712
OxygenOS 10.3.0 for the OnePlus 6 and 6T
  1. Sorin_83
    Cupcake Jan 14, 2020 at 7:03 PM
    Sorin_83 , via OnePlus 6 , Jan 14, 2020 at 7:03 PM :
    I have the same problem, I don't know what causes this bug. It disappears for a while if I change the font size or display size. In the button half of the screen in shelf swiping up, down and single touch don't work, it's a Android 10 bug.
  2. jp4lm
    Gingerbread Jan 14, 2020 at 7:21 PM
    jp4lm , via OnePlus 6 , Jan 14, 2020 at 7:21 PM :
    Downgraded to latest Pie because Android 10 is too unstable so far. Lagging, graphics performance is bad, network is bad. I can't think of one thing that makes latest Android 10.3.0 better then latest Pie.
    Next time I update I want to be sure of the quality of the release.
    AbhiPatel6896 likes this.
  3. ironass
    Lollipop Jan 14, 2020 at 8:12 PM
    ironass , Jan 14, 2020 at 8:12 PM :
    You will need to convert your T-Mobile (USA) carrier minority variant to the global model before you can start using the global model's firmware. See...
    T-Mobile 6T to Global model Conversion (WITHOUT unlocked bootloader/SIM unlock!)
    As @Kytharsis states, you may want to wait until TMo release their own ersatz version of Android 10 with a new bootloader although there is nothing to stop you switching now save for the fact that global Android 10 does not permit GPay to work on converted TMo phones using the old Android 9 bootloader.
    Kytharsis and Caomhin like this.
  4. U1570439465555
    Eclair Jan 14, 2020 at 8:24 PM
  5. KuboxDesign
    Donut Jan 14, 2020 at 8:25 PM
    iamthemafia likes this.
  6. iamthemafia
    Cupcake Jan 14, 2020 at 8:28 PM
  7. Caomhin
    Jelly Bean Jan 14, 2020 at 8:40 PM
    Caomhin , via OnePlus 6T , Jan 14, 2020 at 8:40 PM :
    Just in case there is an App hogging resources, causing lag, Battery drain or freezing, clear your recent apps, also try setting 3rd party apps to Optimize in Settings Battery, only leave the ones you need run in the background or to notify you such as messages, email, Google Services, oneplus etc on Intelligent control.
    Also charge your phone to full and restart it after optimizing, and see if that helps.
    Check App battery stats at about 50% and see if there are particular apps using more battery than necessary.
    How to calibrate your Battery
    https://forums.oneplus.com/threads/...ting-tips-how-to-improve-battery-life.556988/
  8. KuboxDesign
    Donut Jan 14, 2020 at 8:43 PM
    KuboxDesign , via OnePlus 6T , Jan 14, 2020 at 8:43 PM :
    I have another problem, often screen looks like 20-30Hz. I tried clean instal, wipe cache, restart phone and nothing.
  9. U1570439465555
    Eclair Jan 14, 2020 at 8:46 PM
    U1570439465555 , Jan 14, 2020 at 8:46 PM :
    I've had the update for weeks now and have all apps set to intelligent control. the battery performance is fine but I get stutters/lag every day now.
    gaming performance is also much worse.
  10. Caomhin
    Jelly Bean Jan 14, 2020 at 8:58 PM
    Caomhin , via OnePlus 6T , Jan 14, 2020 at 8:58 PM :
    I would suggest putting nearly all 3rd apps on to optimize, it force closes the app once cleared from recents. Only leave the ones you want notifications from on Intelligent control,such as Gmail , WhatsApp etc
  11. U1570439465555
    Eclair Jan 14, 2020 at 8:59 PM
    U1570439465555 , Jan 14, 2020 at 8:59 PM :
    shall try that then
  12. Caomhin
    Jelly Bean Jan 14, 2020 at 9:00 PM
    Caomhin , via OnePlus 6T , Jan 14, 2020 at 9:00 PM :
    Only other thing I can suggest is a complete format and fresh install of 10.3.0 using the Delete Data button.
    Do a full Erase/Delete Data button, factory reset. This will restore you to a fresh installation of 10.3.0. So you will need to backup your phone.
    Go to Settings, System, Reset Options, Erase All Data, click on the Delete All Data button,
  13. Caomhin
    Jelly Bean Jan 14, 2020 at 9:02 PM
    Caomhin , via OnePlus 6T , Jan 14, 2020 at 9:02 PM :
    If you do and you find you need an app notification at a later stage, you can always go back and change it at any time to Intelligent control
  14. U1570439465555
    Eclair Jan 14, 2020 at 9:03 PM
    U1570439465555 , Jan 14, 2020 at 9:03 PM :
    i still don't think this will fix the lag issues though
  15. Caomhin
    Jelly Bean Jan 14, 2020 at 9:15 PM
    Caomhin , via OnePlus 6T , Jan 14, 2020 at 9:15 PM :
    It has for many in the past, of course, if wish you can do a full factory reset using the Data Delete button, to install a fresh version of 10.3.0, make sure you back up your phone first though.
    U1570439465555 likes this.
  16. Prashant007rb
    Cupcake Jan 15, 2020 at 1:29 AM
    Prashant007rb , Jan 15, 2020 at 1:29 AM :
    hi gys this update is not stable, gaming performance is so bad, battery drain to fast, network (internet Speed) not good
    We need a fixed update for these issues
    thanks OnePlus for this care services you provide us
  17. jayanth.nair
    Cupcake Jan 15, 2020 at 2:34 AM
    jayanth.nair , via OnePlus 6T , Jan 15, 2020 at 2:34 AM :
    I have an unlocked OnePlus6T which got the update last month. I've waited for a fix for some of the bugs below for the past month, but none has come. Here's what the update has ruined (surely I can't be the only one):
    1. Camera freezing - Both on stock app and gcam, the camera now freezes randomly. Once it does, other apps like Snapchat can't access the camera.
    2. Animations randomly slowing down - The animations randomly slow down. Fixed when locked and subsequently unlocked. But this shouldn't happen in the first place
    3. Web pages don't load - Happens when I try to open a link from an app like Twitter. It opens the browser page but nothing happens. Everything freezes and I have to kill the app. When I restart the app and try to open the link again, it doesn't even open the browser.
    I was perfectly happy with Android 9 and was fine waiting for as long as needed to get a well tested update. This update though is unacceptable. If anyone knows a fix to any of these issues please let me know. Thanks
  18. bramgoodwin
    Froyo Jan 15, 2020 at 2:56 AM
    bramgoodwin , via OnePlus 6 , Jan 15, 2020 at 2:56 AM :
    Agree, I hesitated to update to 10.3, but did, works great on my OP6 with some minor bugs. Worth updating. Do think many problems are from non USA phones.
    ade0410 likes this.
  19. sid.arur
    Cupcake Jan 15, 2020 at 3:57 AM
    sid.arur , via OnePlus 6 , Jan 15, 2020 at 3:57 AM :
    Hi, since the update to 10.3.0, I have noticed that for some apps, even though they are set to receive all sorts of notifications, don't actually show notifications unless you actually open the app. Is anyone else experiencing this?
    jp4lm likes this.
  20. SaravananRs
    Eclair Jan 15, 2020 at 4:08 AM
