You don't get anything extra using the community app, other than notifications.
    DiogoBelo, Caomhin and ironass like this.
  6. atulworld2k
  7. mischa1981
    mischa1981 , via OnePlus 6T , Jan 13, 2020 :
    but remember: Pie isn't supported anymore and won't receive any more Updates.
    Caomhin, DiogoBelo and ironass like this.
  8. FaleshC
    KitKat Jan 13, 2020
    FaleshC , Jan 13, 2020 :
    you sure you installed the correct update package for 6T?
    why does it say SM-G970F model name, which is for Samsung? i don't suppose you can change that field for Oxygen OS.
    mayrsona, DiogoBelo and ironass like this.
  9. ironass
    Lollipop Jan 13, 2020
    ironass , Jan 13, 2020 :
    Looks like someone has been playing around with the /build.prop file.
    DiogoBelo, Caomhin and FaleshC like this.
  10. FaleshC
    KitKat Jan 13, 2020
    ah, and most likely messed it up.
  11. Szöllösi Attila
    Eclair Jan 13, 2020
  12. DiogoBelo
    Eclair Jan 13, 2020
    I understand, thanks for the help.
  13. themountaineagle
    Froyo Jan 13, 2020
  14. Y1576953305365
  15. KHurf
    Froyo Jan 13, 2020
    KHurf , via OnePlus 6 , Jan 13, 2020 :
    USA OP6 8/128 non Root OTA A10
    25 Dec 2019
    ISSUES after 10.3.0 update:
    general adjustments given new UI (whatever)
    really bad data; LTE .11 up .10 down
    Automatically switches to 3G on all calls
    No WiFi calling, but things like WhatsApp work fine.
    My data is slower than it's ever been. My signal bar has been so discouraged, it doesn't even show me signal source like 4G or LTE, unless I'm calling on 3G.
    I will wait for another OTA bug fix, patiently, but make sure to take care of the details. A10 has been difficult, with several Betas and persistent bugs.
    I would have rather waited a little longer for something that works better than what came before.
  16. D-Tronics_UK
    D-Tronics_UK , via OnePlus 6T , Jan 13, 2020 :
    ah yeah I changed it because an app I am running only works on Samsung phones, hang on I will change it back and see if it fixes the issue
  17. G_Karothikeyan
  18. Jamze
  19. ade0410
    ade0410 , Jan 13, 2020 :
    Why? Has your phone stopped working?
    Caomhin likes this.
  20. Alex Sem
    больше скриншотов моей батареи. сделал именно это. используется просто безбожно. особенно больше половины времени было при максимальной яркости экрана !!! Результат поразил меня.
