730
OxygenOS 10.3.0 for the OnePlus 6 and 6T
  1. tushar.gaikwad
    Gingerbread Jan 13, 2020
    tushar.gaikwad , via OnePlus 6T , Jan 13, 2020 :
    Can confirm there is battery drain in this update.
    I'm waiting for the next update to fix the idle battery drain issue.
  2. Caomhin
    Lollipop Jan 13, 2020
    Caomhin , via OnePlus 6T , Jan 13, 2020 :
    Just in case there is an App hogging resources, causing lag, Battery drain or freezing, clear your recent apps, also try setting 3rd party apps to Optimize in Settings Battery, only leave the ones you need run in the background or to notify you such as messages, email, Google Services, oneplus etc on Intelligent control.
    Also charge your phone to full and restart it after optimizing, and see if that helps.
    Check App battery stats at about 50% and see if there are particular apps using more battery than necessary.
    How to calibrate your Battery
    https://forums.oneplus.com/threads/...ting-tips-how-to-improve-battery-life.556988/
    Artemus. likes this.
  3. Jamze
    Ice Cream Sandwich Jan 13, 2020
    Jamze , Jan 13, 2020 :
    While you wait, have you optimised all your 3rd-party apps? You might have apps active while the phone idles that you don't need.
    Artemus., ironass and Caomhin like this.
  4. alresave
    Donut Jan 13, 2020
    alresave , Jan 13, 2020 :
    Battery drain?
    The guy got 10 hrs SOT and 22 hrs of charge!
    RogerOriginals and Jamze like this.
  5. StefanoD
    Donut Jan 13, 2020
    StefanoD , Jan 13, 2020 :
    Unable to find an answer to this on here, and I haven't opened up a new thread so go easy on me....
    I have Oneplus 6T on EE in UK and still haven't received OTA update. Should I be concerned? Or is it patient that I should be?
    I don't want to update from the website for fear of bricking my phone.
    Thanks.
    ironass likes this.
  6. Jamze
    I wouldn't be concerned. Nobody here knows if OnePlus have paused the OTA in response to high demand on their support channels, or if it's just taking ages.
    The web site method is identical BTW, you're just getting the file from a different place.
    ironass and StefanoD like this.
  7. StefanoD
    Donut Jan 13, 2020
    StefanoD , via OnePlus 6T , Jan 13, 2020 :
    Thanks for your reply.
    By here do you mean in UK?
    OK so back up, download via a pc then drop it onto my phone?
    Out of interest have you done this?
  8. Jamze
    Jamze , via OnePlus 6 , Jan 13, 2020 :
    'Here' referred to the forum, but yes I'm in the UK on Three and O2.
    I've done it, working well for me. some good knowledge on the forum too.
    Check all your backups (Google, WhatsApp, Nova, OnePlus Switch etc.) Transfer the local ones off the phone.
    You can actually download the update file direct on your phone, then move it to the root of internal storage. Or PC method and transfer works too.
    Then follow the instructions.
    Personally I'd do full reset/wipe, but understand why people don't do this.
    ironass, Caomhin and StefanoD like this.
  9. C1577783323814
    Cupcake Jan 13, 2020
    C1577783323814 , Jan 13, 2020 :
    yesterday i updated my device and there is no battery drain on my device and i have no problems. Only 1 game doesn't work.
    First i deleted all my files and a factory reset. (after i made a backup with switch and Google. placed switch-file on my computer)
    After factory reset download A10 on your device
    Installed A10
    Reset to factory settings after update
    Then i restored my file on my device with switch and google
    18 hrs ago i charged my device and i have still 55% battery
    Jamze and Caomhin like this.
  10. StefanoD
    Donut Jan 13, 2020
    Thanks Jamze - I may give it a go
    Jamze likes this.
  11. Alex Sem
    Alex Sem , Jan 13, 2020 :
    [QUOTE = "tushar.gaikwad, post: 21254204, member: 870634"] Может подтвердить, что в этом обновлении разряжена батарея.
    Я жду следующего обновления, чтобы исправить проблему разрядки аккумулятора вхолостую. [/ QUOTE]
    I was just trying to show that there are no problems with the battery)
    Caomhin likes this.
  12. themountaineagle
    Froyo Jan 13, 2020
  13. PerfectStorm
    Donut Jan 13, 2020
    PerfectStorm , Jan 13, 2020 :
    for those who have not noticed yet, there is an update for oneplus launcher released in playmarket...
    Caomhin likes this.
  14. M1578932975429
  15. M1578932975429
    M1578932975429 , Jan 13, 2020 :
    How did you do that?
  16. ironass
    DrJMun, M1578932975429 and Caomhin like this.
  17. W1539719608721
    Donut Jan 13, 2020
  18. ironass
    ironass , Jan 13, 2020 :
    It is not missing! :rolleyes:
    GOOGLE LENS
    Camera > Settings > Smart Content Detection (on)
    Long press on the camera viewfinder screen to activate Google Lens
    ade0410 and Caomhin like this.
  19. W1539719608721
    Donut Jan 13, 2020
    W1539719608721 , Jan 13, 2020 :
    oh thanks for the quick response....we had a symbol of google lense in cam before the update..I thought it's gone..🙂
    ironass likes this.
  20. Sebi0598
    Sebi0598 , Jan 13, 2020 :
    Would like to see an option to change the unit of measurement in the step counter from km to mi
